Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. swade41
    swade41
    from Buffalo,NY
    Took the J down to the local truck stop certified scales, guaranteed plus/minus to 20 lbs, little heavier than I wanted because it gained 190 lbs with all the changes.
  2. atch
    atch
    Wow. I sure thought it would be lighter than that.
    enloe likes this.
  3. swade41
    swade41
    from Buffalo,NY
    It was 2410 when I weighed it at the track in 2013, who knows if they were accurate though. I had weighed it there in 2012 when it was all steel and flat black and it weighed 2400, so it gained 10 pounds by going to a gl*** nose, doors and a paint job. Lol
    Stock they weighed 2341 with the 4 cyl.
  4. fastcar1953
    fastcar1953
    Getting the Nova ready to show to the public. 449437074_8197682396922641_1594054566845093233_n.jpg 449439556_8197683363589211_6075546632892683070_n.jpg 449443792_8197683773589170_6360199659834232259_n.jpg 449487014_8197689563588591_2650990422720969442_n.jpg 449531919_8197684173589130_5731759453572071862_n.jpg 449792161_8197684646922416_3334897836403534514_n.jpg
  5. atch
    atch
  6. fastcar1953
    fastcar1953
    @atch Yes just don't look real close. It's like a prop car for t.v.. A lot of stuff is just on the car for looks. Hood not bolted down. carpet not finished . Hell the shifter isn't even hooked to transmission.
    It does run and drive just start in gear and go. :D:D
    427 sleeper and 61Cruiser like this.
  7. 61Cruiser
    61Cruiser
    fastcar1953 likes this.
  8. Bandit Billy
    Bandit Billy
  9. John B
    John B
    Just before we took off to Ohio for the weekend I decided to touch up my 49. The previous owner had repaired some spits and could never get the paint matched back to an acceptable shade. So he just re-primered it. My Kentucky paint guy just happens to be better than whoever he used in WV.
    I had him put some in a spray can and it sprayed out fine. I think after a little wetsanding and some buffing it will be just good enough.
  10. choptop40
    choptop40
    Man , gotta get some time off from work......You hoodlums are havin too much fun
    saltflats likes this.
  11. pila38
    pila38
    Ch***is is ready for the road. Messed up and set one shock wrong, so it’s sitting a bit ****eyed. Working on cleaning up the cab now for primer and lizard skin.
    enloe, saltflats, lumpy 63 and 10 others like this.
  12. Almostdone
    Almostdone
    Working through some ‘almost’ overheating issues with the Model A (avatar). Driving to LARS last month it got to 230 degrees climbing hills near Mohave, CA in near-100 degree heat. I made it home ok because we travelled along the coast, but that aggression won’t stand.
    Electric fan takes care of it at slow speeds, but it gets hot while cruising in hot weather, which usually equals airflow problem. I took advantage of our recent near-100 degree weather and drove a hilly route with the electric fan removed (better, but not the holy grail), then without the fan shroud (improved, but no). Got home and flushed 10,000 miles of bugs from the AC condenser and radiator and checked the timing for the heck of it. Flippin’ thing had 17 degrees initial! Got that corrected and took drive with the AC on ‘blizzard’ up to our local Cascade Range mountain at 96 degrees….. mostly stayed between 190-210, so that’s that. I had the distributor out this spring and the wife must have reinstalled it with the wrong timing.
    Giddyup,
    John
  13. alanp561
    alanp561
    I've been on the lookout for a '46 -'48 Merc radio speaker cover for a couple of years now. A few days ago, this pops up on EvilBay with a starting bid of $50. Someone had made a 3D print of an original cover and it looked right in the pictures. There was even the stainless screen that goes behind it. It needs to be lightly sanded to remove the flash and then painted to match the speedometer and clock faces in the more door Merc. There were three days left on the bidding, so I waited until the last day and checked in again. Same $50 bid and 9 hours left on the auction. With 45 minutes left, I raised a dollar. Whoever I was bidding against had an automatic bid going on and now the bid was $52. I tried $53, he bid $54. This went on for a few minutes until I figured out his max was $70. I waited until there was a minute left and bid $73. He didn't come back, but I held my breath until the time ran out.
    Now, I know right after I post this, there's going to be someone come back and tell me that if he had only known, he has one hanging on his wall and I could have had it for X amount of dollars. This one will work very well, I'm sure.
    29A-V8, chevy57dude, enloe and 6 others like this.
  14. 57 Fargo
    57 Fargo
    Planning a road trip with the little Barracuda, figured since it has 4.56s in the rear end I would throw a little more highway friendly gear in it, put together a one legger with 3.55s in it. Pulled the old center section out of the car and found this…. IMG_5655.jpeg
    Ring gear bolts were finger tight, good thing I decided to change them, explains the gear noise I suppose.
