Projects Sam's Chicken Coupe
Discussion in 'Traditional Hot Rods' started by Anderson, Jun 21, 2024.
  1. Tim
    Tim
    from KCMO
    Cool,Would love to see it if you come across it.
  2. Anderson
    Anderson
    I didn’t realize the picture of it in the car didn’t show hardware installed. The strips at the seams underneath and the trans cover hold the wood together pretty solidly. And the trans cover attaches to the floor cross brace and firewall for support too.
    Okie Pete, BigJoeArt, Tim and 2 others like this.
  3. swifty
    swifty
    With the A pillar laid back did you have to re-locate the hinges?
  4. Anderson
    Anderson
    The hinge largely stays in the stock spot. The a-pillar is very slightly notched around the hinge.
    When we chop this one, I’ll take a lot of pictures and maybe start a build thread on it.
    Okie Pete, swifty, alanp561 and 4 others like this.
  5. Tim
    Tim
    from KCMO
    Thanks! That helps a ton.
    Anderson likes this.
  6. Anderson
    Anderson
    We've gotten a lot of stuff done on coupe #2. Saving the chop for last.
  7. alchemy
    alchemy
    Are those real live Buick rims on Merc centers?
  8. Anderson
    Anderson
    This car was small Ford bolt pattern already and we’re not changing much on the ch***is. So we found some ‘60’s Ford wheels and used them as-is on the front, then did get Buick hoops for the back and reversed them on the later Ford centers. The rear end is pretty narrow, so they fit well under the fender. The caps are aftermarket made to fit these later wheels.
    2Blue2, Tim, Okie Pete and 2 others like this.
  9. alchemy
    alchemy
    Gives the cl***ic look.
    Kelly Burns, brady1929 and Anderson like this.
