700R4 Torque Converter Control (TCC)
Discussion in 'Off Topic Hot Rods & Customs' started by rockable, Aug 6, 2024.
  1. rockable
    rockable
    The original GM pressure switch that had a significant differential between the vacuum at which the contact closed and at which the contact opened, is no longer available. I have tried and looked at several different methods for controlling the TCC but, so far, have found none that work satisfactorily.
    1. A toggle switch for manual lock up. Works but is a pain in the *** when you're driving in hilly country. Best used for "tow mode" in a truck.
    2. Several vacuum switches have been tried and they all "hunt" at some point, regardless of how you set them.
    3. Bowler has a time delay module but it is not "load sensing". It merely has a time delay between when the transmission shifts to OD and when the Torque Converter locks up. It only "unlocks" when you downshift to 3rd.
    I am getting ready to try something electronic. I found several 12 vdc time delay relays that I think might work. Here is the one I ordered and at ~20 buck is very reasonable.
    https://www.amazon.com/dp/B097GLMDM3?psc=1&ref=ppx_yo2ov_dt_b_product_details
    My plan is to wire the brake light switch and an adjustable vacuum switch in series as the input to the module. (CH) The 12vdc input would be wired to that circuit and to the two DC connections. I would hook the NO connection to the TCC solenoid circuit, which includes a OD pressure switch that has to be made. The solenoid I have is internally grounded, so no other connections would be needed.
    I would set this up to have an 8 second (for starters) "on" delay to TCC. This would smooth the shift transition into OD. If you step on the accelerator and vacuum falls, the circuit would be broken and TCC would unlock. If engine load leveled off and vacuum increased to vacuum switch set point, TCC would lock up again in 8 seconds. This seems like it would smooth out the "hunting" that you get when you simply hook up a vacuum switch.
    Has anyone else tried something similar? Any advice?
  2. pprather
    pprather
    In the 1990's I put a 700R4 in a rod. The setup was like this info I copied from another forum. I'll try to see if I can find a parts source.
    The 12 volts can come from the IGN terminal on your fuse block or any other source of 12 volts. In my case I'm using a terminal on my horn relay to supply the 12 volts and a 15 psi pressure switch screwed into the 4th servo pressure tap (right behind the servo) to send that 12 volts to my solenoid. It automatically locks when it shifts into 4th and unlocks when it downshifts into 3rd.
  3. rockable
    rockable
    I've been using that setup for years, too. It works OK in lighter cars but my big old 49 Buick weighs a lot and I need a part throttle "downshift", not a 3rd gear downshift. Driving along at 55 mph on secondary roads, I generally just put it into 3rd. Scaling the mountains of West Virginia as I travel to Louisville and Columbus, it lugs the engine too much in lockup.
  4. pprather
    pprather
    Mine was locked only in fourth gear. When downshifted to third gear, either manually or automatically, the torque converter unlocked.
    Is that what you would prefer?
  5. pprather
    pprather
    Nope, start over.
    My kit had an internal, fourth gear pressure switch that I replaced and rewired per instructions.
    Worked as described above. Drove it 100k miles.
    This was in a lightweight Model A, but with a 4.3L GM V6, I needed the manual shift to third to power uphill occasionally.
    dogwalkin likes this.
  6. rockable
    rockable
    Thanks, Phil but I totally understand how this works. I usually use the internal pressure switch like the factory. I, also set it up so that it only works in 4th. I am wanting the TCC to unlock automatically, stay in OD and not "hunt" back and forth while driving near vacuum switch set point. The OE vacuum switches did that pretty well but they are no longer available, so i am trying to emulate what they did somewhat. Ideally, you would have a cut in pressure and a cut out pressure that was about 4-8" of mercury apart.
  7. pprather
    pprather
  8. pprather
    pprather
  9. pprather
    pprather
  10. pprather
    pprather
  11. pprather
    pprather
    I never used a vacuum switch. Never had a hunting situation.
    I've seen kits with the vacuum switch, but don't understand the purpose.
    Fourth gear, locked.
    Downshift manually or automatically, unlocked.
    Ned Ludd likes this.
  12. twenty8
    twenty8
  13. rockable
    rockable
    Thanks! I will digest this later today.
  14. 57JoeFoMoPar
    57JoeFoMoPar
    Without going through the info above, my experience with the 700R4 and a tall rear end ratio (3.08) is to leave the converter unlocked. I put the lockup solenoid on a toggle and switch it on when I jump on the highway. It almost acts like a 5th gear, drops my RPM about 250 rpm. My setup is also in a big, full sized car, and honestly would benefit from a numerically higher rear end ratio, since the highway cruising RPM hovers at or below the engine's power band in lockup.
    pprather likes this.
  15. 6sally6
    6sally6
    Is my 4L-60 transmission in my 91 S-10 the same as a 700 R4 OR is it a 200R ?
    Always get corn-fused.......
    Thx
    6sally6
  16. Kerrynzl
    Kerrynzl
    @rockable
    Add a switch in-series with the brake and vacuum switch and use vacuum switch without time delay.
