Technical Aluminum T bucket frame
Discussion in 'The Hokey Ass Message Board' started by Rand Man, Jul 23, 2024.
  1. Rand Man
    Rand Man
    Is anyone familiar with these aluminum T bucket frames? The previous owner told me he had heard it was manufactured somewhere around Houston. It looks to be high-quality. It looks strong, but is unbelievably light. IMG_7321.jpeg IMG_7320.jpeg
  2. Rand Man
    Rand Man
    I guess my main question is do I need specific components like radius, rods?. I think I could probably buy universal hairpin kits and build my own; should be fairly straightforward.
    lothiandon1940 likes this.
  3. Marty Strode
    Marty Strode
    I rode in a T with an aluminum frame, powered by a healthy flathead. It was the wildest sensation, felt like it was going to crawl out from under you, had so much flex. I didn't bother to look under it, to see how it was designed.
  4. Rand Man
    Rand Man
    Thanks, Marty. I was afraid of that. My son is a good fabricator. I think I can come up with some clever reinforcements.
  5. mad mikey
    mad mikey
    I do not know about using it. Marty knows better brother. What ever you decide to do , do your research.
    lothiandon1940, hrm2k and Rand Man like this.
  6. metlmunchr
    metlmunchr
    Yeah, if you built the aluminum frame as a copy of the tube sizes and wall thicknesses of a steel frame, the result would flex 3X as much as a steel one for the same loads.
  7. Rand Man
    Rand Man
    Yeah, I understand. I’ve had this idea for a long time that I wanted to build a reinforced aluminum floor pan that would tie it all together. Kinda like the way a bug body fits on to their frame pan, not exactly, but there will be a hint of that, combining the trans tunnel and everything. This is not my top priority project, just one of those bucket list things.
  8. pirate
    pirate
    from Alabama
    It would be interesting to know the aluminum alloy of the tubing used and also the wall thickness. There appears to be a lot of things still needed to be welded to the frame. Motor mounts, trans mounts, brackets for connecting the front and rear suspension additional cross members, etc. Depending on the alloy the completed frame may need to be solution heat treated and aged to eliminate potential cracks from flexing. Some aluminum alloys don’t require heat treatment at all even after welding, hence would be good to know alloy. Wall thickness is a factor if you intend to drill and tap the frame to bolt components to it as aluminum threads would not be as strong as steel. Wall thickness of course is a factor of flex as well as strength.
    Certainly an aluminum frame ups the “cool factor” and probably would cut the weight of the frame by at least half. However, T Bucket frames probably don’t weight that much anyway. Your mileage may vary.
    mad mikey, lothiandon1940 and hrm2k like this.
  9. Mr48chev
    I'd be at least thinking of building a K member for the trans mount crossmember.
    If it were me I'd be thinking T modified with a small 4 banger. Something in the 800/1600 cc range.
  10. jaracer
    jaracer
    Back in the 70's a guy out of Ohio built a sprint car frame out of aluminum. It was very light and fast. However, the aluminum started to work harden and they retired it at the end of the season. I seem to remember the remark was made that it was good it never got upside down.
  11. slayer
    slayer
    How about using a 215 Olds Aluminum V8 instead of a flathead?
    WC145, X-cpe, duecesteve and 4 others like this.
  12. Marty Strode
    Marty Strode
    Rodney Singer and Karol Miller won the '59 Nationals with this Dragster, the frame was aluminum, and bolted together. But with the stress and twisting of a ch***is for the highway over time, would be far different. For something light, I would choose thin wall Chromoly steel, like is used in aircraft.
  13. Marty Strode
    Marty Strode
    It would certainly be light !
    slayer, mad mikey, catdad49 and 2 others like this.
  14. Shades of Doug Nash....
    mad mikey and Rand Man like this.
  15. Rand Man
    Rand Man
    Yeah, I’m hoping an old timer might remember who manufactured them it doesn’t look homemade. I agree with keeping it light. The Buick is a great idea. I’ve always liked them. The design became the Rover V8, so the equivalent should be easy to find.
    catdad49 and lothiandon1940 like this.
