Technical 32 5w wiring question
Discussion in 'Traditional Hot Rods' started by Hybrid Vigor, Jul 15, 2024.
  1. Hybrid Vigor
    Hybrid Vigor
    Hey everybody,
    I had my 32 rewired by a shop a number of years ago when I wasn't running a hood. Recently I went to put the hood back and..well.. as you can see from the pictures I've run into a problem. The way it's routed now the hood side will crush and possibly cut the wiring so this isn't going to work. I'm at a bit of loss on the best way to route this bundle. Should I drill a hole in the frame rail to run it through to the front? Run it underneath the radiator support? Any advice on how to route this wiring bundle and pictures would be greatly appreciated.
  2. alchemy
    alchemy
    Looks all kinda loose. Can you slide it inwards a little and maybe put a clamp on the inner boxing plate?
    Hybrid Vigor likes this.
  3. RockyMtnWay
    RockyMtnWay
  4. RockyMtnWay
    RockyMtnWay
    and yes, I did get some asphalt covered sheathing but haven’t gotten around to swapping out the crappy plastic stuff yet.
  5. solidaxle
    solidaxle
    from Upstate,NY
    For the smaller wiring tubing you could use something like this from Denis Carpenter
  6. Automotive Stud
    Automotive Stud
    You paid for that wiring job?
  7. Hybrid Vigor
    Hybrid Vigor
    If I drill holes to run it through the frame I think I'm definitely going to need to separate out that main trunk line.
  8. Hybrid Vigor
    Hybrid Vigor
    Thanks for the suggestion.
  9. ekimneirbo
    ekimneirbo
    from Brooks Ky
    The largest opening you can fish the wire thru is the boxed frame opening. You may have to create a hole somewhere near the firewall to begin pushing it in, if there isn't an open area already. Also, those wires crossing in front of the radiator need to be secured rather than just hanging.
  10. RockyMtnWay
    RockyMtnWay
    Did a couple 32s with a single trunk line that came through firewall feet area on drivers side only and into frame then out in front of Vega steering box where I “Y’d” it and ran to headlights/signals. Found it easier to split each headlight in the cab and run separately to each front corner (smaller bundle). Here’s a pic of later project to show where I go through firewall (in footwell). Do same on both sides.
    Please ignore stereo mount.
  11. RockyMtnWay
    RockyMtnWay
    Pics of “outta firewall and into frame rail” and “out of frame rail and up/out to headlight/signal”.
  12. Hybrid Vigor
    Hybrid Vigor
    These frame rails are the weirdest thing. THe whole thing is boxed except the ends.I thought the wires in front of the radiator were attached until I took the shell off and realized they were just tucked into it. Reason #445 I stopped having other people work on my cars.
    ekimneirbo likes this.
  13. Hybrid Vigor
    Hybrid Vigor
  14. glennpm
    glennpm
    I'd open up two decent sized holes through the boxing plate to improve access. Put in a pull wire through each hole for the inevitable future wiring additions. Pics of my full fendered roadster where I ran the wiring behind the radiator and up the sides. On the bottom I used a couple of zip ties through the radiator core.
  15. Hybrid Vigor
    Hybrid Vigor
    Do you think it matters if I run the headlight wires behind the radiator as you did or in front as they're currently situated?
  16. alchemy
    alchemy
    All the headlight wiring on my 32 is run on the back of the crossmember, not the front. Just keep it tied up tight so the pulley won't tangle it.
  17. glennpm
    glennpm
    If you plan on a 32 grill, run it behind works well.
  18. deucemac
    deucemac
    The same thing that I thought! I have been wiring cars for years and would NEVER allow such sloppy work out the door. Function and style can both be
    achieved with good planning.
  19. Hybrid Vigor
    Hybrid Vigor
    IMG_0367.jpeg Do you happen to know what this fitting on the side of the radiator shell is called? I don’t need the whole headlight conduit just that fitting and not having much luck.
  20. RockyMtnWay
    RockyMtnWay
    Try Delikon Flexible Conduit Fittings.
    pprather likes this.
  21. Hybrid Vigor
    Hybrid Vigor
    Thank you so much! I would have never found that on my own.
