What OT crap are you working on
Discussion in 'Off Topic Hot Rods & Customs' started by anthony myrick, May 9, 2024.
  1. guthriesmith
    guthriesmith
    Found my whine…seems these tensioners and the one inside that causes me to pull the cams, etc. last about 25-30k miles is all…
    Okie Pete, 67drake, Balljoint and 2 others like this.
  2. gearhead9663
    gearhead9663
    building a 51 pontiac tin woodie on an extended 4 door s10 frame with air ride....
  3. JohnLewis
    JohnLewis
    Where's the pics?
    67drake likes this.
  4. guthriesmith
    guthriesmith
    Going back together with the torque tube now that my son and I both have time to work on it.
    Okie Pete, 29A-V8, 67drake and 5 others like this.
  5. swade41
    swade41
    from Buffalo,NY
    I was watching Tony Angelo do that this morning
    Okie Pete and guthriesmith like this.
  6. lumpy 63
    lumpy 63
    20240803_105134.jpg went with Hot Rod Holly to pick up her new project car today....I've known her for years and somehow she keeps talking me into this ****..
  7. SS327
    SS327
    Probably didn’t take much talking.
  8. chevy57dude
    chevy57dude
    Tell her about the road trip to Lloydfest, Lumpy.
  9. lumpy 63
    lumpy 63
    She drove her 56 pickup on the Rt 66 run from San Diego To Chicago not to long ago:cool:
  10. swade41
    swade41
    from Buffalo,NY
    She seems to go someplace car orientated every day, always busy.
  11. guthriesmith
    guthriesmith
    Almost there… Just have to put exhaust back on, bleed the brakes, put wheels back on, and should be done.
  12. Deuces
    Deuces
    My first car was the '68 droptop....:rolleyes::)
    Okie Pete, guthriesmith and lumpy 63 like this.
  13. lumpy 63
    lumpy 63
    I see long hours ahead on this one... Needs to be completely rewired , the cooling system needs work and the engine although new runs pretty ****py.
  14. fyrffytr1
    fyrffytr1
    How's this for OT ****? 1989 Tracker Panfisher 16 with a 25 horse Evinrude and stick steer. I rebuilt the trailer, lower unit on the motor and hydraulic jack plate. Then I had a competent welder fix all the leaks. That was earlier this spring. Then summer came and my health faltered a little so I haven't done much more to it. I need to run new wiring, install a new steering cable and put the interior back together. Shouldn't take more than a couple years to finish it! And no, the trucks in the background are not mine, but they may be available.
    20230529_193703.jpg 20230529_193712-1.jpg 20230529_193719.jpg 20230529_193756-1.jpg 20230529_193805.jpg finished trailer.jpg
    Okie Pete, 29A-V8, Balljoint and 5 others like this.
  15. guthriesmith
    guthriesmith
    Finally came in the house after a test drive. Everything we had apart and put back together seems to work…so, bonus! Still more stuff to fix, but that should have been the hardest thing. Everything else is interior cosmetic stuff from gorillas taking things apart without having a clue how to do it.
  16. Balljoint
    Balljoint
    Replacing front springs, all four balljoints and sway bar bushings/links on my avatar.
  17. Fitting some 22s
    Chavezk21 and Bandit Billy like this.
  18. SS327
    SS327
    anthony myrick likes this.
  19. Transport wheels for gms
    They have DOT stamps
  20. guthriesmith
    guthriesmith
    My son decided to put the wing and parachute back on. Seems like cop magnet parts to me…
    enloe, porkshop, Okie Pete and 7 others like this.
  21. Bandit Billy
    Bandit Billy
    porkshop and anthony myrick like this.
  22. guthriesmith
    guthriesmith
    Sometimes wonder why I taught my boys to drive standards considering all the broken parts it seems we are dealing with regularly. :eek: Although, this one was more a Chinesium problem from what I see. So, built a better replacement considering we weren’t smart enough to save the original GM part when we put a new clutch master cylinder in a while back. Not sure I have ever seen a hydraulic clutch pushrod buckle and break quite like this…
    Squablow, porkshop, Okie Pete and 3 others like this.
  23. hotrodjack33
    hotrodjack33
    What do you do with your "work van" when you retire and no longer need a work van?
    You add 20" rims, JDM wheel flares, ground effects and an aftermarket WXR wing (narrowed 8 inches).
  24. JohnLewis
    JohnLewis
    Needs a bosozoku exhaust ^
    porkshop, Okie Pete and hotrodjack33 like this.
  25. 302GMC
    302GMC
    from Idaho
    All I got to add is a boring ol '66 Olds Jetstar.
    I was all happy that I could finally use the set of 5 on 5 Americans I've had for years ... the thing has Chev lug pattern !! HPIM7268.JPG HPIM7273.JPG
    1pickup, Squablow, Chavezk21 and 10 others like this.
  26. chevy57dude
    chevy57dude
    302GMC and Deuces like this.
  27. 302GMC
    302GMC
    from Idaho
    I don't know. 330 is what I'm guessing,; Q-Jet on it was optional.
  28. Greg Rogers
    Greg Rogers
    Thats not boring. Nice OLDS!!
    29A-V8, 302GMC, SS327 and 1 other person like this.
  29. guthriesmith
    guthriesmith
    Yep! Very nice Olds!
  30. J. A. Miller
    J. A. Miller
    from Central NY
    Jack, it needs some green on it.:rolleyes:
    29A-V8 and hotrodjack33 like this.
