Technical Post some pics of your radiator overflow bottles for 30s hotrod
Discussion in 'The Hokey Ass Message Board' started by Choppedcoupe, Apr 7, 2020.
  1. mgtstumpy
    mgtstumpy
  2. Choppedcoupe
    Choppedcoupe
    Wow! Great ideas! Keep 'em coming. I like the gl*** bottles because you can see thru them, but I wonder how the tech inspectors at the strip would take that-I do plan to do some drag racing (even though I don't expect to win any trophies at either the races or any shows (this car is driver quality by design). I also like the fire extinguisher bracket to allow easy removal for servicing. I might have to try it out.....
    I'm also thinking about an old Marvel Mystery Oil can....
    In order to use it as recovery tank, should the bottle be sealed (like air-tight) or vented?
    WC145 likes this.
  3. GearHeadDiver
    GearHeadDiver
    I have a similar small car pyrene extinguisher in chrome. Would really love to use it but cannot figure out how to get the interior pump parts/pieces out.
  4. blue 49
    blue 49
    from Iowa
    I made ends for a piece of aluminum electrical condiut and had them welded on. The inlet is a siphon tube and the bottom has a pet**** drain. I also made one for my Henry J that isn't painted but is lathe turned.
    Gary
  5. GearHeadDiver
    GearHeadDiver
    Did you remove all inside components?
    If so...how?
  6. Splitbudaba
    Splitbudaba
    Had an old canteen laying around. Made it easily removable when cool. PXL_20240426_183545784.jpg
    WC145 and loudbang like this.
  7. BJR
    BJR
    I turned mine inside out so it's ribbed for my pleasure. :p
    '28phonebooth and Bandit Billy like this.
