Hot Rods Let's see your headers. Custom built only
Discussion in 'The Hokey Ass Message Board' started by Frames, Jul 19, 2024.
  1. Marty Strode
    Marty Strode
    Oh yeah, this is my first and second set of headers from nearly 60 years ago. 2012-07-19 105309.jpg 2012-07-19 113420.jpg
    slayer, jet996, Blown Red Ram and 5 others like this.
  2. 6sally6
    6sally6
    Loving the brick and plywood bracing !!!
    6sally6
    deathrowdave, Just Gary and X-cpe like this.
  3. Andyman
    Andyman
    314299C8-9B58-4F24-AF53-EE743D1B4C06.jpeg EAA2BA55-84E2-4D2D-A380-E5B57507B97F.jpeg B1961621-5B39-432C-8D7E-C08EE1C8FC95.jpeg 314299C8-9B58-4F24-AF53-EE743D1B4C06.jpeg EAA2BA55-84E2-4D2D-A380-E5B57507B97F.jpeg B1961621-5B39-432C-8D7E-C08EE1C8FC95.jpeg Here is what I made for my Mercury Speedster
    andy
    jet996, whtbaron, Just Gary and 5 others like this.
  4. wheeltramp brian
    wheeltramp brian
    20231130_084822.jpg 20231130_084833.jpg 20240722_120320.jpg 20240722_120340.jpg Small block Ford in a model A
    2devilles, jet996, akoutlaw and 6 others like this.
  5. earlymopar
    earlymopar
    Pictures of pictures so the picture quality and clarity are not great. These were my first headers made for a 37' Dodge pickup with 340. What a blast to fabricate but the best part for me was having Russ Meeks (very kindly) tell me they were the best fabricated headers he had ever seen from a someone not tied to the business.
    First 2 pictures are during fabrication. The last are of completed headers and one with coating.
    Thanks for your help Russ!
    slayer, jet996, Fitty Toomuch and 6 others like this.
  6. patsurf
    patsurf
    any of those snakes bite you?
    Pist-n-Broke likes this.
  7. willys36
    willys36
    Your album is still there trust me. You just put it somewhere you were sure you could find it!
    dana barlow likes this.
  8. Jacksmith
    Jacksmith
    from Aridzona
    Kelly Burns likes this.
  9. Frames
    Frames
  10. Frames
    Frames
    The wedge I used about 50 years ago. I just drove it into 18 gauge tubing with a B F H. I did not use a wedge on the 16 gauge tubing I am using on the 365 Cadillac engine. I just hammered the ends 2024-07-24 10.07.49.jpg square. I did not want to enlarge the end.
  11. Marty, I would say your skill level has improved by leaps and bounds. My first set was similar but stick welded and looked so bad I couldn't bear to take a photo; however, they did do the job. They were on a 57 Caddy motor set in a 57 Ford truck. That was back in 1960. I was just cutting my teeth and well on my way to trouble.
  12. "Wally"
    "Wally"
    304.jpg Left side in our D/BGRMR Bonneville car. 350 sbc bored .020 over and destroked to 304 (to be under 305.9 D cl***)
    jet996, Blown Red Ram, X-cpe and 3 others like this.
  13. lumpy 63
    lumpy 63
    57584.jpeg 57583.jpeg I can't take credit but my friend Scott built these on my Vette.
    slayer, jet996, Just Gary and 2 others like this.
  14. 05snopro440
    05snopro440
    -Brent- likes this.
  15. 05snopro440
    05snopro440
  16. Marty Strode
    Marty Strode
    Mike that first set was built out of old tailpipes I found out behind a gas station !
  17. Marty Strode
    Marty Strode
    I built this first set for a buddy Jimmy's 32 sedan, 392" Windsor. Then I built a set of outside ones for a Model A with a Hemi. Well, Jimmy just had to have a set like that, so I built these. IMG_0856.JPG IMG_0860.JPG IMG_2820.JPG IMG_2821.JPG IMG_2826.JPG IMG_2844.JPG IMG_3285.JPG
    Tim, slayer, osage orange and 14 others like this.
