History ...
Discussion in 'The Hokey Ass Message Board' started by sgtlethargic, Jul 19, 2024.
  1. squirrel
  2. deucemac
    deucemac
    having worked in Ford dealers for many years we quickly realized that 6 cylinder Mustangs were Falcons underneath and V8 Mustangs were Fairlanes underneath, big differences in strength.
    deathrowdave likes this.
  3. gimpyshotrods
    gimpyshotrods
    My former coworker's father worked at the San Jose/Milpitas Ford ***embly Plant.
    He built my Falcon when it was new. #233 on that line in 1960.
    He remembers reading the accident reports and memos regarding the design change.
    sgtlethargic likes this.
  4. gimpyshotrods
    gimpyshotrods
    Note that says "all models".
    There is NOT a suspension distinction between 6-cylinder and V8.
    Only the spindles/brakes/steering are different.
    squirrel likes this.
  5. gimpyshotrods
    gimpyshotrods
    See post #38 for suspension details.
  6. MOONRNR
    MOONRNR
    Let's clarify a few points as this thread is going everywhere ...
    The FALCON was introduced in the 1960 model run as an econo-box. Designed and ***embled as cheaply possible. Power was the 144CI 6CYL. No undo stress on the uni-body design.
    Each year (1960/1962) there were several suspension upgrades as FORD ENGINEERING discovered design deficiencies. The big change was the suspension with the 63/ FALCON as it now offered a V8.
    The 1965/66 MUSTANG was built as an extended WB version of the FALCON platform. It used basically the same suspension/steering.
    The 1967 MUSTANG (and FALCON - incl MERC versions) was based on the new 1967 FAIRLANE platform. That is when it (MUST-FALCON) began using FAIRLANE suspension.
    Bottom line is if one wants to up-power a 1960/62 FALCON, they have to understand the car was not designed for it and one has to upgrade the suspension to handle the increased HP/TORQUE.
    There were no front torque boxes until the 1963 FALCON.
  7. gimpyshotrods
    gimpyshotrods
    Finally. Someone else has the correct information.
  8. finn
    finn
    And the torque boxes were only part of the V8 package (all body styles) plus the newly introduced hardtop and convertible six cylinder models. Six cylinder sedans didn’t get them until after 65.
    Good post .
  9. It just wasn't just the torque boxes. Ford increased the metal gauge X3 in the inner/outer rockers, frame rails, crossmembers and shock towers for the V8. There was also yet more reinforcement on the shock towers where the upper a-arms attached. The only six cylinder Falcon to get all this was the convertible, which also got additional bracing in the floor pan under the front seats. This two different 6/V8 body shells was 'normal' for the '63-65 Falcon and 64.5-66 Mustang. The Comet was one outlier; it had the two shells in '63, but in '64 Mercury dropped the 'six' shell and used the heavier-duty V8 shell for all cars to improve NVH.
    The other oddball was the wagons/Ranchero. I can't speak to the early ones, but I know the '64-65 versions equipped with the six got the same engine tub as the six cars but did have the heavier V8 frame rails and torque boxes at the rear.
    gimpyshotrods likes this.
  10. F-ONE
    F-ONE
    from Alabama
    Just to clarify further.....
    The Small Fairlane 1962-1965 has a unique suspension and it is specific to 1962-1965 Fairlanes and 1962-1963 Meteors.
    It does not interchange with Falcon, Mustang or post 1965 Fairlanes.
  11. kabinenroller
    kabinenroller
    YES! I totally agree.
    I read most of the posts and just shook my head.
    Also, my Cyclone never had a tube under the engine that mounted between the frame rails, there were no threaded inserts in the sub frame either. When I had the car on the rotisserie I installed threaded bungs so I could install a tube but later found out my headers would not clear the tube.
  12. sunbeam
    sunbeam
    I put a 221 in a 1960 falcon Ia got the Falcon used with 40000 miles replaced all greaseable front end parts from lack of service and drove the car to 120000 miles with regular 3000 mile service no issues.
  13. MOONRNR
    MOONRNR
    Actually the MERC METEOR used a slightly different front suspension than its' FORD brother.
  14. MOONRNR
    MOONRNR
    Now let me ask you a question and it is in no way trying to insult you, only answering a question for myself.
    Have you determined your COMET is a true CYCLONE and it came through with a V8?
