Projects ‘29 High Time!
Discussion in 'Traditional Hot Rods' started by Piewagn, Jun 7, 2024.
  1. Piewagn
    Piewagn
    Yes…
    That’s weed whacker string to keep pipe from kinking during the bending process…
    Just Gary, dmar836, G_Don and 11 others like this.
  2. Dave G in Gansevoort
    from Upstate NY
    Now that's quite the trick!
  3. I'd just put it down to DeJa'Vu all over again!
  4. Piewagn
    Piewagn
    So now, it gets removed, finished and painted…clips installed, then final mounting. I didn’t want to drill holes in the firewall for clips to keep it from vibrating, so I made this bracket.
  5. Brilliant!
  6. Piewagn
    Piewagn
    Just need to plumb out to rear wheel cyls and the brake plumbing is done!
    I also built a battery box for under the p***enger floor, it may create a challenge with the exhaust, but I’m sure it’s nothing I can’t handle…
    Thanks for checkin’ in fellas!
  7. alchemy
    alchemy
    Aren’t ya kinda asking for it by putting the brake T directly under the spring clamp? Looks like they will meet on a hard bump.
    Also I gotta say I’ve never seen short lengths of hard line out of a wheel cylinder, then connected to the hose. What is going to support those joints hanging in mid air and getting yanked on by the hose?
    Piewagn, winduptoy and Fogger like this.
  8. Fogger
    Fogger
    The brake hoses should be replaced with ones with the correct ends to eliminate the short hard lines. There will be flex pressure on those short pieces and eventually they will work harden and snap. Your project is great and you don't want a brake failure to cause an accident.
  9. wheeldog57
    wheeldog57
    Hey @Piewagn , this is how you get @Mart attention. Cool project you have there and good on you helping out. We'll be watching
    winduptoy and Piewagn like this.
  10. Piewagn
    Piewagn
    The camera shot makes it deceptive... plenty of clearance...
    Okie Pete and winduptoy like this.
  11. Piewagn
    Piewagn
    If you see the shot with my finger to the backing plate, that's where bracket will be going to secure the hard lines. Not one for playing twister trying to remove wheel cylinders...
    Okie Pete, winduptoy and Outback like this.
  12. brady1929
    brady1929
    Very nice of you to help him with his dream.
    Tim, Piewagn, winduptoy and 1 other person like this.
  13. Piewagn
    Piewagn
    Thanks for all the input and concerns fellas… input is ALWAYS appreciated!
    winduptoy, loudbang and Outback like this.
  14. Tim
    Tim
    from KCMO
    Very cool of you to step up. Thanks for sharing along the way
    winduptoy, Piewagn and Outback like this.
  15. Piewagn
    Piewagn
    Now I’ll make a “U” bolt or a type of strap to secure it… Like I said, I’m not one for playing twister to remove wheel cylinders…:D
  16. Am I correct in "***uming" that's NiCop tubing you're using?
    Kelly Burns and Piewagn like this.
  17. Toms Dogs
    Toms Dogs
    from NJ
  18. Piewagn
    Piewagn
    You would be correct… it’s the NiCop.
    winduptoy and Kelly Burns like this.
  19. Tim
    Tim
    from KCMO
    Could drill one hole and use a rubber lined adel clamp
    dmar836, Outback and Piewagn like this.
  20. Okie Pete
    Okie Pete
    Good of You to help Bill get His pickup on the road .
  21. Piewagn
    Piewagn
    Yes…could do that too. Thanks for the input! :D
    winduptoy likes this.
  22. Piewagn
    Piewagn
    Thanks Pete!
    Can’t wait to see him enjoying it finally!
    Outback and Okie Pete like this.
  23. 1-SHOT
    1-SHOT
    from Denton
    This is what the H.A.M.B. Is all about helping each other out. Kudos to you Piewagn and the weed eater string is a nice tip. Frank
  24. Piewagn
    Piewagn
    Thanks Frank! Lord knows I've got my fair share of help around here...thanks for checkin' in!!
    Outback and winduptoy like this.
  25. 1-SHOT
    1-SHOT
    from Denton
    Sorry I am not closer so I could help.
    Piewagn likes this.
  26. Piewagn
    Piewagn
    Well I appreciate the sentiment…
    Thank you!
    Outback likes this.
  27. Dean Lowe
    Dean Lowe
    So nice to see a Model A being built with fenders. Good on you sir! This one will be nice.
  28. Piewagn
    Piewagn
    Thank you Dean! For the most part, it will have a mostly outwardly stock appearance, but with that ageless flathead V8 rumble…:D
    Thanks for checkin’ in Dean!!
    Dean Lowe likes this.
  29. Illustrious Hector
    Illustrious Hector
    Ok, the blue ones are U.S., the black are Canada, I've also seen red ovals, what gives?
    Outback likes this.
  30. RICH B
    RICH B
    I'm curious; what part number front wheel cylinders have a tube seat?