    If you're driving at a pace where it's jumping in-out of lockup simply switch it off.
    An 8 sec time delay will end up ending in tears [thrown out]
    At 70 mph you would cover 273 yards in 8 secs before it locks up.
    4L60 is the new designation for the 700 R4
    GM upgraded the '700 over the years until eventually the 4L60 [and the 4L60E]
    You are better off with the 4L60 [the last of them before they went electronic]
    twenty8 likes this.
  17. rockable
    rockable
    We will see. 8 seconds is a starting point. It's adjustable. I think that the timer will reset when the pressure switch "hunts", leaving the TCC unlocked until engine load evens out above vacuum swittch setpoint. If that happens, 3 or 4 seconds might be reasonable. I've done the manual switch on several cars. It's not what I want on this one.
  18. twenty8
    twenty8
    Lots of conversions overlook this important little piece. This is the part you are missing. Put one of these in the vacuum tube going to the vacuum switch. It simply delays the vacuum change to stop the tcc hunting in and out of lockup. GM had already solved your problem for you. Junkyard excursion time...:)
    David Gersic and Kerrynzl like this.
  19. Kerrynzl
    Kerrynzl
    If you wire it so the TC stays locked on for a delay, Also wire a "flat to the floor" disconnect [kickdown switch] to the gas pedal. Connect this "in-series"
    Sometimes you need that instant disconnect of the TC.
    You can also buy 12v 10a [5 pin] timer adjustable relay[these can be switched from delay on, to delay off]
    These can be adjusted between 0.5 secs and 6 hours delay
    Narva part# 68076
    here is the instruction pdf
    https://www.12voltplanet.co.uk/user/downloads/User Guide For Adjustable Delay Timer Relay 12V & 24V 10A.pdf
    They are popular for integrated DIY turbo timers.
    twenty8 likes this.
  20. rockable
    rockable
    When you put your foot to the floor, it downshifts to 3rd, automatically disengaging the TCC due to pressure loss on the OD pressure switch. I do understand how these transmissions work. I'm just looking for a more readily available solution that works. I've already spent 20 bucks for the time delay relay which will only be set for delay on. I already had the vacuum switch, so its gonna cost me 20 bucks to try.
    That little volume chamber would probably work, especially if it has an orifice in it but I don't have a part number and junkyards with old cars are few around here.
    Kerrynzl likes this.
  21. pprather
    pprather
    The vacuum delay valve (little black and blue guy shown above) looks like acdelco #14020691.
    We need the Standard Motor Parts or another cross reference number, as it is no longer available from GM.
  22. twenty8
    twenty8
    Standard Motor Parts DSV35, or any with around an 8 second delay.
    @rockable is correct about the 700r4's needing an 8 second delay.
    A time delay relay will give the same effect.
    rockable likes this.
  23. rockable
    rockable
    DSV35 and 14020691 appear to be made of unobtainium.
    twenty8 likes this.
  24. pprather
    pprather
    More cross reference numbers, but no current source.
    GM part# 14020691 --- Discontinued
    ACDelco # 214-479 --- Discontinued
    Standard # DSV35 ---- No one stocks and haven't been able to find on-line
    BWD #EC342 --- No longer available from manufacturer
    twenty8 likes this.
  25. dogwalkin
    dogwalkin
    from tn
  26. 6sally6
    6sally6
    Since I consider A/T "magic-with genies inside them"..I have had my 4L-60 rebuilt by a pro when the "sun gear??!":oops: broke. He installed a Corvette servo (whatever that does) and heavier-duty bands and other stuff.
    I run B&M Trick Shift fluid because...........I always have.
    My only complaint about the ****** is...the govenor lets it shift into 2nd gear about 12 mph...and 3rd about 18-20 !
    The 4.3 handles it OK I guess but I would like it to hold itself in each gear a little longer. I also had a shift kit installed and it as nice firm shifts..especially from 1st to 2nd ! My tired(250,000 mile)4.3 will still bark the tires on the shift!!
    Once-a-kid...always-a-kid !!
    6sally6
    ekimneirbo likes this.
  27. rockable
    rockable
    Have your builder tune your governor with this kit.
    https://www.summitracing.com/parts/bmm-20248
  28. pprather
    pprather
    Before using the governor kit, try tightening the cable a little more, to get later shift points. @6sally6 .
  29. Kerrynzl
    Kerrynzl
    Try Ford D32E-AA
    Also lot of vehicles use vacuum delay of vapor canisters [vacuum is vacuum]
    But personally I think your timer relay idea is worth experimenting with. [it is tuneable]
    Brain fade on my part :D.
    You're wanting delay switching on.[engaging lock-up]
    This method would get rid of the annoying in-out engagement surging.
    Having a switching on delay mode will still get instant disengagement with vacuum drop [kicking down]
    You want the T/C to be unlocked before it kicks down or it will be too violent.
    twenty8 and rockable like this.
  30. twenty8
    twenty8
    Hey @rockable , please keep this thread going when you install the time delay gizmo. I am interested to know the outcome, good or bad. I can't see why it won't work, but real feedback is always a plus.