    Without that tube, engine torque will twist the lower rails and reek havoc on the aprons after a while.
    It seems to me I remember early FALCONS w/o the tube, but my memory (76) is fast fading as once did my *** life.
  15. MOONRNR
    MOONRNR
    There you go. Surprising what a grease gun can do.
    I remember when FORD put plugs in replacing the fittings. That and a 6000 mile oil change and no need for a trans service.
  16. kabinenroller
    kabinenroller
    Well lets see, I have owned my Cyclone for 56 years so if it is a fake I guess I would know it. Also, my family operated a Mercury dealership so I am quite familiar with most Mercury models. A Cyclone is no different from a V8 Caliente mechanical wise. Who in their right mind would weld up all the trim holes along both sides of a non Cyclone so it would look like a Cyclone?
  17. gimpyshotrods
    gimpyshotrods
    Yup.
    My only concerns with the original suspension is the upper ball joints, and the expensive obsolete other parts, if you can even find them.
    That's why I provided the information to move you on to cheaper and more available parts.
    LWEL9226, Budget36 and finn like this.
  18. I've never seen a '63-65 Falcon/Comet, V8 or six, with an OEM lower crossmember under the motor. You can get an aftermarket one however that attaches with the lower motor mount bolts. Well worth the investment IMO (along with a strut tower brace).
  19. MOONRNR
    MOONRNR
    You misunderstand. It is not whether the car has a six or eight, but whether it can withstand a high HP/TORQUE ENGINE (6 or 8) without the cross-member. I know I have seen the delete as I worked on them fairly new.
    You are fine.
  20. MOONRNR
    MOONRNR
    You actually saw all that rolled off the ***embly line(s)?
    WOW!
  21. No, of course not. Did you?
    I've personally owned a 1/2 dozen of these, knew another 1/2 dozen owned by guys I knew, and looked at a couple of dozen or so in the boneyards when scrounging for parts. No crossmembers on any of 'em...
    You're not the first guy to make this claim which is why I looked for one, but I have yet to see any proof. No mention in any Ford literature or on any exploded diagrams. And the most powerful motor available to the general public (excluding the Daytona specials, B/FX cars, and the Ford of Canada HiPo Falcons) was only the 215HP 4V 289 offered in the '64-65 Comet, so there really wasn't a need.
    winr, 57 Fargo and kabinenroller like this.
  22. MOONRNR
    MOONRNR
    What claim have I made? I was merely surprised that you saw so many examples.
    I thought you may have been a plant supervisor.
  23. MOONRNR
    MOONRNR
    Why are you yelling at me?
    All I asked is if the COMET has been numbers verified in a what I thought was a polite manner. You did not state that you have had the car for 56 years.
    I merely asked as you said there was no cross-member or captured nuts in the rails.
    I am just trying to establish whether/which cars were ***embled with/without the cross-member.
    It seems FORD used two style ***embly rails, those with and without captured nuts.
    You either need a CALGON MINUTE or a MIDOL.
    ... sheesh ...
  24. Budget36
    Budget36
    Yelling? I didn’t notice anything in all caps, except in your reply.
  25. kabinenroller
    kabinenroller
    I did not yell, ( all cap’s) I politely stated facts.
    I do not claim to know everything about these cars and the same theory should be shared by everyone.
    There is no place for insults on this or any other forum.
    (Last words in your comment)
    Budget36 and alanp561 like this.
  26. MOONRNR
    MOONRNR
    I guess politeness is defined as how one was raised.
    alanp561 likes this.
  27. MOONRNR
    MOONRNR
  28. 55blacktie
    55blacktie
    I think it's time to move on.
    Budget36 and kabinenroller like this.
  29. MOONRNR
    MOONRNR
    Are you trying to run this FORUM also?
    If the thread upsets you, use the IGNORE FEATURE.
  30. gimpyshotrods
    gimpyshotrods
    My family and I have collective owned 13 1960-1963 Falcons.
    Every single one, including mine, which was Falcon #233 down the line at San Jose/Milpitas in 1960, had a crossmember.
    The clutch fork return spring attaches to it.
    My former coworker's father was on the line the day and shift my car was ***embled. He was at the factory until the 1970's.
    He says every single one that they sent down the line had a crossmember, at least then, 6-cylinder and V8.
