Technical SBC 350 Getting Hot on Highway
Discussion in 'The Hokey Ass Message Board' started by Goob333, Jul 23, 2024.
  1. Unkl Ian
    Unkl Ian
    How would that be possible ? The coolant return on the SBC, is the upper rad hose.
    The water pump pushes the coolant into the motor. How could it byp*** ?
  2. VI Lonewolf
    VI Lonewolf
    Anyone using an afr gauge will notice that the readings are not good data until these temps.
    MAD MIKE, Unkl Ian and gimpyshotrods like this.
  3. '49 Ford Coupe
    '49 Ford Coupe
    Also, looking at the pic in post #117, I'm wondering if there is a seal between the top of the radiator bulkhead and the hood?
    GlassThamesDoug and Unkl Ian like this.
  4. 05snopro440
    05snopro440
    Not on a 61 Impala. There are tons of places for air to byp*** the radiator if the path through the radiator is too difficult to push air through.
  5. gimpyshotrods
    gimpyshotrods
    Correct.
    Unkl Ian likes this.
  6. '49 Ford Coupe
    '49 Ford Coupe
    BINGO!
  7. Unkl Ian
    Unkl Ian
    Has anyone ever seen an external byp*** on a SBC ? I haven't.
    427 sleeper and 2OLD2FAST like this.
  8. 05snopro440
    05snopro440
    None of my 4 have it.
  9. blue 49
    blue 49
    from Iowa
    Fuelie Corvettes have a external byp*** hose.
    Gary
    ekimneirbo likes this.
  10. jimmy six
    jimmy six
    If you’re concerned about all or most of the air flowing thru the radiator, in 1955-56 Fords used a metal shield mounted on the radiator support with a rubber seal to the hood. It was missing from mine and I found one. It defiantly helped with the cooling and ma help with your problem also.
  11. Unkl Ian
    Unkl Ian
    Got it, thanks.
  12. 05snopro440
    05snopro440
    I've seen these filler panels (also pictured below) for various X-frame chevies but haven't used them. Regardless, I think the fan shroud design is causing a lot of his issue.
    MAD MIKE and 2FORCEFULL like this.
  13. Ditch the electric fans and shroud and go with a 6 blade factory style engine driven fan, also increase the radiator size height, width, and thickness the more cores in the radiator the better 2, 3, rows is not enough, you need 4, to 6 core rows.. lastly use a seperate trans cooler that's not part of the radiator and not mounted on the radiator, put ot below or to the side out of radiator air flow.. What you have now will never run cool.
    jimmy six, Unkl Ian and SDS like this.
  14. SDS
    SDS
    Just as you need to make sure that your water pump is turning the correct direction, there are electric fans that pull and electric fans that push- make sure yours is blowing the right direction
  15. 05snopro440
    05snopro440
    Nope. A bunch of that is antiquated.
    1. Aluminum rads usually have 2 cores of 1" or larger tubes. The old "have to have 3 or 4 cores) is copper-br***, not aluminum. Aluminum rads can flow better as a result.
    2. It's about air through the rad, it doesn't matter to the air or rad whether the fan is mechanical or electric. That's chasing money spent with more money spent for no reason.
    3. The cooling system IS keeping the car cool, just not at highway speeds. It's keeping it cool in stop and go, so it is working.
    As was discussed previously in the thread, his shroud appears to be the most likely issue. Taking it and the fans off and going for a drive will tell whether he has an issue with shroud design. With the design of the cheaper rad and fan setup he bought, I'm betting modifications to the shroud would solve his issue without the hundreds of dollars spent you're suggesting.
  16. blazedogs
    blazedogs
    I,ve learned through the years that shrouds on a radiater to prevent heating is almost a must I,m confused... Gene
  17. Those electric fans Just don't do the job and you have to keep spare ones in the trunk for when they fail. I did the changes I suggested to my 350 Chevy in my 38/40 Ford and it fixed the overheating. to each his own, just offering some help. I forgot to mention, put a large area washer with a 1/2 in hole in it instead of a thermostat, one less thing to break.
  18. Motorwrxs
    Motorwrxs
    I hope the OP comes back to this thread and tells what he/she has done for the fix. This thread has been oddly enjoyable the past few days.
    anthony myrick likes this.
  19. **** yea. Fixing problems that almost don’t exist is fun
  20. Mr48chev
    Some checking shows that the part number he posted for the pump is for a clockwise pump and even with the flat belts he is running the pump in a clock wise rotation.
    I'm not seeing much of any way for air to byp*** the radiator though holes in the core support that shouldn't be there or gaps between the radiator and the support.
    Timing = been there done that with late timing. I don't even know how the 350R in my 51 Merc ran with the timing that late but It ran down the road at 80 pulling a trailer for hours on end.
    Looking at some 61 Chebby under the hood photos there isn't much space for a lot of air to get between the core support and the hood. I've seen 49/51 Merc guys leave that panel over the radiator off all too many cars because "it blocks the view of the engine and I don't like that" and have similar issues. Air going over rather than through the radiator.
    That comes down to lower hose collapsing at speed or that cute fan and shroud setup blocking too much air at speed. Screenshot (637).png
    bobss396 and Unkl Ian like this.
  21. gimpyshotrods
    gimpyshotrods
    Removing the thermostat decreases operational efficiency, and reduces BOTH power and milage.
  22. Oneball
    Oneball
    A decent one does. Those shrouds are so close to the rad and cover so much of it up once you’re doing more than 30mph they become a hindrance to airflow.
  23. Unkl Ian
    Unkl Ian
    Exactly why the OEM stuff doesn't look like that.
    You can make it work well, OR make it easy/cheap to make.
  24. 19Eddy30
    19Eddy30
    from VA
    I read threw all,
    I will waste some time,
    I think , (like others have said )) main problem is Not enough airflow at highway speeds going through the radiator,/core..
    Air is stacking up &'leaking in front of radiator bleeding off in front of core support and other places not flowing through the radiator cores @ Hyw / road speeds , because of fan shroud
    That fan shroud is a poor design , needs to be modified , but best to remove an ad
    70'-80s shroud , cutch fan best but not required,
    Timing Forget about Vac Advance for now!! until you get your cooling under control,
    12 -18 initial btc
    Total 34-38
    also when it comes to coolant temps,
    I have done !!!
    Get yourself four temperature gauges ,test and calibrate them in warm 200 degs of water, Write down the difference between the gauges if there is.. stick them in four different places on a small block Chevy and you will get four different readings of coolant temps
  25. ALLDONE
    ALLDONE
    there's a large group of people that come here... soon as they get what they want they leave no matter what...but at the same time there's a bigger group that comes here looking for info that don't post at all...not say'n that the group here is bad,. but some don't take the constant ribbing that goes on so they just keep quiet...kinda the red nose reindeer deal, but all in , they a lot of good things post here that are helpful for one trying to fix stuff their self... so it works IMO... that and the entertainment of the discussion pretty hard to fix someone's car on the internet, or over the phone,... and with out feedback from the OP as to what worked it doesn't have the value that would be there with it...I had a problem with my model A getting to 240 and climbing, so I fixed it...I now have a new problem,. I fixed it so good that now It won't warm up... at 118 out it now runs 170-180.. not hot enough...I want a maintained 200... at 180 the the 383 stroker doesn't perform well... I did every thing but the stat, and my guess is it's a 165.. no elect fan, or shroud, so my next fix.. a 180 stat
    IMG_2096[8666].jpg IMG_2674[8777].jpg IMG_2675[8776].jpg IMG_2727[8791] - Copy.jpg
    I also wanna add, the first thing I always do is the towel test, I hold a towel in front of the grille, if the fan doesn't **** the towel into the rad and hold it.... I start there... also, on this one I did the zips riser... works awesome
  26. ALLDONE
    ALLDONE
    The idea of a stat is to keep a constant engine temperature.. when the engine warms it starts to open and allow cooler coolant into the engine,,, then starts closing as the temp drops.. when this happens it allows the coolant to cool in the rad...all the while keeping the engine at a constant desired temp... too cold of a stat will cause the stat to open too soon and could also cause an over heat problem because the coolant goes through the rad. too quickly, so you end up loosing the rad. efficacy and end up will an engine with a lot of coolant all the same temp///
  27. twenty8
    twenty8
    The thermostat causes the engine to warm up faster and then maintains the minimum operating temperature.
    It has nothing to do with temperatures above that.
  28. THANK YOU, SIR.
    Ben
    57 Fargo and twenty8 like this.
  29. ALLDONE
    ALLDONE
    isn't that what I post???? so anyway... THANKYOU SIR
  30. LOL. Yes sir. Semantics?
    Ben
    2OLD2FAST likes this.
