Projects 1930's style Race Car build
Discussion in 'Traditional Hot Rods' started by Jay A Driggars, Jun 14, 2022.
  1. Jay A Driggars
    Jay A Driggars
    I checked the Hastings catalog and they only manufacture STD rings for the 3.4's
    The ring gap was within specs when it was ***embled. I encountered several questionable issues during tear down and re***embly, nothing that should have caused catastrophic failure.
    Jag owners informed me that a proper rebuild could take a year and cost would be around $20,000.
    The engine looks great in the car but a $20,000 engine is not a good idea. The car does not have a very good market and I would loose thousands if I were to sell it with the Jag engine.
  2. HJmaniac
    HJmaniac
    If you give dimensions, they will match it up, not by engine make or size.
  3. HJmaniac
    HJmaniac
    Good Luck.
    alanp561 likes this.
  4. Jay A Driggars
    Jay A Driggars
    A valve failed a fluid test, it all ran out the exhaust valve. I've ordered a valve and will know later this week if its a fix.
    HJmaniac likes this.
  5. Jay A Driggars
    Jay A Driggars
    I replaced all of the valves. It started on the first try, and runs great. It idled at around 400 rpm and was smooth as silk, even before a proper carb tune.
    Deutscher, Vic Walter, rod1 and 6 others like this.
  6. ratrodrodder
    ratrodrodder
    from Boston
    Nice sleuthing! Time for a driving video for us to ooh and ahh over!
  7. Jay A Driggars
    Jay A Driggars
    The engines 500 mile break-in is complete. I checked the oil filter pleats and they were excellent. The engine is running great. The transmission is a Moss 4 speed with no synchro on 1st, 2-3-4 are synchronized, it requires a little finesse.
  8. Jethro
    Jethro
    Marvelous!...Bravo! , way better than a SBC
  9. Jay A Driggars
    Jay A Driggars
    I forgot to mention this was my first engine rebuild. It was a great experience, maybe I'll get a chance to do another one. The transmission and overdrive also had to be dis***embled, cleaned, inspected and ***embled, I've rebuilt a couple of manuals.
    Deutscher and brEad like this.
  10. Jay A Driggars
    Jay A Driggars
    Thanks!
  11. chrisp
    chrisp
    You could have kept the T5 to put it behind the Jag 6.
    Nice car. I really like those wheels.
  12. Jay A Driggars
    Jay A Driggars
    My T5 is a GM, the Ford T5 is the only one they make adapters for. The GM input shaft is too short even for a custom adapter.
  13. Jay A Driggars
    Jay A Driggars
    Oil pressure after engine break-in and first oil change. The break-in oil was 30w with no detergent, it now has Valvoline VR-1 10w-30 racing oil. During the break-in period, the oil pressure was 25 psi at idle and 40 psi at 2000 rpm. With the Valvoline VR-1 the oil pressure is now 30 psi at idle and 50 psi at 2000 rpm. Should the oil pressure be different with 10w-30 VR-1?
    Deutscher likes this.
  14. Jay A Driggars
    Jay A Driggars
    Left Side Front_2.jpg Engine2.jpg Right Side Front_2.jpg Right Side Rear.jpg Here's some new photos. It's running great now, and it's so much fun to drive.
    jet996, Deutscher, Mikko_ and 15 others like this.
  15. elgringo71
    elgringo71
    It’s beautiful, you did a great job. It looks like it would be fun to drive on some curvy mountain roads
    Uncle Ronn and Tow Truck Tom like this.
  16. 282doorUK
    282doorUK
    Nicely done Jay, it looks well balanced, any idea of the front rear weights?
    Tow Truck Tom likes this.
  17. Jay A Driggars
    Jay A Driggars
    It weighs about 1300 lbs. But I don't know the front rear weights. It's fun to drive. The handling is great, especially for a solid front axle.
    Uncle Ronn likes this.
  18. Uncle Ronn
    Uncle Ronn
    from Modesto CA
    Bet it Sounds Pretty Good Too!
  19. 282doorUK
    282doorUK
    It has the correct all important elbow to rear wheel ratio too...
    jet996 and brEad like this.
  20. Jay A Driggars
    Jay A Driggars
    The Jaguar 3.4 that's in the car now, appeared to be a collection of parts. The head and the block are matching casting number. The oil pan was most likely from a different block, as were the sump pickup tubes. The pan and pickups were both damaged by metal pieces bouncing around in the pan.
    There were some odd things also, like one of the main nuts was secured by a tab lock washer made out of a tin can.
    jet996, Deutscher, rod1 and 3 others like this.
  21. Dave G in Gansevoort
    from Upstate NY
    Now that there is aerospace engineering! Why I bet that would be good to at least once to 5 grand! Then, well, let's not go there...
    Sharpone likes this.
  22. Jay A Driggars
    Jay A Driggars
    I recently completed a few updates and fixes.
    The oil filter pointed downward, no oil in the filter at startup. This caused the oil pressure to delay at startup. I replaced the oil filter ***embly with an up facing filter, proper oil pressure at startup.
    The sump was damaged and leaked lots of oil. I replaced it with one in excellent condition, with no oil leaks.
    I added a fan shroud too. I used a small kerosene flask as an overflow tank.
    It's been a while since I worked with copper, so it's got a custom copper catch can now.
    There are still a couple of minor oil leaks, one's the intake cams oil feed inlet. Someone had damaged the banjo bolt threads, so I had to install a heli-coil insert. I tried new copper washers and crush washers; it still leaks a little. It might damage threads if I tried to tighten it more.
    It recently started leaking a lot of oil from the rear transmission seal. The seal was replaced during the rebuild. I have another new one on order. The yoke may have a groove in it where the seal sets.
  23. patsurf
    patsurf
    speedi-sleeve!
  24. rod1
    rod1
    So Cool. Be proud at what you have accomplished.
    Sharpone and Jay A Driggars like this.
  25. Jay A Driggars
    Jay A Driggars
    It's been a great experience, Thanks
  26. Jay A Driggars
    Jay A Driggars
    I'll measure the yoke to see if there's a speedi-sleeve that will fit.
  27. rwrj
    rwrj
    from SW Ga
    This thing is fantastic.
  28. Jay A Driggars
    Jay A Driggars
    I finally got the transmission oil leaks stopped, maybe. Some of the sump bolts leak occasionally, they use copper washers, I'll be trying crush washers next.
