Projects 32 5W Build - The $4K Swapmeet Body / The Old Chrome Coupe
Discussion in 'Traditional Hot Rods' started by NealinCA, Feb 2, 2023.
  1. NealinCA
    NealinCA
    I'll show you at the Roc...
  2. Anderson
    Anderson
    Godamnit.
  3. NealinCA
    NealinCA
    I can't show ALL of my cards...haha
  4. Tim
    Tim
    from KCMO
    lol good stuff.
    the exhaust looks fantastic. Did you make the flared tips? I don’t recall if you mentioned it already or not.
    31chevymike likes this.
  5. NealinCA
    NealinCA
    We flared them on my buddies tubing bender
  6. Tim
    Tim
    from KCMO
    Awesome
    31chevymike and porkshop like this.
  7. brady1929
    brady1929
    That exhaust looks killer.
  8. Ron Emerson
    Ron Emerson
    The Chrome Violet
  9. Ron Emerson
    Ron Emerson
    The Chrome Violet, thanks for posting everything you are doing to that beautiful 1932 Ford you are building. I have always wanted a Deuce but I had to settle for what I have now, a 1936 Ford Cabriolet. I have had a few 35s and 36s but I always loved. The 32. Thanks Ron
  10. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    As I said before, great build. As I watch you chrome and polish I'm thinking your not a kid anymore. Are you going to be able to crawl around and under this car to clean all the shiny? I'm knocking on the door of 80. I know for me that's why I'm powder painting more and shining less. Can't wait to see it at the ROC.
  11. justabeater37
    justabeater37
    Pretty sure it is just doctoring up the lower fronts to correct everything from rolling the fenders forward, but just purely speculation as I am silently following many of these subtleties.
  12. hotrodA
    hotrodA
    If we’re talking rear fenders, I sure Hope so. I’m dying to find out so I can do mine!
    31chevymike and Outback like this.
  13. NealinCA
    NealinCA
    Picked up some of my gauges today. Williamson's Instruments repaired the capillaries on 2 SW big logo temp gauges and converted a big logo fuel gauge to 12v. A couple more parts marked off the list.
  14. alchemy
    alchemy
    Do they have fresh rings or did they reuse your old ones? I need to find a new place that restores old SW’s cause my previous place closed down.
    31chevymike, porkshop and Outback like this.
  15. Outback
    Outback
    from NE Vic, Oz
    Beautiful.
    31chevymike and chryslerfan55 like this.
  16. NealinCA
    NealinCA
    All original parts, just cleaned and repaired.
  17. NealinCA
    NealinCA
    With the rear fenders rolled forward, the frame horn covers no longer fit. Josh and I came up with a plan to modify them, but keep them looking stock. Here's what we came up with... 86744.jpeg 86743.jpeg 87060.jpeg 87338.jpeg 87336.jpeg 87339.jpeg
  18. porkshop
    porkshop
    from Clovis Ca
    Neil, Your attention to detail is and always has been amazing....
    31chevymike, Outback and NealinCA like this.
  19. NealinCA
    NealinCA
  20. 19Eddy30
    19Eddy30
    from VA
    Alot of Detail here,
    I Originally thought the ***le 4K steel body it was going to be a car built for like 20 K ,,, All the money you saved on body,, 4K, The other 20 k is
    tied up / spent in Crome & parts ,detail, 40-60 k when done ,,,$$ spent in p*** collecting part to Present, with No labor cost ,,,
    Im not looking at my 32, looking at the pic above, I wonder why Ford never follow the same body line shape with the frame horn covers
  21. hotrodA
    hotrodA
    Very nice! What did you do with the front inset where it bolts to the frame?
  22. NealinCA
    NealinCA
    We retained the lower front part of the fender where it bolts to the frame and running board, and cut and spliced above that. It took some of @carrillocustoms metal working magic to piece it back together.
    31chevymike, cactus1, hotrodA and 6 others like this.
  23. dln1949
    dln1949
    Neat fix on the rear fenders, getting the rear of them up off the ground a little bit sure cleans up the rear view. I think it will be something like “oh that 5 window”, gonna be *****en.
  24. NealinCA
    NealinCA
    My dad was known to some as "Low-buck Chuck", so I was raised building projects from nothing. That's probably why I was attracted to this body in the first place. This project started off to be a low buck hot rod, as I didn't think the body would ever be good enough for anything other than primer. As it has progressed and I started to see the body had potential to become something nicer, the vision changed over time and then kind of snowballed into where it is headed now. I am still building it as low budget as I can, while at the same time trying to build out somewhat of a "lifetime" dream build. Yes, it has gone over budget, but I am still scouring swapmeets for parts and trading labor to make this happen.
    I have seen frame horn covers smoothed out and made to fit the body, but they look too "street roddy" to me. I really wanted to keep these looking factory, just tweaked to fit the forward swept fender. Something that could have been done on a 50's hotrod/show car.
  25. hotrodA
    hotrodA
    Thanks! I bet that was some work! Swallow hard and cut this perfect fender in two.
    31chevymike, Outback and porkshop like this.
  26. NealinCA
    NealinCA
    More progress on the frame horn covers. You can see the difference compared to an unmodified original pair
  27. NealinCA
    NealinCA
    I saved a nice filled shell off of another 32 project. I could tell it was done nicely, but couldn't believe that it was metal finished with no lead or filler. Definitely done by a master craftsman back in the 50's!
  28. Tim
    Tim
    from KCMO
  29. alchemy
    alchemy
  30. rod1
    rod1
    Not!