  16. Marty Strode
    Marty Strode
    I have a complete 215 Buick and 5 speed along with most of an Olds equivalent, waiting to go into a Simca 5/ Fiat Topolino. They are a nice little package.
    lumpy 63, Anderson, mad mikey and 4 others like this.
  17. Unkl Ian
    Unkl Ian
    I'm surprised it lasted that long.
  18. Unkl Ian
    Unkl Ian
    Yes, absolutely, the engineering is pretty straight forward.
    Compare Young's Modulus and Yield Strength. Not incredibly difficult.
    An aluminum frame would have to be more substantial, the same way
    that Aluminum rods are more substantial compared to steel.
  19. chevy57dude
    chevy57dude
    That is going to look so cool when you polish it!
  20. Jmountainjr
    Jmountainjr
    I have kept tabs on T bucket kits and components since the late '70s. It's likely I missed some, but never saw an aluminum frame offering. As I look at the frame it has more of a homemade vibe than a production unit. I hope you are able to track down the history.
  21. Rand Man
    Rand Man
    Well, if nothing else, it might be an interesting wall hanger.
    mad mikey likes this.
  22. GTS225
    GTS225
    And, ,IMO, that's exactly what it should be.
    I'm a bit on the conservative side, so there's absolutely no way I'd use that on the street. As was mentioned.....it would work harden from the flexing in relatively short order, and start to crack, if not give way entirely, and dramatically.
    Now, a trailer queen show car, with a polished (or even color anodized) ally frame and polished aluminum 215.......that would be an eye-catcher.
    Roger
    Unkl Ian likes this.
  23. Rand Man
    Rand Man
    My first thought was to buy this complete set up from a wrecked car, have something quick, cheap and easy. I’m not the biggest fan of these 70s style itty-bitty excuse for a pick up box. Might switch this to a turtle deck. IMG_7324.jpeg
    chevy57dude, slayer and mad mikey like this.
  24. 1971BB427
    1971BB427
    from Oregon
    From the lack of crossmembers, or brackets it appears to have never been used before?
    I think your idea of a heavy gauge floor pan might make it more rigid and help. Crossmembers for engine, trans, and rear axle will also help, but will likely require some bracketry welded into the frame rails to bolt in steel crossmembers to. Hope you're setup to do some aluminum welding!
    Rand Man likes this.
  25. big john d
    big john d
    from ma
    triump tr8 also
  26. Tim
    Tim
    from KCMO
    I think @BigJoeArt still has a few small aluminum v8’s for sale.
    with work hardening etc I wonder if
    You don’t go the other direction and not try to make it ridgid. A stock A frame is flexy on purpose. Kept it light and low hp
    and let it keep some flex and maybe it won’t have many points to really harden?
  27. Rand Man
    Rand Man
    Truth is, if I built a T, I would like it a little more like this. This aluminum frame might not be right for that in the first place. This one had a V8 60 hidden under that hood. Might be peppy with it being very light. I could probably find an appropriate for banger to put in there.
    IMG_7307.jpeg IMG_7305.jpeg IMG_7306.jpeg IMG_7304.jpeg IMG_7303.jpeg IMG_7302.jpeg IMG_7301.jpeg
    GuyW, WC145, cactus1 and 3 others like this.
  28. Malcolm
    Malcolm
    from Nebraska
    I'd also be concerned about work hardening and stress cracks. Don't aluminum trailers have a limited lifespan due to the same thing?
  29. swade41
    swade41
    from Buffalo,NY
    Didn't Lil' John ****era build an all aluminum car that he crossed the U.S. in ?
    I want to think the article in Street Rodder magazine said he had to do some repairs along the way due to work hardening.
    Rand Man and mad mikey like this.
  30. Rand Man
    Rand Man
    Yeah, I kept a subscription to Street Rodder back then and I do remember that article. I’ve had aluminum boat trailers and they seem to be really well built and long lasting My son is the welder. I haven’t asked him about this yet. If he doesn’t wanna mess with it it probably won’t get done.
    Martin72 and swade41 like this.
