Hot Rods 350 chevy will die when you let off the gas while driving
Discussion in 'The Hokey Ass Message Board' started by 29moonshine, Jul 27, 2024.
  1. 29moonshine
    29moonshine
    i have a 37 truck with a 350 engine , Edelbrock carb, with a stock hei new aluminum 4 core radiator and 185 thermostat. when it gets to 185 operating temp while driving if you let off the gas it will die but it will crank right back up , carb has been rebuilt i have changed the coil and cap on the distributor
  2. Will it still die in neutral?
  3. swade41
    swade41
    from Buffalo,NY
    Die like cold turkey or stumble then die ?
  4. 29moonshine
    29moonshine
    like cold turkey, just like it was turned off
  5. Wanderlust
    Wanderlust
    Sounds like an electrical short to me
  6. ALLDONE
    ALLDONE
    I don't know anything about what your problem is with out seeing it,... but some thing to check, when it's cold, it goes on fast idle... and when it warms up that goes away,.. maybe the hot idle is too low of rpms and when it warms up you need more idle...remember hot idle needs to be set when the motor warms up...
  7. ALLDONE
    ALLDONE
    also, hate to even say the word but here goes.... whats your timing set at?
    Motorwrxs likes this.
  8. Unkl Ian
    Unkl Ian
    Idle speed ? Timing ? Does it have a Choke Unloader ?
  9. Unkl Ian
    Unkl Ian
    Someone once said: "Most carb problems, are electrical."
  10. gimpyshotrods
    gimpyshotrods
  11. SS327
    SS327
    Don’t let off the gas?
    Jokester, alchemy, '51 Norm and 3 others like this.
  12. ClayMart
    ClayMart
    Did you mean "choke pull-off" or "vacuum break" instead of choke unloader?
  13. bobss396
    bobss396
    Key element here, gets to 185 and "soils" the bed. I have had ignition modules do all sorts of evil things to me over the years.
    One would start right away and keep going, another would start and I'd get a short distance, rinse repeat. The last one would refuse to start again after it was shut off, I'd have to try again in 2-3 hours.
    Wanderlust likes this.
  14. Had an O/T carbureted HEI Ignition 350 Chevy years ago would do the exact same thing .
    start up
    Idle
    Accelerate and run fantastic .
    let off the gas and it would just shut off , no burps , farts or stumbles . Just off like you turned the key off .
    Then fire right back up .
    ended hp being a bad engine ground .
    chased that one for a bit before I found it .
    good luck .
  15. Unkl Ian
    Unkl Ian
    427 sleeper likes this.
  16. SS327
    SS327
    Those are the terms GM used at school. Pull off or vacuum break.
    jaracer likes this.
  17. pprather
    pprather
    I had an hei where mechanical advance weights were not returning/closing when throttle closed, due to corrosion and dirt.
    At low rpm it had too much advance and died.
    Algoma56 and jim snow like this.
  18. Jeff Osstyn
    Jeff Osstyn
    Make sure all the adjustment steps are followed in the carb rebuild kit.
  19. tb33anda3rd
    tb33anda3rd
    have you checked for a vacuum leak? sometimes won't be an issue till the choke opens all the way up.
    Unkl Ian likes this.
  20. jaracer
    jaracer
    If it is warmed up and setting still, will it idle on it's own? If not, you either have a plugged idle circuit, or a fair sized vacuum leak.
  21. 29moonshine
    29moonshine
    thought i would let yall know the idler screw was missing the stop . i bent the stop and it seems to be working now.
    SS327, Unkl Ian, Algoma56 and 3 others like this.
  22. distributorguy
    distributorguy
    from MN
    2 common ailments I've seen that cause this:
    1. the pickup coil and magnet are failing. They drop out at lower rpms and would give you a complete loss of tach signal before the engine even stalls.
    2. The heads got shaved but not the intake, and you have a vacuum leak in the lifter valley - at the bottom of the intake ports from misalignment.
    If you have a manual choke, it may be your best tool to enrichen the mixture and see how it responds.
    The fact that you're not holding stat temp leans me to say the timing is retarded, so I'd be trying a higher setting and verify the vac unit doesn't leak.
