Technical Do Those Epoxy Gas Tank Repair Kits Work?
Discussion in 'The Hokey Ass Message Board' started by Al T, Jul 16, 2024.
  1. 1 hole in the tank. Wondering best fix without pulling the tank and having a patch soldered on. It just came back from the tank place that steamed the tank for me. I don’t really want to pull the tank again.
    Thanks in advance.
    Allan
    chryslerfan55 and Tow Truck Tom like this.
  2. Is that gasoline running out?
    Tow Truck Tom and Paul like this.
  3. Paul
    Paul
    Editor
    I might use it as an on the road emergency band aide but not much more than to get me home.
    if you have one rust through like that you know the rest of the tank can't be much better.
  4. TCTND
    TCTND
    I'd be looking at a new tank; not a good part to compromise on.
    29A-V8 likes this.
  5. 6sally6
    6sally6
    X-2
    6sally6
  6. Bandit Billy
    Bandit Billy
    What he said! That pin hole likely is just the tip of the iceberg.
  7. Agreed.
    It’s weird, the tank was replaced in 2011 before the car being parked. There was some crud in the tank under fill tube (the fill tube was pretty crusty) so I took it in to have it cleaned. It looked OK until I put gas in it.
    Still had its red tank sealer internal coating. Must be these great fuels. This was the sending unit.
  8. They can work, but not always. If you can get a new replacement you'll be better off in the long run. My avatar had a repaired-then-lined tank, it lasted ten years until some came loose and clogged the pickup.
    29A-V8, 31 B'ville and Tow Truck Tom like this.
  9. I can find a new tank, but it doesn’t have a provision for a vent line which the existing tank has. Would a vented gas cap suffice
    chryslerfan55 and curbspeed like this.
  10. bobj49f2
    bobj49f2
    I've used the epoxy patch in the past. I put it on a tank I wired brushed clean and the epoxy wouldn't stick. It got some gas on it so I kneaded some more and stuck it back on and it stuck and sealed. I've used it a few times since and always mix a little gas with it before applying.
    Not the ideal fix but when you're young, drive a beater and don't have a lot of money it'll work.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    When I was young , I had money, now I've outlived that money & drive a beater ,with me it's whatever works .
  12. Jim Bouchard
    Jim Bouchard
    Back in my heavy motorcycle days, this stuff was standard tool box equipment for everyone I was hanging around with. We used it a few times on the road to keep on rolling. It dries fast and it worked for us. Some of the temporary fixes lasted for years….
    I haven’t seen it in decades but I found it quick on the internet.
    29A-V8 and chryslerfan55 like this.
  13. I'm going to order a new tank. The car it goes in had a vented tank to a canister in the trunk. The replacement tank doesn't have a vent connection off the tank. Would a vented cap suffice?
    .... but the Seal-All looks like a good experiment while I wait for the tank!
    curbspeed and Jim Bouchard like this.
  14. I repaired tanks on two different Semis . One, with a hole in the bottom I could stick my fingers through, with 2 part epoxy and steel wool. It was still holding 2 years later when the truck was wrecked. The second , hole was some smaller. Fibergl*** patch was still holding when truck was traded a couple years later.
    Clean it well. Dry well. Apply sealer of choice and see what happens.
    Ben
  15. 57Fury440
    57Fury440
    I repaired a tank that had a pin hole in it. I took all the gas out, cleaned the bottom of the tank and used a tight fitting screw with some JB weld. It was still working after 10 years. I don't have the car anymore, but it may still be working.
  16. A lot of people are spooked by welding fuel tanks, and I don't blame them. I have repaired lots of tanks with a small square of copper sheet soft soldered (using a large soldering iron) onto clean mild steel.
  17. FrozenMerc
    FrozenMerc
    Fill it with water and weld it up.
    INVISIBLEKID likes this.
