Technical Lit my '41 on fire yesterday. That was fun............
Discussion in 'The Hokey Ass Message Board' started by kustomkat1950, Jul 17, 2024.
  1. kustomkat1950
    kustomkat1950
    from Coastal GA
    Drove it to scout out a local hot rod shop, cool place. One man band kinda thing, but he has an eye for quality..
    Driving home, smelled elect burning...Look down and my firewall, yeah, the firewall, is on fire. I have an extinguisher in the car, but don't want to deploy just yet...I smother the fire out and think I am all good.
    Now I am just trying to get it home.
    Two miles down the road, fire lights off again, I rip into the local stop and rob, run in and grab two big bottles of water, no time to pay... I tell the lady, I'll be back, my car is on fire.....
    Get the smolder out for good. Get her home and put to bed.
    Turns out, the metal coil cable going from ign to coil thru the cabin was grounding out on the firewall. So a rubber grommet should fix this issue.
    That is all.
  2. G-son
    G-son
    from Sweden
    A fuse might help too. ;)
  3. Budget36
    Budget36
    Dang Don!
    Nothing to ad, but, uh, you did go back and pay the lady, right?…:)
    SS327, Speccie, Sharpone and 2 others like this.
  4. catdad49
    catdad49
    Glad to hear that it wasn't worse, have you calmed down yet?!
  5. Petejoe
    Petejoe
    from Zoar, Ohio
    Glad you made it but why on earth would you continually drive it knowing you had a dead short. Sounds like you need alittle more than just a rubber grommet and a fuse at your electrical system.
  6. BINGO!!!
    AND! Why is the "metal coil cable " HOT??
    Ben
    Petejoe, Sharpone and alanp561 like this.
  7. lothiandon1940
    lothiandon1940
    WOW!! Major pucker factor here!
    downlojoe33 and Sharpone like this.
  8. Automotive Stud
    Automotive Stud
    I'd keep the coil under the hood where it belongs.
    Petejoe likes this.
  9. kustomkat1950
    kustomkat1950
    from Coastal GA
    I did pay the lady, not into thievery...LOL!
    I did not knowingly drive a car with dead short. This took me by surprise. Per the manual, all the wiring is straight up by the book. It has been re-done in the past, and they used the factory wiring with the cloth wrap...sigh.
    Coil is mounted to the block, like it should be. There is a wire that goes from the coil to the ignition switch, that is the subject in question and has a stock metal sheath and I have no idea why. I asked my buddy with a '39 if his was set up the same way, and he confirmed.
    Just to re-cap, iggy switch (cabin) to coil (engine bay). Am I off base here?
    Budget36 likes this.
  10. kustomkat1950
    kustomkat1950
    from Coastal GA
    That being said, I am looking into the instrument cluster and ign switch for faults.
  11. K13
    K13
    Why is the metal sheath hot? It shouldn't have any power going to it to short out.
  12. skooch
    skooch
    The original ignition wiring on my 47 Pontiac was also covered with a coiled metal loom. I would imagine if the old wiring cracked inside it would short out.
    ffr1222k and firstinsteele like this.
  13. Petejoe
    Petejoe
    from Zoar, Ohio
    Looks to me you were hoping a water bottle was going to allow you to continually drive it.
  14. kustomkat1950
    kustomkat1950
    from Coastal GA
    Nope. I fix things the right way. But thanks Pete.
    I think the metal sheath slid down to touch the energized side of the coil, hence the hot wire.
    osage orange likes this.
  15. Budget36
    Budget36
    Sorry about the name screw up. I didn’t have my reading gl***es on and I thought lothoniandon had made this thread.
    But good to know you went and covered the water tab!
    SS327 likes this.
  16. TCTND
    TCTND
    I'm not sure about your car but the LaSalle I had (in the middle of the last century) had heavy shielding over that wire and the coil. I believe it was a theft deterrent to prevent hot wiring the car. When I lost the key while fishing I had to hot wire it and that was a real pain.
    osage orange and Budget36 like this.
  17. Speccie
    Speccie
    That is some scary stuff, I am glad you saved your ride, shudder to think.
  18. rockable
    rockable
    If you think that was fun, wait until you try to get the smell out. Ask me how I know. :D
    osage orange, Speccie and SS327 like this.
  19. Onemansjunk
    Onemansjunk
    from Modesto,CA
    SO, this is how a FIREWALL works...good to know...depends on which side your'e on...
