Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. alanp561
    alanp561
    Came out of an apartment that three of us were sharing one day to find one of the other guys tearing into his 394 powered '39 Oldsmobile sedan. The manifold was laying in the parking lot, and he was getting ready to pull the heads. I asked him what he was doing, and he said he was going to mill the heads. He didn't want any help, so I went to run some errands. When I got back, he had the heads upside down and was making slow p***es across them with a 7-inch grinder. I just shook my head and went on.
  2. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    I talked to Warren Johnson several years ago as he was taking a DA to the flywheel in his Pro Stocker., running the starter to rotate it.
    I asked him if that was his Armstrong Blanchard grinder:D
    We both had a laugh about it.
    Not the same but similar!
  3. Six Ball
    Six Ball
    from Nevada
    Oh ye of little faith. It could be done, might take a few tries. (heads) It is easier to deck the block with a belt sander.
  4. clem
    clem
    I have both metric and imperial tools, as most metric and imperial don’t interchange.
    1” equals 25.4 mm, (not 25 mm) - the rest can be worked out from there.
    The figures posted are mostly inaccurate, ballpark figures at best…….
    hopefully others don’t put too much confidence in those.
    X-cpe, Sharpone and Tow Truck Tom like this.
  5. j hansen
    j hansen
    You are not wrong,,
    Sharpone and clem like this.
  6. I didn't take a photo, but I just swapped the rear leaf spring on a Model A with ratchet straps and some square tubing. I think I'll build a real spreader tool for next time.
  7. mikhett
    mikhett
    from jackson nj
    Maroon is a nice color! ***** IS THE WORD!
    29A-V8, Tow Truck Tom and clem like this.
  8. snoc653
    snoc653
    from Iowa
    Unless you are old and a Foghorn Leghorn fan. Then the quote would be, “What a maroon!” Bugs used the maroon line as well.
    Just Gary, X-cpe, Ford52PU and 15 others like this.
  9. swade41
    swade41
    from Buffalo,NY
    When I was reading it my voice in my head instantly changed to Bugs when I read "what a maroon" LOL
    X-cpe, jet996, Sharpone and 9 others like this.
  10. Six Ball
    Six Ball
    from Nevada
    I was just looking that up but you guys were ahead of me. Wish I hadn't looked it up. It seems like so much else these days Bugs is wrapped in racism and maroon was a racist slur. So don't laugh at Bugs or you'll be a put in the hate speech box. :eek::rolleyes:
  11. atch
    atch
    Sharpone, LOST ANGEL and 56don like this.
  12. I'm planning to quit being an eraserest first chance I get, but in this case, I right away figured it was a "spell checker" error in that post and not a human error because only a maroon would ever spell it that way. :eek: :cool:
    Grumpy ole A, Sharpone and Six Ball like this.
  13. Six Ball
    Six Ball
    from Nevada
    Car guys are well aware of how spell checkers screw us up. :D
    Is there thread about that?:rolleyes:
    29A-V8, Sharpone and The Shift Wizard like this.
  14. Not in the world of Bugs Bunny!
    Sharpone, Boneyard51, lostone and 4 others like this.
  15. snoc653
    snoc653
    from Iowa
    This is why we refer to some people as ID ten Ts. Try it without spelling out ten (10) and no spaces.
  16. Fortunateson
    Fortunateson
    Not according to Bugs Bunny!
    LOST ANGEL likes this.
  17. chevyfordman
    chevyfordman
    IMG_2377.jpeg It helps to remove the bottom threads on those fine threaded fan bolts to get them started easier.
    Just Gary, 29A-V8, Sharpone and 11 others like this.
  18. RodStRace
    RodStRace
    That bottom area is a good place to dab a little anti-sieze, too.
    clem, jet996, 29A-V8 and 6 others like this.