  18. Jokester
    Jokester
    I only used it one time (epoxy two color stuff). Boom chain on the trailer rubbed a hole in the tank. Moved the chain, mixed the putty and pushed it in the hole. Finished our trip. I think it was still on the tank several years later when the car was stolen. But it worked for a long time.
    my 2 cents.
    .bjb
    firstinsteele and chryslerfan55 like this.
  19. chicken
    chicken
    from Kansas
    Yes, a vented cap will be fine. If you want to use the original vent, use a center punch to put a hole in the new tank and solder a piece of steel fuel line in for a ****** to clamp hose to.
  20. curbspeed
    curbspeed
    Yes, A vented cap will work
  21. inthweedz
    inthweedz
    A ''blind'' pop rivet will seal up a small hole.
  22. Moriarity
    Moriarity
    SUPER MODERATOR
    I would imagine that the inside of the tank look like the sending unit. Don't you guys have non ethanol fuel there?
  23. BamaMav
    BamaMav
    from Berry, AL
    I had a few pinholes in my tank in one small spot, the rest was perfect. I used a two piece epoxy stick you mixed together to make a putty like patch. Spread it out pretty thin, then used RedKote inside. Hasn't leaked again in 10 years...
  24. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Well it sat 13 years.
    So I just checked, comes to, four thousand, seven hundred forty five temperature cycles.
    My vote would be to let it go.
    Enjoy a worry free new one.
    If necessary, wait til it's time to use it. But use it
  25. 37 caddy
    37 caddy
    from PEI Canada
    you could sandblast the outside of the pinholed area and lay some resin and cloth on the freshly cleaned area,done lots of them like that.the fibergl*** sticks like **** to a blanket on sandblasted steel.Or use a soldering iron and patch it with solder,it works really well ,find a sheet metal shop and see if they have someone there who can solder it for you.
  26. F-ONE
    F-ONE
    from Alabama
    This will save you some money.
    1. Consider all the fixes for rusty tanks like.....
    Gravel/nuts/gl*** ....shaken, spun on anything from a concrete mixer to a tractor wheel
    Various rust kills
    Acid
    Chemical dipping
    Various coatings and sealers....
    Epoxy
    Think on these strongly and consider them.
    After considering this for a while, go to your toilet and peel out five 20dollar bills and flush.
    Then, order a new tank.
  27. tb33anda3rd
    tb33anda3rd
    vented cap will work fine,.
    I have fixed holes in tanks a number of ways with good success. I have used a screw with a sealing washer.
    I have used bondo then fibergl***ed over it.
    a crayon or wax candle rubbed into the hole will plug the leak so it can be epoxied, or fibergl***ed.
    I used just bondo on a repair that lasted for years [despite everyone telling me it will leak]
    bobss396 and firstinsteele like this.
  28. Sharpone
    Sharpone
    Yep I’ll bet ethanol is the cause, I think you’ll be chasing pin holes for ever, if it was mine I’d do the temporary epoxy etc fix and order a new tank, and use non ethanol fuel. I have fixed holes(punctures) in tanks that weren’t rust related and the fix lasted as long as I owned the vehicle. I drained the tank cleaned the area good using brake cleaner or acetone then a couple coats of good epoxy Slow Cure type. A sheet metal screw will help fill the hole.
    Dan
    29A-V8, 57Fury440 and Tow Truck Tom like this.
  29. bobss396
    bobss396
    I had a VW tank in a stock car that was leaking, we used a tube of gas-tank-leak-fix and it held for 2 seasons. I like the pop-rivet idea, but coat the rivet with JB Weld, aka a wet-install.
    osage orange and Sharpone like this.
  30. 65pacecar
    65pacecar
    from KY, AZ
    I had a small pin hole on a tank, applied some type of epoxy in the 80s and it's still holding with no issues. The hole was not the result of rust and on top of the tank, maybe that helped. They finally started making the tanks and I have one for it in the box, I'll replace it someday if needed. The original tank has never leaked since, no odors.