  18. RICH B
    RICH B
    Long ago I cut up a set of late model headers and re***embled them to fit a '33 I had; not totally home built; but almost so.
    Picked up some flanges and bends at Headers by Ed's shop along with 4" truck stack parts and built some pipes for a T bucket I built a while back. Later my son acquired them from a later owner and used them on his T bucket with different mufflers.
    I made a set of headers for my '47 using more parts from Ed.
    Made a set of lake style headers using flanges and cones from Speedway for another T-bucket I had.
    Tim, 2devilles, jet996 and 2 others like this.
  19. RICH B
    RICH B
    I almost forgot to add the headers I built for the 396 in my friend's '29 cabriolet; lon long ago. More Headers by Ed's parts.
    jet996 likes this.
  20. Marty Strode
    Marty Strode
    Rich, is Ed still in business ? I bought a set of FE flanges and starter tubes nearly 20 years ago from him.
    Moriarity and Just Gary like this.
  21. @RatPwrd built these for my buddy’s 56 Sedan, BBC with raised exhaust port heads. 2-1/8” stepped to 2-1/4” primaries. Steering box was angle milled for more clearance but #5 had to be m***aged to fit and #7 & #8 had to snake over the outside of the frame rails to fit under the inner fenders. Everything ended up under the car and above the bottom of the frame. He said they were one of the hardest set of headers he ever built. Absolute works of metal art!
    6B854948-FB4A-4FE3-A6DA-AD180F4706FB.jpeg A306C9CD-07E4-423D-8F1D-643C382D2F78.jpeg 76D51E87-3CF0-42E3-BCC7-300BFE6B6939.jpeg 52FC2D0D-D6B3-432E-A59E-497B75053A5D.jpeg 75EA05DA-3434-44FE-8B5E-D9FB1A641213.jpeg
    Now they’re getting coated, almost a shame to cover up all those beautiful welds!
  22. Marty Strode
    Marty Strode
    Very nice !
    RatPwrd and SilverJimmy like this.
  23. Flatrod17
    Flatrod17
    Found some pictures of the first set of headers I ever made. 55 big block Chevy. I had no clue what I was doing! 55 headers.jpg
  24. Frames
    Frames
    Some really nice looking headers here. I've built quite a few custom headers in my day. None built time and material. Customer always wanted a price. Thinking I'm superman I quoted too cheap a price. Bet I lost my *** on every set. This set is pretty simple. I used Speedways combo pipes. Only one joint at the bottom. Can't believe how long it took. Can't be old age. I'm only 89. 2024-11-02 21.48.06.jpg
    brandon, slayer, osage orange and 7 others like this.
  25. Frames
    Frames
    My first set of headers. 1963. E W R A rules. No engines later than 1952. Don't remember how I got 4 pipes on 3 port 52 Olds heads. img077.jpg .
  26. Marty Strode
    Marty Strode
    They look chrome plated !
    RICH B likes this.
  27. 2devilles
    2devilles
    Nothing fancy compared to some of these beauties, but 2" primaries on my 552".
    jet996, Kelly Burns, loudbang and 2 others like this.
  28. Frames
    Frames
    1963. Living in Fond du Lac, Wisconsin. Don't believe there was a chrome plating shop., but it looks like I had the headers chrome plated. 1965. Moved to Milwaukee. Everyone ran zoomies. I got away from that. Saved the drivers hearing a little bit. img023.jpg
    slayer, jet996, Kelly Burns and 3 others like this.
  29. chopolds
    chopolds
    from howell, nj
    Not entirely from scratch. Some Ebay stainless headers for a 455, going in my 56 Olds. Cut them apart, so the farthest from each other, firing cylinders were paired up. 2 into 1 collectors. So 4 pipes. Cut apart 4 Brockman Mellowtones, so the tubes were closer together, welded in 198.JPG 205.JPG 208.JPG 216.JPG 218.JPG separator plates, with flanges to make installation easier. 2 pipes into 2 mufflers, on each side. Then 4 tailpipes. It was an experiment that took a long time to do, but it does sound amazing!
    Tim, slayer, jet996 and 2 others like this.
  30. Maybe you did something like I did on my Siamese center port Pontiac motor.
    2devilles and jet996 like this.
