Hot Rods Big Daddy's 55 2 door wagon gasser
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 1, 2024.
  1. Budget36
    Budget36
    My ‘57 Chevy PU the front axle has them in the front as well, the rear axle has them in the rear.
    Wonder why it’s like that?
  2. Johnboy34
    Johnboy34
    from Seattle,Wa
    Early Ford Econolines have the shackles on the rear of front springs.
  3. Lloyd's paint & glass
    I look at it that as the car goes forward, the stable point should be in the front, and as the tires contact something, say a speed bump, it pushes the axle toward the rear of the car, and the shackles, but I'm not a suspension engineer, just a hack lol. I've done 2 with the shackles at the rear, and they both drove and rode great. I did one with a transverse leaf from a 47 Ford and hairpins. I like the parallel leaf setup better. I wonder if shackle position makes a difference with front or rear steer....????? Hmm...
  4. wvenfield
    wvenfield
    My reply was messed up. I did note "front" when I meant "rear" to show where manufacturers had different ideas on what was best but they all seemed to have worked.
  5. GlassThamesDoug
    GlassThamesDoug
    Straight Axle looks killer...
  6. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Eagle Rare no doubt.
    That’s one shot of Double Eagle Rare.
    I’m working on Double Eagle Rare.
    Really.
  7. Lloyd's paint & glass
    There was a bottle of eagle rare store pick involved, and a bottle of pappy 23 at $50 a shot :D and another bottle of Weller's.... it was a bad night man.
  8. Lloyd's paint & glass
    NEWSFLASH!!! rear tires are mounted. That's all for now.. 20240728_135426.jpg
    VANDENPLAS, enloe, slim38 and 15 others like this.
  9. swade41
    swade41
    from Buffalo,NY
    I put mine to the front (I have cross steering) but if you look where the rear lands on the kick up the swingy shackle wouldn't work there anyhow, just something else to think about.
  10. Lloyd's paint & glass
    I honestly don't think it matters. Because my experience is that the springs don't give much anyway. It would be interesting to me to see how much the shackle moves going down the road.
  11. Cl*** 6, 7, and 8 trucks have the shackles to the rear on the steer axles. I believe by doing it this way, it adds stability to the front end. I know there have been a few Ford Trucks that mounted the shackles to the front. The ones that come to mind are the 1980s-90’s Ford light duty 4x4’s. I’m sure there are reasons for both, I’m just not sure what they are.
  12. blue 49
    blue 49
    from Iowa
    I've read that if your cross steering is in front, the shackles should be in the back. This is to minimize side loading the shackles. I needed front steer and front shackles (like swade41) so I also have a panhard bar.
    Gary
  13. Lloyd's paint & glass
    That makes sense. There is a lot of force acting on the springs. When I put the axle under the front of my El Camino, there was a pop when I'd turn the steering wheel, one of my buddies was standing there once and he asked what the hell popped, I told him I don't know what it is, he looked under the car while I cut the wheel and it was the springs moving, I hadn't put straps on them.
  14. swade41
    swade41
    from Buffalo,NY
    During mockup I used the main leaf and a block of wood to simulate that height of the full stack of leafs. I would have to look back through my build thread but I believe the axle pushed forward 3/4 of an inch when the spring was compressed.
    My pitman arm points to the rear so theoretically if you hit a good dip in the road and the axle moves forward it could twist the steering wheel to the left. How much on a 3/4 inch movement I have no idea but I haven't noticed it while driving the car.
  15. Outback
    Outback
    from NE Vic, Oz
    @Lloyd's paint & gl*** I've read through this thread, I too was very amused how many pages were written before the car made it home, the banter was funny & the car will be awesome, better to sort those choices out before you start turning spanners, I will definitely subscribe & follow along with interest, looking forward to seeing what you do with it
  16. Lloyd's paint & glass
    Got tired of block sanding so I did a couple little things to my car before I went home today... 20240729_150729.jpg 20240729_151751.jpg 20240729_165223.jpg 20240729_165234.jpg 20240729_165243.jpg 20240729_165253.jpg 20240729_165629.jpg
  17. Lloyd's paint & glass
    2 hours and 10 minutes. I think it's my new record lol... still some welding to do, and I've gotta go get a piece of tubing to make my drag link, it's rigged at the moment so I can steer it lol
    VANDENPLAS, saltflats, enloe and 10 others like this.
  18. You are the designated HAMB straight axle installer!
  19. patsurf
    patsurf
    -you've now made it look like we should have the squirrel and lloyd show--but diff than 'home improvement'...
  20. wheeltramp brian
    wheeltramp brian
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
  22. choptop40
    choptop40
    Go Straight ( Axle that is ) to the head of the cl***....looking good...got a nose bleed looking at the front shot...
  23. patsurf
    patsurf
  24. Budget36
    Budget36
    enloe, 427 sleeper, Sharpone and 4 others like this.
  25. Moriarity
    Moriarity
    SUPER MODERATOR
  26. Lloyd's paint & glass
    I'm in the process of blocking a 71 Pontiac grandville that's going black, that's a lot of blocking lmao! My elbows hurt :(
  27. Lloyd's paint & glass
    No mine is open, my thought that it was a posi must've been in my head. I even asked Jerel, he said it's open because he's replaced the spider gears.
    Outback, enloe, 427 sleeper and 5 others like this.
  28. Do you need a Captain’s license to work on a car that big?? :D
    VANDENPLAS, Outback, enloe and 7 others like this.
  29. swade41
    swade41
    from Buffalo,NY
    Sitting proud !
    VANDENPLAS, Outback, enloe and 4 others like this.
