Projects Building My First Roadster in San Francisco
Discussion in 'Traditional Hot Rods' started by J.Ukrop, Sep 7, 2020.
Tags:
  1. ZerroHalfcup
    ZerroHalfcup
    Pushing that out after bolting the body on is what it's all about, you can't beat that feeling. This is exciting stuff.
    Outback, winduptoy, Nobey and 3 others like this.
  2. Tim
    Tim
    from KCMO
    Hot dog! Looking good. I’m doing the same crush tubes in the subrails on my A but I think I’ll weld them around the top as well.
    so close! I can see the video of it cackling down the street to a neon marque in my mind clear as day!
    Outback, winduptoy and Nobey like this.
  3. Nobey
    Nobey
    When you have that kind of momentum going don't stop for anything. You're like that old Army
    commercial in the 60's, ( we get more done by 9am than most people get done all day), Ha.
    41 GMC K-18, J.Ukrop, Outback and 2 others like this.
  4. So Cal Brian B
    So Cal Brian B
    from Pekin, IL
    Go Joey go!! The car looks perfect and it's coming together very quickly. Can't wait to see it rolling down the road!!
    Kelly Burns, J.Ukrop and winduptoy like this.
  5. winduptoy
    winduptoy
    udden udden uuuddennn....
    screeeeechhhh
    smell the burning rubber....
  6. BigJoeArt
    BigJoeArt
    heck yeah man! looking good!
    good to see the new seat! should make it way more comfortable!
    Keep it rollin!
    41 GMC K-18, winduptoy and J.Ukrop like this.
  7. Nick32vic
    Nick32vic
    Yes! The new car chair looks good in there!
    J.Ukrop likes this.
  8. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    We're really goin' now!
    Yes they are! It's been a busy week but I'm hoping to hop back on it this weekend.
    Thanks, Jimbo. I'm about 80% through the process, and I'll make sure to post about it!
    Amen to that!
    If I had access to welding at the house, I'd do the same. And ahhhh I can't wait for the first drive!
    Hahah I love this quote. I told my roommate Benj about it and he also got a good laugh!
    Thanks, Brian! You and me both. Hope the foot is doing well!
  9. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I dream of smoking meats! Boiling bolognas!
    Thanks Joey! Oh man you wouldn't believe how much better it is. Night and day difference.
    Car chair is v good. Old one needed replaced.
  10. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    I have nothing bad to say about the old car (bus) chair. That said, I don't have the space for it. If you're local and you need it for your build, please let me know.
    Mocking things up with the new setup. Note that the steering column has been added to the equation.
  11. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    So, the question is, how do you make this seat work with the stock seat riser? I looked at it, sat in it, folded it up, folded it back, and finally devised a plan. It's pretty simple. First, I bought some 1x2 tubing from Bay Metals in Bayview.
    The place is incredibly cool, and the folks who run it are extremely nice.
    Since the metal comes in 20-foot lengths, they let you cut it yourself on site.
    After the trip to Bayview, I swung by the Sunset to lend the Hartleys a starter Bendix. They were on their way up north from the Central Coast for Saturday's Northern California Reliability Run. Both Jeremy and Heather are the nicest people, and it was amazing to see another Model A hot rod in the city. IMG_3616.jpg
    Later that night, we had our neighborhood potluck/showing of Cars. I was happy that I could roll my roadster out and share what I've been working on!
  12. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Saturday of course was the Roadster Run. I'm getting my full recap ready for Friday, but man was it inspirational. 6P1A0658 resize x.jpg
    This is a shameless plug for my weekly Jalopy Journal article. For this piece we'll have plenty of digital shots, like the one above, as well as 35mm film, seen below. Scan42.jpg
  13. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    In between the cutting and building of the seat base, I decided to jump into the steering.
    So, on Sunday morning, I built a plate and broke out my new two-inch hole-saw.
    Full speed ahead!
    I'll end with this piece of huge news. Once I clamped the box into position, I grabbed the header and apprehensively set it into place. Much to my surprise, it fits. It 100% clears the box and the column. I absolutely couldn't believe it.
    Once again, there's a lot more to say, but it's getting late out here. We'll pick back up soon!
  14. winduptoy
    winduptoy
    I'm impressed how you get 28 hours out of a 24 hour day plugging away at your life and projects...
    before you know it you will be on the road in vision two dot zero
  15. Tim
    Tim
    from KCMO
    Fantastic updates! Looking forward to Friday morning as always :)
  16. I have a small tech tip that I use for boring a hole with a hole saw. If you've ever been frustrated that the saw sometimes spins a bit oblong making your hole larger than needed then here is what I have started doing.
    -I use a stepped bit to make the pilot hole since they cut mostly round holes, most hole saw arbors use a 1/4" pilot bit, so drill your hole to match. If you can find them there are long drill bits out there that I remove the flutes from to make a smooth, non cutting pilot bit. Grind a flat spot on the end for the set screw located in the arbor to secure it. Make sure your new pilot shaft is the right size and snug in the arbor so it is concentric.