  19. '34 Terraplane
    '34 Terraplane
    from Western PA
    Have you ever struggled to get a "torn-up" oil filter off of a vehicle? My son-in-law called me to inform me that he was in trouble getting his oil filter off and would I help him. He had tried the "puncture a screwdriver through the filter canister trick" and "the LARGE pipe wrench trick" all to no avail. When I crawled under his vehicle, all that was left of the oil filter was approximately the top 1/4 of the canister where it screws into its housing plus many thin shards of the metal canister hanging down. The filter material was completely gone and all I could see was the drain-back holes and the threaded portion of the filter still TIGHTLY attached to the filter housing. Tried "the chisel trick" on a couple of the drain holes...still NO movement. Laid under the vehicle looking and thinking and went back home and made this "tool(?)" - not the prettiest but it got the filter off !!
    The small cap cap screws went up in the filter "drain-back holes" and I locked them in place with a nut on each side of the plate. The plate has 2 slotted openings to allow variable spacing - depending on the spacing of the oil filter "drain-back holes". There's a 3/8" nut welded at the center of the plate to allow a socket on it. Oil Filher removal tool.png 20240717_140519.jpg 20240717_140718.jpg 20240723_104022.jpg
    GuyW, X-cpe, FRANKTHECRANK and 16 others like this.
  20. Gabby
    Gabby
    I had to make a similar tool to remove a small lawn mower filter. I didn't make at adjustable and want something that wouldn't bend so a cut up a Allen wrench to make the tool.
  21. Harv
    Harv
    from Sydney
    Five seconds to smear the o-ring with oil versus half a day to butcher the filter out. Taught the neighbour's kid a few new words that day.
    Cheers,
    Harv
    jet996, 61Cruiser, drdave and 7 others like this.
  22. Is that the stock filter from a grey motor??? I always have trouble finding them on my FB!
    I reckon I have changed 1000 filters in my time, but luckily have never had to resort to an axe to remove them, but thankfully there are some good tips here if I ever strike one.
    Who said canister "toilet roll" filters were no good? I never heard of anyone taking a sledge hammer to remove one of them!
  23. Harv
    Harv
    from Sydney
    My grey motors have the stock GM Holden factory oil filter. The rear main, rocker cover, engine plate and timing cover all leak oil. That leaked oil carries out any impurities, and I top the oil up routinely :D If it ain't got no oil under it, it ain't got no oil in it.
    The filter was the run-in filter from the 327 in my avatar. Built by a professional engine shop, but one that I would not go back to.
    Cheers,
    Harv
  24. RICH B
    RICH B
    Somewhere I have a piece of square tube with two pieces of round stock welded to it that would probably fit the remains of that filter.
    That was one messy oil change that day; but I won.
    Sharpone, Six Ball and Tow Truck Tom like this.
  25. j hansen
    j hansen
  26. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Over tight oil filter happens one time if you can learn from it.
    My time came one Winter Sunday afternoon.
    A 'new' delivery van that was expected on-duty Monday morn.
    Semi frozen on my back, The hammer driven chisel worked.
    Has never been called for since. Hand tight,, then, then pull back a hair.
    Once more for insurance Hand tight,, then, pull back a hair.
  27. Boneyard51
    Boneyard51
    Yous guys know Bugs Bunny turned 84 a couple of days ago…..right?
    Bones
  28. Six Ball
    Six Ball
    from Nevada
    He was just a kid when I got here! :D
  29. j hansen
    j hansen
  30. Damon777
    Damon777
    I remember the first time I performed an oil change on my very much OT diesel truck (7.3 psd). Took me quite a while to get the filter off. I think I did pierce it with a screwdriver to get it off. I was thinking what sort of gorilla tightened this thing down?! The tightening instructions are right there on the side of the pan! (No joke, they were on a factory-applied sticker right there.)
    Anyway, I get to the next oil change, and discovered that I was the gorilla this time. Dang filter was that tight again, and I followed the instructions to a T.
    That is the story on why I have a huge filter pliers in my toolbox. That was the one tool that worked easily every time.
    brEad, 29A-V8, Sharpone and 3 others like this.
