Technical Vent wondow seal '42-'48 Ford
Discussion in 'The Hokey Ass Message Board' started by fordy6, Aug 4, 2024.
  1. fordy6
    fordy6
    Hello all,
    Does anyone have experience replacing the vent window seals on a '46 Ford? Does the seal go on first or the vent window? I remember chipping the old seal out because it was so sun baked and brittle. I do remember that the top hinge gets screwed on first. to add to my dilemma some teeth are broken on the window gear.
    Thanks, Mike Jackson
    istrum4u@cox.net
  2. Jim Bouchard
    Jim Bouchard
    The seal goes onto the garnish molding first then the vent window goes on second
  3. fordy6
    fordy6
    Thanks for you fast response Jim. Do I need to screw in the hinge first?
  4. Jim Bouchard
    Jim Bouchard
    Yes.
    The rubber has only a slot for the rubber to go through. The hinge needs to be installed first
  5. fordy6
    fordy6
    Jim, I can't put top the hinge in without putting the bottom through the slot first...I think I'm missing something here?
  6. fordy6
    fordy6
    It's so much erasier when you use liquid soap DUH!
    Thanks for your help Jim...
  7. Jim Bouchard
    Jim Bouchard
    Did you get it?
  8. fordy6
    fordy6
    Yes, well the p***enger side. Tomorrow's another day.
    thanks again Jim!
  9. Jim Bouchard
    Jim Bouchard
  10. fordy6
    fordy6
    Jim, Should I wait til the headliner is in before I install the back window and windshield?
  11. Jim Bouchard
    Jim Bouchard
    YES!!!
    Both get the upholstery tucked underneath the rubber.
    The windshield is not as important because the garnish molding helps cover it but most upholstery guys want it captured under the rubber.
    The rear window is for sure as that tucking helps keep the tension on the upholstery
  12. fordy6
    fordy6
    Thx again Jim,
    After wrestling with them all morning I got the rear quarter windows in...
  13. Jim Bouchard
    Jim Bouchard
    Great work. It’s an adventure for sure
    You should probably check with your upholsterer to confirm what he wants and expects
