First Trip Down a Drag Strip
Discussion in 'Off Topic Hot Rods & Customs' started by Oneball, Jul 6, 2024.
  1. spanners
    spanners
    Sounded good. I bet it's not the last time you do it.
    Sharpone, Oneball and Deuces like this.
  2. Oneball
    Oneball
    Was looking at the timing slips, am I right it saying your ET does not include your reaction time? So in theory you could post a slower ET and still win by being faster to react?
    Sharpone likes this.
  3. 427 sleeper
    427 sleeper
    Exactly! The timers don't start until you do. ;)
    Sharpone, Deuces and Oneball like this.
  4. Oneball
    Oneball
    Thanks. Following on from that, in bracket racing does your “target time” include RT?
  5. 427 sleeper
    427 sleeper
    No sir, Reaction Time is simply a measure of how much of a headstart you got on your opponent, or how much he got on you without going Red, and is not accounted for in your dial-in or elapsed time.
  6. chicken
    chicken
    from Kansas
    Your 107 mph indicates that with everything "right" for drag racing you could run a 12.38 elapsed time. Lots of work to get there but the HP is there.
    Sharpone and Deuces like this.
  7. squirrel
    When bracket racing, if you want to win every time you need to get a reaction time of 0.0000, and run your dial in time exactly.
    If two cars run their dial in time exactly, the car that gets there first will win, unless he redlights. This where the racing is...getting off the line right as the light turns green.
    alanp561, 19Eddy30, Sharpone and 3 others like this.
  8. Oneball
    Oneball
    Really? I wouldn’t have thought there would be that much time to gain.
  9. RodStRace
    RodStRace
    That is only if the car is set up for drag racing. Since yours is a road car, you would have to make changes that would be detrimental to it's main use. It could 'split the difference' and be decent at both, but weight transfer at launch is not something that translates well to accelerating out of a corner.
  10. RmK57
    RmK57
    Your reaction is the time it takes you to break the staged beam when the green light comes on. Thats why you can leave somewhere on the last yellow to get a bit of a head start.
    Deuces likes this.
  11. RmK57
    RmK57
    107 mph and if your corvette weighs 3200 lbs. your making a little over 300hp. According to Wallace racing calculators.
  12. guthriesmith
    guthriesmith
    From what I heard in the video, you ended in third gear and you had more to go? If so, my guess is that lower gears would help as much as anything but not sure how those would work with the normal racing you do.
    SS327 likes this.
  13. Oneball
    Oneball
    It’s got a bit over 350. I’m imagining that traction and diff ratio limit it.
  14. Oneball
    Oneball
    Yep it’s 3.7:1 at the moment which is about right for circuits.
    Deuces and guthriesmith like this.
  15. chicken
    chicken
    from Kansas
    Absolutely, as does both front and rear suspension setup and design, shock absorbers and many drag race oriented things that would ruin the car for a road course. Your times are quite respectable, and especially for a first experience. The manual transmission is a challenge on the dragstrip compared to an auto with converter. Well done!
    guthriesmith and Oneball like this.
  16. Oneball
    Oneball
    A set of slicks would probably make a fair bit of difference I’d imagine. The Avons I run are a sticky road tyre but the GT40 guys will do the whole of the Spa 6 hours on one set of them so they aren’t that soft.
    427 sleeper likes this.
  17. swade41
    swade41
    from Buffalo,NY
    You could gain a lot just in your 60 ft times, little better burnout to get the tires a little softer and a little more rpm to get out of that bog that's happening.
    Oneball and 427 sleeper like this.
  18. Johnny99
    Johnny99
    Fun starts here!
  19. Oneball
    Oneball
    It’d be nice to get a perfect run and see what it’ll actually do.
    swade41, guthriesmith and Deuces like this.
  20. chicken
    chicken
    from Kansas
    Ah, the elusive Perfect Run. :D:D
    swade41, Deuces, twenty8 and 2 others like this.
  21. spanners
    spanners
    I've done between 600-700 p***es since I started drag racing at age 54, I'm now 67. My HA/GR has no electronic aids, manual gearbox with a street style clutch and I still haven't done a perfect reaction time. I've been close with 0.002 and a 0.001 red light but not the elusive 0.000.
    Deuces, 427 sleeper and Oneball like this.
  22. RmK57
    RmK57
    Perfect run may be a couple tenths better. With a stick shift car there should be some wheel spin but not excessive or not enough spin to bog the engine. Reaction time will have no affect on your ET.
    Oneball likes this.
  23. Oneball
    Oneball
    I was thinking perfect in terms of no bog or wheelspin.
    I think it should just drop into the 12.9s if I get it right.
    On of the sponsors of our race series has got a day at the strip in August so might go along for another try.
    SS327 and 427 sleeper like this.
  24. RmK57
    RmK57
    If you dead hook it will bog the engine so there has to be some wheel spin to keep the rpm up , but not so much spin that it slows your momentum. It’s a very fine line with a stick shift car.
    loudbang, Deuces and 427 sleeper like this.
  25. Oneball
    Oneball
    Going back for another go on Monday. Thought I’d give the car a once over.
    This, it turns out, was full throttle:
    No idea how long it’s been like that but I’m guessing at least the whole of this season. Wonder what difference it’ll make??
  26. RmK57
    RmK57
    Looks like the ****erfly plate screws are unthreading?
    swade41 and Oneball like this.
  27. Oneball
    Oneball
    Thanks
    I’ll check but I think that’s just a puddle of fuel.
    guthriesmith likes this.
  28. squirrel
    heh...Plan II would do that with the throttle linkage, it usually ran about a second slow. I finally figured out the permanent fix for the problem when the pedal arm broke off completely, after repairing that it was good.
  29. Oneball
    Oneball
    ****erfly screws are ok
    The cable bracket at the carb end has bent. I’ve got a throttle pedal stop so if it does it again I’ll beef up the bracket.
    Dick Stevens, SS327, swade41 and 2 others like this.
  30. swade41
    swade41
    from Buffalo,NY
    Having full throttle will liven things up a bit
    Dick Stevens, alanp561, SS327 and 2 others like this.
