Hot Rods Barn or in this case, garage finds still exist!!
Discussion in 'The Hokey Ass Message Board' started by Vintage Amercian Iron, Feb 8, 2019.
  1. Vintage Amercian Iron
    Post Office just dropped off my latest Ebay score. One new old stock GM original & 1 aftermarket with new chrome front bumper "bullets."
    chryslerfan55, Spooky and Squablow like this.
  2. Vintage Amercian Iron
    Cut out, then started fitting the patch on the passenger side lower quarter panel.
    Found more rust through on the inner rocker, but leaving that as is because I have a complete replacement floor for it to go in at a later date.
  3. Vintage Amercian Iron
    Got the majority of the outside of the patch welded, still have the inside of the wheel lip and have to deal with the bottom where it folds under and joins up to the inner rocker later when the floor is changed, so it is just hanging there for now.
    chryslerfan55, Squablow and Cosmo49 like this.
  4. Vintage Amercian Iron
    First coat of Duraglass over the welded area:
    Took these with my phone, no idea why they are turned, they are positioned correctly when I look at on my computer...????
    chryslerfan55, 61Cruiser and loudbang like this.
  5. Squablow
    Squablow
    Fixed them for you. Not sure why they got turned if they look to have the correct orientation on your computer before posting.
    Looks good though, glad to see more progress on this one.
  6. Vintage Amercian Iron
  7. Vintage Amercian Iron
    Added a second skim coat of Duracoat to smooth out the area. Will knock that down when it sets and on to the next issue.
  8. Vintage Amercian Iron
    Finished up smoothing out the area on the quarter panel & primered.
  9. Vintage Amercian Iron
    Starting some more detail finishing on the doors, passenger side stripped above & below the weld line, then skim coated with Duraglass, sanded and a few small spots covered. Final sanding for this stage and some primer to cover the area.
  10. Vintage Amercian Iron
    Driver side gets the same treatment, but some additional work needed on the lower inside as well.
    IMG_3134.JPG IMG_3137.JPG IMG_3138.JPG IMG_3139.JPG IMG_3140.JPG IMG_3142.JPG IMG_3144.JPG
  11. Vintage Amercian Iron
    Primer on the inside but ran out so need more before doing the front. But then both doors will be done and on to the fenders. IMG_3145.JPG IMG_3146.JPG IMG_3147.JPG
  12. Vintage Amercian Iron
    Grabbed some more primer over the weekend and this part of the door work is done.
  13. Vintage Amercian Iron
    Started some smoothing of the driver side fender over the welded/repaired areas.
    mvee33, chryslerfan55, BigRRR and 7 others like this.
  14. Squablow
    Squablow
    Still looking nice, good to see more progress. I also like to see original panels getting repaired, even when they're available new. Too much new sheetmetal gets to be a Ship of Theseus situation.
    Vintage Amercian Iron likes this.
  15. indyjps
    indyjps
    Great to hear you're helping the family out, awesome score on the 57.
    The '73 truck - looks great to me. Scuff it down, acid etch, and shoot it with enamel ( tan,white, or grandpa green ) - good to go for another 10 years.
    chryslerfan55 and SS327 like this.
  16. Vintage Amercian Iron
    Thanks, been a little bit due to hunting season interupting and redirecting priorities...
    chryslerfan55 and Squablow like this.
  17. Vintage Amercian Iron
    Both the "A" pillars were almost completely gone as was the bed floor, it was surprising they could hold the doors in place.
  18. Vintage Amercian Iron
    Skimcoat to even out the area and a little attention to the lower fender repair area as well.
  19. Vintage Amercian Iron
    Finished up smoothing the side of the fender. But still have a little work around the headlight opening before moving on to high build and blocking.
  20. Vintage Amercian Iron
    Headlight area cleaned up and primed. Back to storage and time to start on the other fender.
  21. Vintage Amercian Iron
    After last week's trip to the big swap meet in Portland, I decided to pull out all my stuff I have been accumulating over the past few years and do an inventory....
  22. Vintage Amercian Iron
    Been off busy recovering from a total knee replacement and getting back to somewhat normal activity. Started smoothing over some welded areas from previous rust repair.
  23. Squablow
    Squablow
    All progress is good progress. As long as you keep working on it, eventually it'll get done.
    osage orange likes this.
  24. Vintage Amercian Iron
    Thanks, kinda hard to get back in the groove after so long, appreciate the encouragement.
    osage orange and TrailerTrashToo like this.
  25. Vintage Amercian Iron
    Little more hand sanding to smooth out the area then some primer for now.
  26. Vintage Amercian Iron
    Started smoothing out a couple of welded areas.
    547973446_24976419468616453_5116563452427173171_n.jpg 548736456_24976419488616451_4654856493019501054_n.jpg
    SS327 and loudbang like this.
  27. Vintage Amercian Iron
    Little touch-up to even the area out and some primer. 548195129_24984864061105327_6452725429892316545_n.jpg 548201863_24984864411105292_6378363274589399850_n.jpg 548219022_24984864107771989_6398490201277422427_n.jpg 548230371_24984863757772024_7030477931288383134_n.jpg 548213961_24984863781105355_5316837161968696596_n.jpg 548202334_24984864371105296_8776906672304161046_n.jpg
    Squablow, 55 Ford Gasser and loudbang like this.
  28. Vintage Amercian Iron
    True.
    This is my first time attempting something on this level, so taking a little extra time, researching and such. Lots of how to videos and then diving in!
    sunfighter and Squablow like this.
  29. Vintage Amercian Iron
    Trying out a new tool to strip to bare metal…started with dirt, paint, road grime, etc and down to clean, bare metal in about 15-20 mins!!
    548338043_24993623046896095_8707543720614314583_n.jpg 549652544_24993623056896094_6525435036223156617_n.jpg 550064854_24993623403562726_8534352969280487539_n.jpg
    Squablow likes this.
