rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  1. Time for testing the new set up. Sunday Sunday Sunday union grove wisconsin. Be there.
    mad mikey, saltflats, TFoch and 7 others like this.
  2. Harv
    Harv
    from Sydney
    Be there in spirit. Go man, go! :)
    Cheers,
    Harv
  3. wrenchbender
    wrenchbender
    Keep us in the loop Brian hope all is good I will be at nitro chaos this weekend at mokan I’ll be breathing in nitro too just not under my right foot like you will be lol
  4. I wish I could make that.
    saltflats and porkshop like this.
  5. The coupe gets new dancing shoes. Tires should be bought in pairs with matching cir***ferences.
    The fastest way to destroy them is doing long smokey burnouts. While they look cool they will ruin tires in no time. When the oil is burned out of the tires they are junk. They dry out and get hard. It will be noticeable. They will also start smoking less on a burnout. A sign of too big of a burnout is when the sidewall turns brown. The tire is getting too hot. 20240719_184951.jpg 20240719_184956.jpg
  6. I check the cir***ferences after they are mounted. If one is larger than the other it will steer the car toward the smaller side.
    To correct that the tire is over inflated and put in the sun. The tire is stretch to match the larger one. It takes time and patience to correct a miss matched set.
    Regular maintenance should include a tire measurement.
  7. Sharpone
    Sharpone
    racer-x are bringing the beast to Jefferson this fall?
    Dan
    porkshop likes this.
  8. No. We were the featured car in the spring. They don't repeat the cars. I will be in my regular spot
  9. New tires for the race car. New tires for the stroller. Grampa has it going on for the 8 week old grandson. 20240721_173510.jpg
  10. 427 sleeper
    427 sleeper
    LOL! I had a Grampa like you!!! It was the BEST TIME OF MY LIFE!!! :D:D:D Memories are being made that you don't even realize!!! You're too Friggin' Cool Man!!! :cool::cool::cool:
    Thank You for letting me relive some of the things my Grampa did for me. ;)
  11. Sharpone
    Sharpone
    Congratulations on the grandson
    Dan
  12. wrenchbender
    wrenchbender
    How did the testing go
    mad mikey and chryslerfan55 like this.
  13. It went great. The new four link setting is perfect. The car flew right past the 330 without spinning the tires. The shock setting is close. On the second p*** I loosened the shocks three clicks. This didn't work. This resulted in too much wheel speed.
    The fastest you will ever go is with the tire spinning a revolution or two at the hit. You might ask why? Won't spinning make you go slower? Not really. A slight spin keeps the rpms up. Sticking the tires brings the rpm down out of the ideal power range. I called up a friend to shoot pics and video. He has great equipment. Slow speed video is the only way to go.
    Unfortunately the coil or points box went bad causing a loss of power on the top end. The parts have been replaced. We are ready for the lannon car show Saturday. 8 nitro cars firing up. I'm trying to post videos.
  14. First hit.
    Tires hit
    Body drops two inches
    Tires spin
    Tires wrinkle but don't wad up
    Weight is transfered
    Body is level without bouncing by the tree.
    Just about perfect.
    After a few more p***es on the tires and it will be.
  15. Three clicks softer on the shocks resulted in too much wheel speed.
    To get this perfect the data logger will have shock and driveshaft sensors. Things happen so fast the eye can't see what's going on. These slow motion videos can get you close. There's alot to look at here if you know what to look for.
  16. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
  17. DDDenny
    Are we having fun yet!!!
    mad mikey and Sharpone like this.
  18. 19Eddy30
    19Eddy30
    from VA
    $$ well spent & will pay for itself ,
    Data logger was suggested and recommended close to few years ago,
    The Technology has /doses changed almost 2-3 weeks , all most ever p*** made captured in that little computer,
    Is knowledge,
    If you look back , on Kenny Bernstein , I Believe Armstrong Crew Chief for several weeks Body up ,
    Black box , was covered up ,
    Algoma56 and chryslerfan55 like this.
  19. AmishMike
    AmishMike
    In that 2nd run, right rear wadded up bit more & started to shake bit more then left. Appears to me anyway…. U the expert
  20. It's fighting for traction. We dropped the rite pressure from 12.75 to 10.0. I had it higher for years because the car ran good at 12.75. With the new setup we had to try it. The car is set up now to not smash the rim into the track. Now the pressure can be lowered. The video was watched at the track after the first p***. I wanted to try loosening the shocks three clicks. This will result in more wheel speed. The slicks had one p*** on them now and I wanted to get more aggressive. It didn't work because the the tires spun more just as we figured. The shocks are back to were they were. All part of the sorting out procedure.
  21. some cool editing by Calvin
  22. wrenchbender
    wrenchbender
    Looks great the first p*** was definitely better but without trying the second p*** you wouldn’t have known the difference glad you are goin in the right direction
  23. Harv
    Harv
    from Sydney
    On the second p***, something moves from mid-left of the view to lower right. Can't make out what it is... leaf? lizard? If it's a lizard, I better the critter is deaf :)
    Cheers,
    Harv
  24. SS327
    SS327
    I think it was a mouse or vole. Not too many lizards up north, but lots of messes!
  25. Oneball
    Oneball
    Alien mouse. It seems to be able to levitate!
  26. Devil69
    Devil69
    from Glen Ellyn
    It was a bird.
  27. Harv
    Harv
    from Sydney
    Lucky he missed the birdcatcher :D That thing is mean enough to **** in an albatross, or stray children.
    Cheers,
    Harv
  28. kabinenroller
    kabinenroller
    I thought “Elephants” were afraid of “ mice” thats why the car took off so quickly.
    SS327, loudbang, chicken and 3 others like this.
  29. The 39 guy
    The 39 guy
    That's a pretty nice beer holder you have there Grandpa!