    - Attach the hole saw of your needs to the arbor and go to town as you normally would. Not having a drill bit cutting and enlarging your pilot hole will lessen the chance of the saw spinning off center as you bore through thick steel. The only variable is the condition of the saw itself, obviously it should not be damaged or bent for best results.
  17. And if you need that new seat done up right, I had my mini van bench covered by Bill's Auto and Boat Upholstery in Burlingame on California Ave. I had him do it with boat spec material (good for a roadster since it is exposed to all of the elements) and it has held up well since it was done in 2014. He can add or remove cushioning to the seat back and seat to your fit your needs, to fit in my truck the seat back had to be as thin as possible and still comfortable.
    Nobey, winduptoy and Six Ball like this.
  18. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Thank you so much. I do my best to make it all happen. Some days are better than others!
    Thanks for always reading!!
    Great tips! I plan to give him a call!
    Nobey, Tim, Outback and 1 other person like this.
  19. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
  20. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Most of my garage time this weekend was dedicated to the seat. I managed to finish the steel frame, which attaches to the stock riser. I'll take detail pictures of once it's out of the car again. It's sturdy and comfortable. I still need to drill my seatbelt mounting holes and buy the corresponding hardware. Once that's complete, I'll paint it black.
    Although the new seat isn't the most aesthetic thing in the world, it earns big points from a function standpoint. Now that it's in position, I have a fun and practical solution for that front riser area. I will say that I'm really happy with how the package tray fits. When sitting in the seat, it does not hit you in the back. I'm not someone who keeps spare parts on hand, but I'm glad I didn't end up selling these two pieces of very old metal. I plan to build some sort of filler panels to flesh things out on either side of the seat too. IMG_3831.jpg
    This afternoon, I finally plopped in my Tanks, Inc. gas tank. I'll be bending up a metal floor soon, so please ignore the wood. I'm pleased with how it fits. It will bolt solidly to the subrail cross-piece/new floor.
  21. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    From there, I finalized the steering flange to prepare it for the next steps. IMG_3832.jpg
    Tomorrow, I'll drill the frame to accommodate it.
    How many how-tos on the internet are completely false? I can't say for sure. But I will say this. I've been putting off taking the horn ****on off this wheel for the better part of a year. Right before heading inside for the night, I did a quick Google search and found the instructions on how to do it. Push in the center. Turn the ring counter-clockwise. Done. I don't think this has been apart since the '50s. Now, I need to remove the top of the old steering shaft. We'll dive into that soon. Suggestions are greatly appreciated.
  22. J.Ukrop
    J.Ukrop
    SUPER MODERATOR
    Here & There
    @SAVAGE sighting at Ocean Beach this morning
    I swung by this incredible, original mid-century modern house in the Sea Cliff neighborhood today. If I won the lottery, I think I'd have to move in.
  23. 41 GMC K-18
    41 GMC K-18
    Hey @J.Ukrop
    Most impressive as to how all of this is coming together.
    I can totally relate to the feeling of getting something done correctly.
    To a much lesser degree, of putting things together, you might want to check out my build on the antiquated forum, the "FORD COE HEADLIGHT UPDATE" , I think you might enjoy the photo sequences.
    Bravo on all of your brilliant work, and extreme patience.
    Thanks from Dennis.
  24. Tim
    Tim
    from KCMO
    Got some better photos of what remains of the steering shaft in the wheel?
    41 GMC K-18 and J.Ukrop like this.
  25. RodStRace
    RodStRace
    The hub of the wheel should be strong. A press could make light work of it.
    Is the nut still in place? Are the splines in decent shape?
    A steering wheel puller is also a typical tool for this. Borrow from a store.
    I'd avoid heat if possible.
    J.Ukrop, Nobey and Tim like this.
  26. Tim
    Tim
    from KCMO
    ^ that was my initial thought as well. Take the nut off and use a puller or press to remove the shaft out the back
    J.Ukrop and Nobey like this.
  27. winduptoy
    winduptoy
    just use a regular steering wheel puller...you might need that shaft nub later
  28. Nobey
    Nobey
    That looks like a Cad flathead in that 33 coupe.
    J.Ukrop and Outback like this.
  29. RodStRace
    RodStRace
    I agree, IF he has access to one. He's shown a press at his friend's place. Also he is pals with 947 works, who should have a press but may not have a steering wheel puller since he does bikes.
    A big vice and 2 well chosen sockets will do it too. Just needs a 'pop', unless there is more to the story.
    J.Ukrop, Tim and Outback like this.
  30. Beanscoot
    Beanscoot
    I like to put the nut back on a few threads before using the puller so that when it breaks loose, the wheel (or me) doesn't go flying.
