Hot Rods How about some love for the T-Bucket?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, May 9, 2021.
  1. 40ragtopdown
    40ragtopdown
  2. 40ragtopdown
    40ragtopdown
  3. 40ragtopdown
    40ragtopdown
  4. 40ragtopdown
    40ragtopdown
  5. 40ragtopdown
    40ragtopdown
  6. 40ragtopdown
    40ragtopdown
  7. 40ragtopdown
    40ragtopdown
  8. 40ragtopdown
    40ragtopdown
  9. wheeltramp brian
    wheeltramp brian
    Man that
    T roadster and parts look like you'd be halfway there. Where was that picture taken? I'm sure nowhere close to me.
  10. 40ragtopdown
    40ragtopdown
    Not sure where it came from. But it sure looks like a clean Western body.
    Snicklefritz65 and chryslerfan55 like this.
  11. Snicklefritz65
    Snicklefritz65
    from Mass.
  12. That's an early body, 1915 back I believe. (correct me if I'm wrong) It has a long cowl. I'd sure like to have it. That ****er is clean.
  13. ‘23. Low cowl with a steel firewall.
  14. Snicklefritz65
    Snicklefritz65
    from Mass.
  15. Snicklefritz65
    Snicklefritz65
    from Mass.
  16. Snicklefritz65
    Snicklefritz65
    from Mass.
  17. Snicklefritz65
    Snicklefritz65
    from Mass.
  18. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    As much as I like the long tube cross ram Mopars they look out of place on a T (bucket or not).
  19. Moriarity
    Moriarity
    SUPER MODERATOR
    Hmmmm, that is the Alexander brothers built top banana T that won the ridler award in 1969. I see the Lee Pratt 58 Chev in the background, I wonder when and where that picture was taken?
  20. silent rick
    silent rick
    that won the ridler? i wonder what the rest of the great 8 looked like
    bchctybob likes this.
  21. Snicklefritz65
    Snicklefritz65
    from Mass.
    it sure is. lots of details on this i like although generally i'm not a fan of "fat" tires up front.
    i wish i knew where i got this shot. maybe john moorehead's tbucketplans(.)com?
    Moriarity likes this.
  22. Snicklefritz65
    Snicklefritz65
    from Mass.
    more of top banana. top banana 1.jpg top banana 2.jpg top banana 3.jpg top banana 4.jpg top banana 5.jpg top banana 6.jpg top banana 7.jpg
    mad mikey, Deuces, loudbang and 7 others like this.
  23. RodStRace
    RodStRace
    Snicklefritz65 likes this.
  24. bchctybob
    bchctybob
    Motor mounts attached to the cylinder heads - I've always wondered if that was a good idea or not.... I wouldn't do it.
    GuyW likes this.
  25. silent rick
    silent rick
    they say they started with a brizio instant T kit
  26. patsurf
    patsurf
    talk to me or squirrel about all those yrs of vettes!... the pump not much worse..
  27. lurker mick
    lurker mick
    The Gathering at the ROC, 2023.
    Mick
    Tim and Moriarity like this.
  28. Dave G in Gansevoort
    from Upstate NY
    Just think about the 63 Lotus Indy car with the small block Ford engine. The rollbar bolted on to the heads. Gurney and Clark had big ones, for sure!
    mad mikey and Snicklefritz65 like this.
  29. RodStRace
    RodStRace
    Back then you had a choice; run the fastest, lightest (all dangerous, but lighter often meant less safe) car, or don't run F1. The fatality rates were not good and everyone knew it. Same or worse than TF.
  30. bchctybob
    bchctybob
    Well, when you consider that the '55-'57 Chevys had two 3/8 bolts holding those two cup-like mounts to the front of the engine, and two long studs holding up the front of the engine, I thought that the Corvette straddle mount wasn't too bad.
    That engine mounted roll bar was REAL sketchy. Eddie hill used the heads of his twin Pontiacs as stressed ch***is members too. Not ideal but it seemed to work....
