1966 Mustang 2+2 - Beater / Patina Build
Discussion in 'Off Topic Hot Rods & Customs' started by agshelby, Aug 3, 2024.
  1. I picked this car up about 1.5 years ago. It was parked in 1993 and overall solid, with some minor floor work needed. That’s pretty much typical with an early mustang - and the frame rails and unibody are in excellent shape.
    The “plan” was to just get it running and drive it as-is. But things kind of snowballed. In the middle of this rebuild we are making a move from Texas to New Zealand. The mustang and my 32 are coming with us - so I am in a thrash to get the mustang done in the next two months. The New Zealand inspections are thorough - and everything on this car (structural and mechanical) will be in new condition.
    So far:
    New painless wiring harness
    347 stroker, Dino tuned at 400 hp
    T5Z trans
    9” that came out of a 57 ford, with a traction lock 3.50 gear set
    New Kelsey-Hayes front discs brakes
    Restored interior
    Floors and entire underneath stripped to bare metal, coated in POR-15, seam sealed and painted
    New brake and fuel lines
    Reproduction Shelby Crager wheels
    Rebuilt suspension - lowered 2”
    Sub frame connectors, export brace and a Monte Carlo bar
    Shelby Hood
    Shelby R Model Valance that eliminates the front bumper
    Rear seat delete
    Stainless fuel tank
    I’ll start off with a “before” photo - as bought:
    Malcolm, RMcCulley, swade41 and 2 others like this.
  2. Nothing ***y about wiring. This was probably the worst that I’ve seen. It was an easy choice just to rip it all out and replace. I prefer the painless kits for a mustang. Easy to do - it’s all labeled and the connectors are mostly plug and play. Any that I had to terminate are solder connected and covered in shrink wrapped insulation.
    The electrical is now all new - every switch, bulb and connector in the car.
    Here is a before / after of the dash area:
    Sharpone, swade41 and Deuces like this.
  3. Brakes are new Kelsey-Hayes reproductions from CSRP. Great product and customer service -
    I didn’t take any before photos - was just basic ford drums that had been rattle canned orange.
    New front discs:
  4. blue 49
    blue 49
    from Iowa
    Except for the wheels (I had chrome slots), it looks like one I totaled in the early '70s.
    Gary
    Sharpone likes this.
  5. BamaMav
    BamaMav
    from Berry, AL
    Beautiful car! I’ve had several coupes, but never a fastback.
    Sharpone and Deuces like this.
  6. Kerrynzl
    Kerrynzl
    Be very careful with any patch panels .
    And DO NOT POR-15 the underside until it has gone through compliance in New Zealand.
    They will ask you to remove it so they can see what it is hiding underneath [POR--15 is almost impossible to remove]
    Spot welded and overlapped patch panels in the floor will NOT p*** inspection.
    One last thing ..................... give the whole car a steam clean before you load it into a container.
    Talk with your shipping guys.
    When I imported vehicles, after loading the container [and tying everything down] the entrance of the container was sealed with plastic and a "bug--bomb" was let off to fumigate the container. Leave the bomb their so the biosecurity people can see it.
    It can cost $1500 for them to clean and fumigate a vehicle if there is a bio risk.
    Nice 'Stang by the way .Do yourself a favor and send it off to a paint correction guy [reds oxidizes badly , But comes back really well]
    Once the paint is shiny , you might re-evaluate respraying vs touch ups
    A Texas car with original paint that is shiny will go a long way to impressing inspection.
    You have only one chance at a first impression.
  7. POR-15 is basically a paint - it doesn’t cover anything at all (any more than paint). It is not the thick rubber undercoating. It’s already painted - I hope that it isn’t an issue down the line …
    The underside has no patches and the replaced rear floors were **** welded:
  8. Deuces
    Deuces
  9. swade41
    swade41
    from Buffalo,NY
    Nice work, this one has been hitting the local cruise nights, really nice paint
  10. Kerrynzl
    Kerrynzl
    It will need a repair cert in NZ if the compliance deems any repair structural.
    The repair certifiers are tough, the compliance part easy.
    If they can see any repair covered over with paint [POR-15] you will need to remove that area.
    I had to strip the underside of my 57 because the under body was painted in "ch***is black" [to cover all the black widow spider webs]
    After 3 weeks of s****ing the Repair Cert inspector looked at it for about 15 seconds and said "OK you can paint it now" [which pissed me off]
    If you do any repairs TAKE PHOTOS before, during and after.
    With your floor because it is already painted, remove all the interior [carpets and plastics] so they can see the other side during inspection
    Doing this could give you a visual "free p***" on the inspection.
    Also do all your brake hoses, wheel cylinders, M/C and caliper seals before you export it [this will save $$] and the Park brake must be working properly.
    No frayed front seat belts at all.
    You will need to change the headlights when you get to NZ [our headlights dip to the L/H side]
    The only thing redeemable about NZ inspections is zero smog inspections on any car.
    We don't do "Catbacks" in NZ! we big bore the whole system even on our new cars
  11. SS327
    SS327
    Just tell the inspector this is an American car and you’re an American so it will be ok.
    Deuces and Sharpone like this.
  12. I’ll just have to work through the inspections for the mustang and the 32. Both are solid, rust-free and in excellent mechanical condition. I’m aware of the requirements and have been adapting both cars ahead of the move.
    On the mustang - everything from the brake cables, lines, hoses and entire brake ***embly is new or rebuilt as new, along with every other mechanical and electrical part. It is spotless mechanically and rust free. I’m sure there will be issues - but I don’t expect anything major.
    Deuces and Kerrynzl like this.
  13. Kerrynzl
    Kerrynzl
    That'll do it !!!
    He doesn't even need to produce a p***port to prove he's American.
    P***ports are only needed for foreigners
    rod1, chevy57dude and SS327 like this.
  14. SS327
    SS327
    I miss that show. So much wisdom and an El Camino with Jamie Presley. What could go wrong?
    hotrodjack33 and rod1 like this.
  15. Exhaust is done - all stainless. Rear axle is a ‘57 Ford 9” with a 3.50 Eaton True-Trac, transmission is a T5Z.
  16. Deuces
    Deuces
    :confused::rolleyes:
  17. These responses are good example of why there aren’t many build threads anymore. I’m out.
  18. 6sally6
    6sally6
    Somebodys in a bad mood !
    YOU were doing the narrative about your "build"...we were just watching.
    Guess we were being inattentive and talking in cl***......
    6sally6
    Deuces and SS327 like this.
  19. HOTRODPRIMER
    HOTRODPRIMER
    I like your Mustang, looking forward to seeing what you end up with, I love the fastback! HRP
    Deuces likes this.
  20. Grumpy ole A
    Grumpy ole A
    I like your Mustang and hope your move goes well.
    Deuces likes this.
