Technical Low Fuel Pressure Gauge
Discussion in 'Traditional Hot Rods' started by ‘28 RPU, Jul 10, 2024.
  1. 05snopro440
    05snopro440
    The comparison should be between the ****s 0-5 and the 0-15 posted earlier in this thread, you'll find that makes more sense.
  2. Beanscoot
    Beanscoot
    How about showing us the pictures?
  3. Hotrodmyk
    Hotrodmyk
    Marshall gauge for me. Have used both filled and unfilled.
    Bandit Billy likes this.
  4. seb fontana
    seb fontana
    from ct
    I have what the OP was asking for but he never pm'd me so maybe changed his mind.
    chevy57dude likes this.
  5. ‘28 RPU
    ‘28 RPU
    I’m sorry Seb, I somehow missed your earlier post. I will pm you now.
  6. chevy57dude
    chevy57dude
    Did you end up with a gauge? Just found one here, but Seb was 1st.
  7. burl
    burl
    from Minnesota
    I've been using the old air or oil pressure gauges they work well and check pretty accurate gauge 1.jpg gage 2.jpg
    BigRRR, Bandit Billy and skooch like this.
  8. theHIGHLANDER
    theHIGHLANDER
    Here's an idea. Run one initially, 1st cpl weeks maybe. Now take it off, give the innards a drop of 3 in 1 oil, seal it up and put it away. Fuel pressure is a set and forget. If you have to up and down all the time there's a problem. Now it's a tool and not something that may vibe apart and become wrong, or worse, leak with potentially firey consequence. Once you've sorted that out you can easily discern stuck floats and such that may bring issues.
  9. birdman1
    birdman1
    why would a 0 to 100# gauge be less acurate than a 0 to5# gauge? I see no difference.
  10. 05snopro440
    05snopro440
    Any instrument that has a larger scale is inherently going to have more error in the measurements at certain points in the scale.
    A 0-5 gauge also gives much better resolution when reading say 3.5 psi than a 0-100 gauge, because it's effectively zoomed in.
    TrailerTrashToo likes this.
  11. 19Fordy
    19Fordy
    I have found that replacing the liquid in liquid filled gauges with DOT 5 brake fluid results in less needle vibration.
