Technical Little tips and tricks for garage hobbyists.
Discussion in 'The Hokey Ass Message Board' started by Ron Brown, Jul 30, 2019.
  1. 29A-V8
    29A-V8
    from wyoming
    Thought he got the point across, a little misspelling for effect is an art. There is a name for it, Fibber McGee and Archie Bunker were masters at it. When I tell my wife I pacificly want something and she dont understand me she calls me a maroon and some times worste. :cool:
  2. atch
    atch
    Magnetic trays and zip lock baggies:
    • We all know how handy those magnetic trays are when doing dis***embly work. I've got a dozen or so and need more.
    • Today I was doing some reinstallation of parts I had removed several months ago. I was again reminded how a baggie can keep all of the hardware for one specific chore together and prevents having to look for stuff; especially when re***embly happens in the sometimes-distant future. Tupperware works well for heavier screws and bolts. The containers that deli ham & etc. comes in are also handy.
    • Don't forget to keep a Sharpie handy to label parts/hardware. Especially if it's likely it will be some time before you use the parts again.
    • Even in my hardware drawers/bins I have several baggies holding screws and bolts. You know; things like stainless steel 1/4 20 bolts that you have very small quan***ies of and don't want to have them mixed up in your other 1/4 20 mild steel bolts. Again label with the Sharpie 'cause a year later you won't remember why there are a few screws in a baggie.
    alanp561, jet996, 61Cruiser and 13 others like this.
  3. j hansen
    j hansen
    From the Interweb,,,,,
    X-cpe, oldpl8s, LAROKE and 8 others like this.
  4. 69fury
    69fury
    from Topeka
    purchased like that or modified? i'd buy one
    -rick
    Six Ball likes this.
  5. BJR
    BJR
    What keeps the band with the jaws from slipping off of the jack, or is it welded from the factory?
    rattlecanrods and Six Ball like this.
  6. Six Ball
    Six Ball
    from Nevada
    That would get those old drums off! Yeah, you'd probably have to weld the bracket but with another set of arms it would be a neat little press.
  7. patsurf
    patsurf
    that is a very typical hydraulic puller-usually 10 ton and usually yellow
  8. j hansen
    j hansen
  9. RodStRace
    RodStRace
    Looks like they included some red loc***e on the threads for good measure!:eek:
    j hansen likes this.
  10. Doublepumper
    Doublepumper
    from OR-WA, USA
    Struggled with using a funnel to filter out some anti freeze and came up with this:
    Works great! I'm so proud of myself...:rolleyes:
    teach'm, alanp561, vtx1800 and 18 others like this.
  11. j hansen
    j hansen
  12. j hansen
    j hansen
    This was a new tool to me,looks interesting ,anybody used one ?
    jet996, Six Ball, 29A-V8 and 2 others like this.
  13. ratrodrodder
    ratrodrodder
    from Boston
    Those knots in your back won't stand a chance!
    alanp561, jet996 and Six Ball like this.
  14. RodStRace
    RodStRace
    How to get a 14" tire on a 15" rim!
  15. Six Ball
    Six Ball
    from Nevada
    Is that a pneumatic trombone slide?
    jet996 and 29A-V8 like this.
  16. clem
    clem
    had to use something similar today to get in a really confined space.
    1/4” ring spanner, (would have been nice to have a rachet 1/4” for this particular job)
    jet996, Tow Truck Tom, 29A-V8 and 4 others like this.
  17. rockable
    rockable
    I made myself a poor man's radius brake yesterday, aka pipe anvil. I think it's going to come in really handy. The small pipe is bolted on, so I can have different small sizes.
  18. WZ JUNK
    WZ JUNK
    from Neosho, MO
    The bolt on side is a good idea. I plan to make a bolt on small radius for mine. I think that if you made one of the original three bolt on, like you did, then you would be able to work further around the pipe. You have a good idea.
  19. Dave G in Gansevoort
    from Upstate NY
    Brilliant! Why not bolt both sides together? For that matter, just make it with nuts welded on the big pipe, and screw on whatever size needed... I think I'll give that a shot.
  20. rockable
    rockable
    Handling that larger piece of pipe and bolting it on with a flat washer spacer would be a job. I decided to just make the lighter pipes replaceable. These are 40" long.
  21. JD Miller
    JD Miller
    I could sell those BB headers on the local facespook market place
    29A-V8 likes this.
  22. willys36
    willys36
    Need a complicated mold for a fibergl*** part? Use Duct tape. Resin doesn't stick to the tape. Here are 'tape molds I used for Mysterion interior panels. Worked like a champ.
    Finished panels.
    GuyW, orbitup, mohr hp and 19 others like this.
  23. TwistedMetal
    TwistedMetal
    from Wisconsin
    I like this and need to build a tailgate. I think this tool would be perfect for the top and maybe bottom flanges. I have plenty of pipe laying around just not a large one. Not my truck just a tailgate image showing the area I'm thinking. upload_2024-9-20_13-18-19.jpeg
    rockable and Sharpone like this.
  24. RICH B
    RICH B
    Cut up an old telescopic hydraulic cylinder to get the different tube sizes for a pipe anvil long ago. Wonder if it is still laying around at my kid's house; probably hit the s**** yard by now.
  25. TwistedMetal
    TwistedMetal
    from Wisconsin
    I'm looking at my argon tank on my tig right now, but probably shouldn't cut that up. :p
  26. arse_sidewards
    arse_sidewards
    from Central MA
    If you live somewhere rural or suburban enough to have a town dump you can just drop things off at they've probably got a cylinder pile somewhere you could grab a few of if someone wasn't looking.
    TwistedMetal, Six Ball and 29A-V8 like this.
  27. j hansen
    j hansen
  28. arse_sidewards
    arse_sidewards
    from Central MA
  29. Good gravy!! So simple! So obvious, as though they were MADE for that.
    Ben
    29A-V8, Sharpone, Algoma56 and 4 others like this.
  30. atch
    atch
    Now I know what to do with those old rakes I've been saving; the ones I've been intending to put new handles in...
    brEad, nosford, LWEL9226 and 7 others like this.
