Technical 3 deuces on SBC running out of gas??
Discussion in 'Traditional Hot Rods' started by 49Dodgeboy, Aug 5, 2024.
  1. 49Dodgeboy
    49Dodgeboy
    Let me start by saying I have read more threads here and everywhere else on running an SBC with 3 94's, probably way to much for my "simple" issue:
    engine: 327 L79 clone. 11:1, Crower Street beast hydraulic cam (L79 specs), camel humps with 2.02's,
    Old School Accel dual point. Offenhauser manifold, rebuilt 94 style 2100 carbs, progressive linkage.(about 60/40), red Holley electric pump regulated at 3.5#'s at the carbs. ( all used parts )
    Rebuilt TH400 2300 stall.
    a minute or 2 after I hit 3rd gear it just sputters like its running out of gas ?? I try to feather it but it finally just dies. Pull over, turn it off, turn it on and it fires right up. if I light foot it home is does the same thing.
    My gut tells me the red pump is shutting off. Could I be running out of gas on the center carb?
    old and confused
    IMG_3857.jpeg 5-18-24 hood install engine pic-1.jpeg 7-21-2024 gas pedal and throttle cable.jpg
    Tow Truck Tom likes this.
  2. Artwoodie
    Artwoodie
    Are running electric or mechanical fuel pump?
    Art
  3. 49Dodgeboy
    49Dodgeboy
    Holley red electric with no relay.
  4. lostone
    lostone
    from kansas
    I'd run a temp fuel pressure gauge where I could see it, wire tie to a wiper etc. Then go drive it and watch to see what happens.
    Also are you pulling any rpms when doing this? As in are you running up to say 5200 rpm and letting it shift then 5200 again when it starts acting up ? Or are you just taking off from say a stoplight or corner under "normal" acceleration?
  5. 49Dodgeboy
    49Dodgeboy
    Just normal acceleration. It revs like a mutha in park in the shop! gauge is a good idea thx
  6. Artwoodie
    Artwoodie
    Where is it located? I had the same issue with a Snipper pump. They do not **** very well. The pump needs to be located so gravity feeds fuel to the pump to work properly.
    SuperKONR, Tow Truck Tom and ClayMart like this.
  7. Oneball
    Oneball
    Next time it dies pull the wire to the fuel pump so it’s not pumping and see if it’ll start. If there’s fuel in the float chamber it will, if not it won’t.
  8. 49Dodgeboy
    49Dodgeboy
    its on the frame rail between ( and below) the fuel tank and engine.
  9. 49Dodgeboy
    49Dodgeboy
    good idea....thx Tim
    Tow Truck Tom and Oneball like this.
  10. hrm2k
    hrm2k
    Dump the electric pump and go with the stock manual pump. You will never regret that move. I had to do the same thing on my coupe. Ended my problems …I was using Stromberg 48’s
  11. 49Dodgeboy
    49Dodgeboy
    I can't, frame is in the way.......
  12. hrm2k
    hrm2k
    that is what grinders are made for.
  13. 49Dodgeboy
    49Dodgeboy
    trust me, I started that way... Using and old school Hurst style from mount it just did not fly.
  14. BJR
    BJR
    Is the gas tank vented or do you have a vented gas cap?
  15. 49Dodgeboy
    49Dodgeboy
    vented cap - already went through that too........... jumped out and opened that cap when it stalled...........no air
    Tow Truck Tom and BJR like this.
  16. Bandit Billy
    Bandit Billy
    As said above, electric pumps push gas they do not **** it. If your take pickup is on top the tank it makes it hard to provide a gravity feed to the pump. Installing a tank outlet lower on the tank is an option.
    Your pump is half down the frame rail, it needs to be close to and under the tank. I prefer them in the tank as that is where they are most efficient (pushing always), coolest and quietest. And quite frankly I don't like looking at them so another point for in the tank.
    19Eddy30 and Tow Truck Tom like this.
  17. 49Dodgeboy
    49Dodgeboy
    Well. My exit on the tank is on the low end of the tank but I understand what you’re saying. I will review location options.
  18. Doublepumper
    Doublepumper
    from WA-OR, USA
    Plugged filter...?
    SuperKONR, Tow Truck Tom, Tim and 2 others like this.
  19. 2OLD2FAST
    2OLD2FAST
    from illinois
    Mount a fuel pressure gauge where you can see it while driving ,that should tell the story .
  20. 49Dodgeboy
    49Dodgeboy
    Brand new, but I got the pump second hand and was told there is one inside?
    Tow Truck Tom and Tim like this.
  21. 49Dodgeboy
    49Dodgeboy
    That’s the plan
  22. wuga
    wuga
    I see you are running a fuel pressure gauge, the same one I run. This is probably the least dependable part on your whole car. I don't know what you have it set at or what the psi of the Holly is, but normally 97s like about 1.5-2 lbs. We just set up a flathead with a 6:53 blower and it ran out of gas at that psi. We installed a 4psi K&N pump and it worked perfectly. Just a thought, but you you say it revs high and you have a lot of fuel log, maybe you are draining the bowl. If you find the problem, keep us in the loop.
    Warren
    Jeff Norwell and Tow Truck Tom like this.
  23. clem
    clem
    Holleys seem to like 2&1/2 to 3 lbs pressure.
    Then there are things such as correct fuel float setting and sticking inlet valves which may also affect the original posters conditions, (although I am sure that he has checked that).
    That is one really nice looking automobile though !
    Neat colour scheme too.
    Got more photos some where ? - thanks.
    Tow Truck Tom and 427 sleeper like this.
  24. tomcat11
    tomcat11
    I think you're under carbureted for that engine combo, and the progressive linkage probably isn't helping. Could be ****ing the bowl dry under load. That's just my opinion which probably ain't worth one red cent:D
    Jibs, 19Eddy30 and Tow Truck Tom like this.
  25. Artwoodie
    Artwoodie
    I ended up installing a small K&N fuel pump. It was recommended by them and they ***ure me it would **** fuel out of the tank. It's doing a great job.
    Art
  26. Mr48chev
    An original Stromberg 97 has 167 CFM X 3 = a grand total of 501 CFM.
    Back in the 70's I had a 57 Panel truck with a 327 with an engle cam, Jahns 12.5 pistons, 202 heads and an early Corvette dual 4 setup. When I got it it would cruise along at well over the speed limit without a whimper but fog down on it and run though the gears and it ran out of gas before it ran out of gear. some searching found that who ever put it together used a natural gas fitting in the fuel line with a small orifice that restricted gas something crazy. I'd also be looking for any sort of restriction in the line from tank to carbs.
  27. 49Dodgeboy
    49Dodgeboy
    Thx Warren I appreciate the input. I sure will
  28. 49Dodgeboy
    49Dodgeboy
    Thx Clem. The input here has been fantastic. I have a lot to go thru now. My IG site has a ton of photos, you will be really surprised at what it looked like before . old_soul_rich. On IG
    clem and Tow Truck Tom like this.
  29. 49Dodgeboy
    49Dodgeboy
    All opinions are information to me, so thanks.
  30. 49Dodgeboy
    49Dodgeboy
    Thx Art. I will look into them
