Hot Rods Blowing this thing apart
Discussion in 'The Hokey Ass Message Board' started by nochop, Feb 28, 2022.
  1. @nochop where does the line from the intake go, once it gets to the other side of the firewall?
  2. nochop
    nochop
    from norcal
    Hi Kelly. Line tees off to go to the t400 trans and vacuum gauge.
    HOTRODPRIMER and Kelly Burns like this.
  3. Thanks for clearing it up for me!
    lothiandon1940 and nochop like this.
  4. nochop
    nochop
    from norcal
  5. nochop
    nochop
    from norcal
  6. nochop
    nochop
    from norcal
    Nibbling away at it IMG_7357.jpeg IMG_7355.jpeg IMG_7349.jpeg IMG_7345.jpeg IMG_7346.jpeg
  7. Tim
    Tim
    from KCMO
    Looking good
    Kelly Burns and nochop like this.
  8. nochop
    nochop
    from norcal
  9. nochop
    nochop
    from norcal
  10. Tim
    Tim
    from KCMO
    Looks beefy! You’re getting closer!
  11. nochop
    nochop
    from norcal
    Thanks, I hope it works
    HOTRODPRIMER and Tim like this.
  12. nochop
    nochop
    from norcal
    Body guy called an said get ready, going to prime 74553446996__B9937159-AE2E-447E-A9FF-7770D9A865FC.jpeg 74553445696__B042C2FB-D32A-48A1-9ADD-D1600BD9CC3E.jpeg 74553442695__52FEC5E0-C88C-4A7C-BBC1-338998472E77.jpeg 74553441643__DAE2B777-07B6-4136-B06B-08160F35570A.jpeg 74553444703__16B76DAC-CA2B-4FE6-AD8C-98E206B2BB6F.jpeg
  13. sdluck
    sdluck
    Sweet
    nochop likes this.
  14. nochop
    nochop
    from norcal
  15. nochop
    nochop
    from norcal
    I used this **** to restore the brake pedal. It’s been on the car since my dad built it in the late ‘50s IMG_7402.png IMG_6968.jpeg
  16. nochop
    nochop
    from norcal
  17. nochop
    nochop
    from norcal
    More body shots IMG_6975.jpeg IMG_6974.jpeg IMG_6973.jpeg IMG_6972.jpeg IMG_6971.jpeg IMG_6970.jpeg
  18. nochop
    nochop
    from norcal
    Mechanical gauge lines mocked up for the hydraulic shop to do their thing. IMG_6994.jpeg IMG_6996.jpeg
  19. nochop
    nochop
    from norcal
    More dash details. I have an idea on how I wanted the fire wall to end up. Sometimes a hair brain idea could or couldn’t work out. IMG_7005.jpeg IMG_7004.jpeg IMG_7003.jpeg IMG_7002.jpeg IMG_7001.jpeg IMG_6999.jpeg IMG_7006.jpeg
  20. nochop
    nochop
    from norcal
    I got my gauge (vac, oil pressure) lines back. Those things are a bit stiff IMG_7012.jpeg IMG_7011.jpeg IMG_7010.jpeg
  21. nochop
    nochop
    from norcal
  22. vtwhead
    vtwhead
    Are you intending to use silicone brake fluid? If so, that brake switch may only last a little while. Many have used a unit from Harley Davidson that apparently works with Dot 5. I went thru three units on my 37 while I had it but switched to a manual electric switch on the 31.
    nochop and milwscruffy like this.
  23. nochop
    nochop
    from norcal
    No just going to run dot 3. I may go to a mechanical switch on the pedal. I noticed that hydraulic switches are slow to react or that switch does.
    HOTRODPRIMER likes this.
  24. swifty
    swifty
    I would definitely fit the mechanical switch. I started with a hydraulic switch and Dot 5 fluid on my 32-5 window as it was easier to fit but after 2 trips I changed to a mechanical switch. Apparently the brake lights were only on when I had my foot hard on the pedal. Got rear ended before I changed the switch, luckily no major damage. Thank God for those plastic bumpers on modern cars. Only had to re-spray the spreader bar.
    nochop likes this.
  25. nochop
    nochop
    from norcal
    Yup, that’s what I noticed, the hydraulic switch was put on during the first build 20+ years ago. I’ll pull it and plug it next week prior to filling and bleeding. I want to get that done before the body arrives. Yay!
  26. nochop
    nochop
    from norcal
    Light switch pull, guess what I resourced IMG_7051.jpeg IMG_7052.jpeg IMG_7053.jpeg
  27. patsurf
    patsurf
  28. nochop
    nochop
    from norcal
    Actually there is a 12 year old neighbor kid into recycling scored it for me. Part of a surplus haul.
    HOTRODPRIMER and lothiandon1940 like this.
  29. nochop
    nochop
    from norcal
    HOTRODPRIMER and guthriesmith like this.
  30. 427 sleeper
    427 sleeper
    You'll have that on your bigger jobs... ;):cool::D
    nochop and SS327 like this.
