Technical Making aluminum radiator black...with primer
Discussion in 'The Hokey Ass Message Board' started by jaalcom, Jul 30, 2024.
  1. jaalcom
    jaalcom
    from Maryland
    I just purchased an aluminum-in-the-raw radiator for a stock '65 Impala and you know it has to be black. I'm not sure that all the fuss some make about reduced cooling ability is a factor unless you decide to apply an 8 layer BC/CC finish. Still, this got me thinking -- Since it really doesn't require any UV protection and it should be a low gloss black why not use what's on hand, this would be black epoxy primer. It could be reduced to sealer visc and provide a thin one or two coat finish that should stand up well to the environment. In addition it would be just different enough in sheen to look OEM mismatch.
    I'm basically sharing my intentions but still interested in hearing any opinions or experience?
    lothiandon1940 and Tow Truck Tom like this.
  2. deucemac
    deucemac
    Make sure that you use zinc chromate primer because regular primer doesn't stick to aluminum very well. Once the chromate is on you can apply any color your heart desires.
    Tow Truck Tom likes this.
  3. Main thing is worry about is it still turning lighter from all the heat cycles. On my 53 I used engine paint to actually paint the tanks and lightly misted the core to make it overall look black. Still cools fine
  4. fastcar1953
    fastcar1953
    I've just used rattle can.
  5. Mr48chev
  6. BJR
    BJR
    I have used barbecue flat black high heat paint with no pealing issues.
  7. dana barlow
    dana barlow
    from Miami Fla.
    BBQ Grill black spray can,I used on new alum rad,also,, over 8 years back,is still good,no faiding/graying.
  8. jaalcom
    jaalcom
    from Maryland
    Thanks to all. Much appreciate the info and insight!
  9. Another vote for eastwoods rad paint, definately no cooling issues.
  10. RICH B
    RICH B
    Used BBQ paint with no problems with peeling or oxidizing over the years.
  11. gnichols
    gnichols
    from Tampa, FL
    Buy some spray bomb radiator paint at the auto parts store. It gives a thin coat to aid cooling.
    lothiandon1940 likes this.
  12. Happydaze
    Happydaze
    Experience here with black epoxy primer. Nice satin finish. Looks great. Been in use 12 months now. About 3000 miles. No cooling issues. Still looks like I painted it yesterday! So far so good.
    Prep was somewhat cursory. Surfaces (except fins) were scuffed with scotchbrite and then the entire rad was heavily sprayed with panel wipe/ prepaint. I mounted it in a body panel rotating paint stand so I could reposition it whilst painting to help get full coverage without excessive buildup, especially on the fins. I think it came out as well or better than I could have imagined.
    Kinda funny thing. I cheaped out on this car with a Champion aluminium rad but once fitted I regretted that decision. Looked nowhere near as good as the Walker rad in my roadster, but since painting it I've not given it another thought! Both cars have full hoods so there's not much to see but I think I'd be happy either way if they were hoodless, but I'm not ******** trad! Ymmv.
    Chris
    Algoma56 and lothiandon1940 like this.
  13. lothiandon1940
    lothiandon1940
    ...What's your "general" location in Maryland?
  14. G-son
    G-son
    from Sweden
    Paint sprayed at a radiator core will not penetrate deep into the core, it will just cover the outer layer, the part that easily can be seen. Use whatever good paint you like, as that isn't much if the total cooling surface area of the core. Even if a layer of paint actually does reduce cooling, most of the core still remains unpainted.
    gnichols likes this.
  15. manyolcars
    manyolcars
    Wrinkle black has always been considered best for heat dissipation
    warhorseracing likes this.
  16. bobss396
    bobss396
    I like VHT Ch***is and Roll Cage black. It has a satin finish to it and is quite durable. Touch ups, it blends in very well.
  17. bangngears
    bangngears
    from ofallon mo
    i bought an aluminum radiator from a local manufacturer here in Missouri and he told me if i wanted it black, to paint it with cheapest Walmart flat black. Apparently, it had no effect on cooling.
    Algoma56 and Kelly Burns like this.
  18. jaalcom
    jaalcom
    from Maryland
    Much appreciate the replies. Lots of great info and insights!
  19. jaalcom
    jaalcom
    from Maryland
    Currently just outside Andrews Air Force Base (JBA). Making plans though to vacate the state early next year to, as of yet, parts unknown. In search of a bit more freedom than MD offers along with just a little warmer winters. Not going back to south Florida but likely somewhere in-between and nearer the Appalachians.
  20. 05snopro440
    05snopro440
    I've used duplicolor black paint on an aluminum radiator. It's still on there 12+ years and nearly 40,000 km's later, and my radiator happily keeps the truck on thermostat temp.
    rod1 and Algoma56 like this.
  21. theHIGHLANDER
    theHIGHLANDER
    I painted some of em many years ago with plain ol Krylon Semi-gloss black. Lasts for a looong time. Cooling? How come air cooled modern cycle engines are satin black? Black absorbs heat. Air dissipates heat to atmosphere. In SAE theory it should cool better. "OK smart *** then why aren't new radiators black?" Cuz it saves em ****in money. How much better does it get in black? I dunno, I'm not the engineer, and I also like how it looks. Seeing an aluminum radiator thru the grille is like seeing someone in a bridal party with his fly open. Yeah, I said it...
    Algoma56 likes this.
  22. lothiandon1940
    lothiandon1940
    ...I can completely understand how you feel. I spent my first 12 years in East Tennessee in the foothills of those Southern Appalachians and I've always felt like I left my heart there.
  23. In the reverse of things, I like to spray my SBC engines with aluminum paint and tell people it's a rare Can Am engine that I (obviously ;)) removed from a Corvette :D
    1952henry likes this.
  24. Not long ago, I media blasted the ends of a set of Dart aluminum heads for a SBC and painted it orange, so they looked iron.
    jimmy six and lothiandon1940 like this.
  25. el Scotto
    el Scotto
    from Tracy, CA
    BBQ paint if I'm feeling fancy, but usually whatever black I have in a rattle can.
  26. deathrowdave
    deathrowdave
    from NKy
    Engine paint has always worked good for me
  27. gene-koning
    gene-koning
    I left my aluminum radiator unpainted, so it would stand out and look like **** through the grille of my blue truck.
    Actually, in the heat of the build, it was one of those things that slip your mind until its too buried to paint it. Someday, when I have to take the front of the truck apart, maybe I'll remember to paint the radiator, or, maybe not.
  28. dutchrod
    dutchrod
    I painted three aluminium radiators black witch cheap flat black spray cans , it holds up real good for many years.
    No problems with heat , radiators don't get real hot so no need for heat resistant paint.
