The stack injection picture thread
Discussion in 'The Hokey Ass Message Board' started by mctommy, Feb 13, 2014.
  1. PackardV8
    PackardV8
    Yes, as mentioned, the Scott won races back when, but seen any in the winner's circle in the past forty years?
    No, Scott's are not really streetable. Now, here come all those who swear they are driving stack injectors in freeway rush hour traffic. Yes, it can be done by very patient, very savvy builders who live in warm, mild, low al***ude, but kids, don't try this at home.
    Maybe, think about the OEM systems which made constant-flow injectors actually work. The one thing they all have in common is they DON'T have stacks. The '57-65 Chevy Rochester had a common plenum and ****erfly, as did the '80s Bosch systems. When there is the ability to measure all the air and use that to adjust volume and mixture, constant flow works on the street.
    But then, this thread is all about the looks and secondarily the horsepower the individual /isolated runner stacks make. So IR = not streetable. Think having to build a separate starting priming system or alternately, squirting raw gas down the stacks, a la Tommy Ivo on his nailhead T-bucket roadster.
    There is one nice side benefit of IR stacks; the isolated runner does reduce the effect of long overlap camshafts. Once properly tuned, the IR will idle and pull from low RPM much better than today's common single plane intake.
    jack vines
  2. jimmy1931
    jimmy1931
    Switched from short to tall stacks.
  3. the shadow
    the shadow
    hilborn w/6" stacks on a 331 ci
  4. All American 6
    All American 6
    Hot Rod Power Tour 2013. Mechanical Hilborn.
    <EMBED height=480 type=application/x-shockwave-flash width=640 src=//www.youtube.com/v/1gGY3EyCRaI?hl=en_US&version=3&rel=0 allowscriptaccess="always" allowfullscreen="true"></EMBED>
  5. R W Ohio
    R W Ohio
    from Ohio
  6. JEM
    JEM
    Oh God, you've just brought back my nightmares. Where's the Scotch?
    The guts of those things was basically an air meter that varied fuel pressure to the injectors (measured against a reference pressure that was controlled by engine temperature and, later, oxygen-sensor feedback) based on airflow. The number of machining steps involved in the production of the valve block (the 'fuel distributor') boggled the mind. Very German. Also ugly as hell from an appearance standpoint. And the air meter attached to the fuel distributor was, in many applications, a giant cork in the airflow.
  7. DRAGSTER_JOHN
    DRAGSTER_JOHN
    here is mine :) 2 3/16 hilborn on a 398 c.i. sbc on methanol
  8. Dean Lowe
    Dean Lowe
    In '63 this Hilborn injection was worth 5mph in the 1/4 over a Rochester unit.
  9. magooz
    magooz
    Chris,
    I just saw this H.A.M.B. site on Injectors. Is yours a 3" Crower like ours? When I saw yours last summer on your Altered Wheeelbase FX Comet I thought it was a BBC Hilborn.... Magoo
    michaeldbarnes likes this.
  10. 28dreyer
    28dreyer
    from Minnesota
    Bodies are 1960's Tecalemit Jackson (English, sold in this country by Holman Moody) 40mm, originally cast in pairs to dimensionally replace Weber carburetors. They were acquired from Rich, sawed apart, nozzles replaced with Kinsler and the idle air circuits plugged. Conventional pump, barrel valve and by p***es.
    Thanks to Rich, I'm having fun also.
  11. R W Ohio
    R W Ohio
    from Ohio
  12. Never2old
    Never2old
    from so cal
    Now restoring this car need stacks see "wanted" section please.
  13. RichFox
    RichFox
    As seen on the Landspeed racing site
  14. II FUNNY
    II FUNNY
    This one is headed for my 1931 Chevrolet.
    Meltdown Drags
    July 18-20 2014
  15. 35WINDOW
    35WINDOW
    Hey! That's mine!
  16. speedwise
    speedwise
    Here's mine too
  17. 35WINDOW
    35WINDOW
    Nice! Love the Car!
  18. Pewsplace
    Pewsplace
    Here is mine in a 40 sedan delivery. The unit is an Inglese with a FAST operating system. Works fantastic.
  19. Saxxon
    Saxxon
    49 Prefect...aka...Fuel Injected Suicide Machine
  20. slayer
    slayer
    Is this the car your restoring?
  21. FrozenMerc
    FrozenMerc
    A Friends Outlaw tribute car.
  22. 37willysgasser
    37willysgasser
    ImageUploadedByH.A.M.B.1399037107.078225.jpg ImageUploadedByH.A.M.B.1399037140.584752.jpg
    41 Willys g***er resto
  23. RodBender57
    RodBender57
    from JawJah
    enloe likes this.
  24. CGkidd
    CGkidd
    Eventually going on my 56 Olds rocket engine in my 1950 Stude g***er.
    402BOSSMAN likes this.
  25. shop teacher
    shop teacher
    I just picked up a Hilborn unit on Craigs List for $250! I need stacks and how in the hell do I run this on the street. I am now doing my homework, any advice is welcome. Thanks, Bill
  26. Magfiend
    Magfiend
    Bringing back up this old thread - this is my Algon that I am currently (over)restoring - all the br*** is now polished, new hoses and the manifold will be blasted shortly.
  27. Magfiend
    Magfiend
    Anyone have any of these Tecalemit Jackson individual injector bodies? I need 2...
    enloe likes this.
  28. Mitchell Rish
    Mitchell Rish
    from Houston MS
    enloe and 427 sleeper like this.
  29. Flatrod17
    Flatrod17
  30. Flatrod17
    Flatrod17
    enloe, 427 sleeper and RmK57 like this.
