Projects Removing a brass fitting
Discussion in 'The Hokey Ass Message Board' started by IowaTom, Jul 25, 2024.
  1. IowaTom
    IowaTom
    Gang - This fitting has been in place since '52 and does not want to come out with my 7-16ths wrench. It's at the end of an oil galley and feeds my partial flow filter. I've been dripping Kroil where it goes into the block, but I fear I could twist off half of it if I'm not careful. My 13mm socket is the tightest but it slips over the soft metal edges. Any ideas? Thanks much!
    Unkl Ian likes this.
  2. Marty Strode
    Marty Strode
    Maybe a heat gun, and more Kroil, would help.
  3. Does a 3/8" drive extension slip over it? Heat the cast iron around it with a torch and use a wrench on the extension.
  4. gimpyshotrods
    gimpyshotrods
    If that is for a flared line, get a tube nut that fits the threads an put it in the hole before trying to remove it.
    It will help prevent distortion.
  5. Doublepumper
    Doublepumper
    from OR-WA, USA
    May have some thread sealer on it, some light heat around the fitting would help soften it.
    One of these sockets would take it out. It works great for things like this.
    Good luck!
    '28phonebooth, Tim and Tow Truck Tom like this.
    Buy a pipe plug socket , bought this set for something stupid I was working on. Does me well on those lonely nights at sea !
    if you do snap the head off a drill bit with grease on it and drive it slowly into the br*** will drill it out real easy and the shavings will stick to the grease
    1940Willys, Cosmo49, SDS and 6 others like this.
  7. IowaTom
    IowaTom
    Great stuff. Thanks all!
  8. Unkl Ian
    Unkl Ian
    Heat the block.
    Cutting Torch, or Rose Bud.
    Propane/MAPP torch if you have to.
    Not your daughters hair drier.
    29A-V8, Okie Pete, bobss396 and 2 others like this.
  9. '29 Gizmo
    '29 Gizmo
    from UK
    Grind a slot in it and use an impact wrench with a large screwdriver bit in it
    bobss396, VANDENPLAS, IowaTom and 2 others like this.
  10. RmK57
    RmK57
    Like mentioned, heat the block and use vice grips. Should come out easy.
    CSPIDY, Okie Pete, warbird1 and 4 others like this.
  11. PackardV8
    PackardV8
    From here, that appears to be a Weatherhead fitting. You mean you don't have the appropriate Weatherhead socket?
    jack vines
    down-the-road, das858, rod1 and 4 others like this.
  12. Jeff34
    Jeff34
    I'd probably try the 3/8 extension or maybe an extractor...
    You might also use a stud remover (not the cam style, the collet style)
    29A-V8 likes this.
  13. TCTND
    TCTND
    Heat the fitting pretty hot, not the block. Let it cool and take it out
    das858, tb33anda3rd, 29A-V8 and 3 others like this.
  14. chicken
    chicken
    from Kansas
    This is a good method...and a couple sharp swats straight in towards the block with about a 16 oz hammer will help as well.
    elgringo71 and 29A-V8 like this.
  15. winduptoy
    winduptoy
    Agree with installing the fitting into it...then try to tighten it slightly before loosening it.
    it is br***, so don't get too carried away with torch heat if you go that route... and watch out for hot oil burping out of it
  16. It’s a br*** fitting, I wouldn’t use heat on it, if it were steel that would be different.
    Warm the block around it while putting firm pressure on it to undo and it should come free.
    As said, also screw the line fitting into it, that will stop it from distorting when undoing.
    IMHO.
  17. bobss396
    bobss396
    Maybe a couple of heat-cool cycles. This has worked for me more than once.
  18. spanners
    spanners
    Br*** is hot-short if I remember correctly which means if you heat the fitting it will snap.
    SDS, Barrelnose pickup and Unkl Ian like this.
  19. Looks like a 90 deg fitting, steel line screws in top left where we can't see? Find a new replacement first, and then you have some more leeway, if you damage this one coming out.
    5window likes this.
  20. 8 point sockets, I have my grandfathers set. They're a must for square headed bolts (and fill plugs).
    clem, RDR, deathrowdave and 2 others like this.
  21. pirate
    pirate
    from Alabama
    I would take a flat chuck of steel or flat punch bigger than fitting head and give it a good firm hit a couple of times. Sometimes that will loosen the fitting enough so you can back it out. Then as someone else said try to tighten the fitting just enough to get it to move then rock it back and forth adding lubricant until it comes out. I would not add heat directly to the fitting. Br*** anneals and gets softer at relatively low temperatures and a softer fitting will twist off more easily.
  22. Unkl Ian
    Unkl Ian
    It is.
    But how many people here know what hot-short means ?
    Bob Lowry and gimpyshotrods like this.
  23. mohr hp
    mohr hp
    from Georgia
    Do tell?
  24. gimpyshotrods
    gimpyshotrods
    I do.
  25. Okie Pete
    Okie Pete
    A old oil field hand once told me . Heat , forceful persuasion and don’t give up when removing stubborn things . While applying heat put wax where the piece screws in . This will provide lubrication as it will melt into the threads.
    deathrowdave likes this.
  26. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    As was mentioned just put heat on the block not the fitting. If that is a 90-degree fitting put a plug in to fill the void. Then before you try to unscrew it try to tighten it. Whatever you do don't break it off. If you cannot get it out leave it, just make sure the hole is filled.
    bobss396, 29A-V8 and Unkl Ian like this.
  27. Sharpone
    Sharpone
    @mohr hp It gets 'hot short' - meaning that it's got a tenancy to crumble if you hot work it at the wrong temperature.
    Dan
    hotrodharry2, 29A-V8 and Unkl Ian like this.
  28. Sharpone
    Sharpone
    Br*** anneals also, usually heat to high temp and then quench in water without the quench I believe the br*** is somewhat brittle. With all that being said I wouldn’t heat the fitting. If you could get a good grip on the fitting and tap fairly lightly with a hammer it may come loose. Like sated above install a plug to keep from distorting.Does the fitting appear to have a sealant? Some sealants Recto Seal comes to mind set up hard with time. Hopefully not Loc***e red, red takes heat to break loose usually.
    Dan
  29. Unkl Ian
    Unkl Ian
    400F
    IIRC.
  30. Sharpone
    Sharpone
    I don’t think 400 F will harm the br*** but not sure
    Dan
