Technical Fiberglass Willys bodies
Discussion in 'The Hokey Ass Message Board' started by willys36, Jul 29, 2024.
  1. willys36
    willys36
    With no mags any longer, don't go to rod runs, have lost contact with the commercial rod market. Are there still companies making pre-war Willys coupe bodies? And Ford bodies for that matter?
    Tow Truck Tom and Deuces like this.
  2. 19Fordy
    19Fordy
    Tow Truck Tom likes this.
  3. willys36
    willys36
    denis4x4 and Tow Truck Tom like this.
  4. swade41
    swade41
    from Buffalo,NY
    ScottRods in west Ohio and A & C in Buffalo NY both make high quality bodies
  5. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Mine is an A and C. It was a shock to me at just how good it was. Go back and look at my builds. It’s pretty nice. Wished I hadn’t gotten the hidden hinges and had gotten the stock. That way I could have put the pull pins like the Prefect and Opel Kadet and remove the doors and hang them easy. Everything is there I just didn’t at the time. Hind sight
    swade41, rod1 and Tow Truck Tom like this.
  6. brigrat
    brigrat
    from Wa.St.
    Willys in my avatar is an Outlaw, bought 2 of them #24 & #25. Would by a chopped '33 if they made one.
    Hotrodmyk, catdad49, rod1 and 3 others like this.
  7. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I haven’t don’t the Final Cut and buff. I have some orange peel in the clear right behind the door on both sides. And for the life of me I haven’t figured out how. It’s the most access able area when I sprayed it. Go figure.Do yourself a favor. Buy the grill /headlight ***emblies and let them do the front cap and trunk hinges. It will actually save you money and time in the long haul. Again also I wished I would have done the stock hinges so could quick pin the doors. But it shuts very solid. Is well built lots of structure reinforcement in the critical areas. I would buy another one( 33 pick up ) in a heart beat if offered and I had the coin
    Also this is a street body. I have total weight with ***embled car and me. And that’s as you see cage and all. I was shocked. As in how light it really was. .