  15. BJR
    BJR
    Getting stuff ready for the Iola swap meet. Space BH80
    29A-V8, chevy57dude, enloe and 8 others like this.
  16. rattlecanrods
    rattlecanrods
    Been fighting the brake system for weeks. After replacing half the system I was having issues bleeding.
    Not wanting to throw money at a dual master pressure bleeder I decided to try lifting the driver's side only so that the front and back caliper bleed screws were the high points.
    Worked like a charm! Used a stick to hold the pedal down after pumping and dove under to crack the bleeders. Took a while but finally got a firm pedal! 20240703_212213.jpg
    das858, enloe, osage orange and 8 others like this.
  17. 57 Fargo
    57 Fargo
    Drove the little Barracuda 400 miles to Wetaskiwin Alberta, “the ultimate car show” happens here tomorrow at the Reynolds museum. They expect over 600 cars.
    das858, alanp561, enloe and 6 others like this.
  18. deathrowdave
    deathrowdave
    from NKy
    OT but repainting one of my tractors
    enloe and Truckdoctor Andy like this.
  19. 51504bat
    51504bat
    Not OT, It's a 4x4 powered mobile engine hoist.:cool:
    29A-V8, enloe, firstinsteele and 3 others like this.
  20. 67drake
    67drake
    from Muscoda WI
    IMG_2079.jpeg Getting ready to pull the engine on my ‘63 Pontiac. Lots of oil leaks, and detonation at WOT. Tried everything else to get rid of detonation, so gonna pull engine and see what’s in there. Previous owner thought it was a 400 out of a ‘73 Pontiac, so it would have been a smog era low compression ratio. In reality I decoded it as a ‘69 400 with 10:1 CR. So maybe the dufus threw an inappropriate cam in there to build cylinder pressure like a lot of CompCams are ground. I’ll find out soon enough.
    29A-V8, chevy57dude, alanp561 and 2 others like this.
  21. swade41
    swade41
    from Buffalo,NY
    Tried something different on my meat slicer pedals, couple grooves with a drill bit in the drill press, I like it better.
    Screenshot_20240720_211404_Gallery.jpg 20240719_204628.jpg 20240720_163932.jpg
    29A-V8, enloe, guthriesmith and 8 others like this.
  22. lumpy 63
    lumpy 63
    Didn't take any pics , but fired up the 327 4 bolt I built for a 30 sedan today. 69 350 block with a steel Lg journal 327 crank , Aftermarket aluminum heads with a Hyd. roller. Fired up and ran great. Just a side note... I only use Isky Hydraulic roller lifters period anymore.
    29A-V8, chevy57dude, enloe and 10 others like this.
  23. atch
    atch
    Put a new starter in Clarence today. Now it actually starts. Took sweetie to supper in it and it started/ran flawlessly. When we put the crate 350 in a few years ago we reused the old 283 starter and distributer, both of which gave up the ghost recently. Should have put a new starter on it then. Silly me, I thought that distributors lasted forever if you kept points and rotors in them. The distributor gave up 400 miles from home with no tools on board. The hot rod shop I had it towed to installed an HEI instead of a new points distributor. I had told them to just do whatever it took to get me home. That's what that shop uses nowadays so that's what they put in (they build street rods and muscle cars). I have several sbc distributors. I'll probably pick the best one of them this winter and go back to points. At least the HEI is black and because the air cleaner is pretty large you don't really see it unless you're looking for it.
  24. 26 T Ford RPU
    26 T Ford RPU
    Got the fairing adjusted on the Belly Tank project. Have never worked with fiber gl*** before.... i think i may learn a lot very soon.:rolleyes: JW
    29A-V8, 34 GAZ, saltflats and 9 others like this.
  25. lumpy 63
    lumpy 63
    20240721_143715.jpg Dropped the 327 in the A to test fit headers and steering . Mark, I just realized you can see a little suspension in there...delete if you wish.
  26. hrm2k
    hrm2k
    Got my headlights and running / turn signal in place IMG_6526.jpeg IMG_6525.jpeg
  27. choptop40
    choptop40
    Test fitting the GM column.. looks ok. Might wanna go with key on dashboard .. 2184EA42-AC9C-4A1C-93BD-2BD3B867682B.jpeg
    saltflats, hrm2k and deathrowdave like this.
  28. earlymopar
    earlymopar
    Correcting my intake manifold angle to (vastly) improve the seal. This was a Weiand prototype or pre-production sand-casting that was very crude (none of the text and graphics seen on the production manifolds were on mine). The flange was out of flat by .060" although the flange angle itself wasn't far off.
    29A-V8, rod1, chevy57dude and 8 others like this.
  29. Hubnut
    Hubnut
    20240225_153805.jpg Recently finished up putting this one back together for a good friend.
  30. fourspd2quad
    fourspd2quad
    The painstakingly slow process of prepping my louvered trunk lid for paint.:rolleyes:
