Hot Rods '63 Rambler Classic 550
Discussion in 'The Hokey Ass Message Board' started by Greenblade, Oct 10, 2020.
  1. bobss396
    bobss396
    I had an OT '68 Mustang with no speedometer, just a tach. I had someone with a good speedometer drive next to me, beep the horn at 40, 50, 60 and 70. I jotted down the RPM and later wrote the values on tape and stuck them onto the tach face.
    41 GMC K-18 and Greenblade like this.
  2. Rctinker
    Rctinker
    Greenblade, what rear shocks did you end up using on your Rambler? I saw that the bottom mounts were fabricated on to the trailing arms, but did you use stock Rambler shocks or go with something different?
  3. Greenblade
    Greenblade
    I believe I just ordered the stock option off rockauto. Gabriel shocks
  4. Greenblade
    Greenblade
    Anybody in the black hills SD area have a 700r4 to sell? After installing the new ge****t I haven't driven the Rambler much due to high rpm.
  5. Hudson High
    Hudson High
    I'm in the process of installing my rebuilt T-35 BW on my '63 Cl***ic. What is the best way to remove the melted rubber trunnion from the "collar" flange? I've tried rubbing alcohol, heat gun, s****ers, and wire wheel brush. Taking forever to get it off.
  6. farna
    farna
    The original is vulcanized to the metal. It's just a PITA to remove. I've used a sharp wood chisel and a mallet... It was a quality piece when new for sure!
    leon bee likes this.
  7. Hudson High
    Hudson High
    Thanks - I ended up taking a wire wheel to it over several nights. Got it fully cleaned off and ready for the replacement. It's been installed for a month now, no issues.
  8. Greenblade
    Greenblade
    700r4 picked up. Looking forward to some overdrive PXL_20240902_181127644.jpg
  9. Greenblade
    Greenblade
    Went to a dirt drag event yesterday. Had some fun. Didn't take too many pictures IMG_0632.jpg PXL_20240901_195959265.jpg PXL_20240901_205617406.jpg PXL_20240901_192312684.jpg PXL_20240901_201114207.MP.jpg PXL_20240901_205531883.jpg PXL_20240901_195715408.jpg PXL_20240901_205321146.jpg PXL_20240901_190113024.MP.jpg
    loudbang, 51pontiac, Rctinker and 2 others like this.
  10. Rctinker
    Rctinker
    Will you be rebuilding the 700R4 or running it as is?
  11. Greenblade
    Greenblade
    It'll get rebuilt
    bobss396 and Rctinker like this.
  12. bobss396
    bobss396
    I knew of a few shops that would do carry-in work for me. Now I'm down to one that might still do that. For a little extra, one place had exchange units ready to go.
    Greenblade likes this.
  13. Greenblade
    Greenblade
    I was recommended a local guy. I'm hoping he does good work
    bobss396 likes this.
  14. BamaMav
    BamaMav
    from Berry, AL
    I just had the 700R4 in my 82 Vette rebuilt, cost me $1500. He pulled it out of the car, built it and used a new torque converter, then replaced it in car. When I had my Ford AOD built by the same guy, I carried it in and picked it up, it was only $1000. I figured it was worth the extra $500 on the Vette since I didn’t have to do anything.
    Greenblade and TrailerTrashToo like this.
  15. Greenblade
    Greenblade
    ISO
    Anyone who might have a '63 Rambler steering wheel and also anyone with a Ford 8” center section with 3.00 gears. I'm wanting to get up to Canada later in 2026. The gear/ pinion ratio I got now is rather inappropriate for such a trip. The 700r4 I mentioned previously is on hiatus for the time being.
