Projects 38 Willys with 8BA power
Discussion in 'Traditional Hot Rods' started by 1/2done, Jun 27, 2022.
  1. 1/2done
    1/2done
    from Ohio
    I found indoor storage for my roadrace car so garage space was available to start on my Willys. First order of business was pressure washing everything out that might want to kill me.
    20220604_145246.jpg After I got the front end sheet metal removed I cut the firewall until the motor fit and the headers cleared the steering box. 20220618_132853.jpg
    Once I figured that out I fabbed some motor mounts and a trans mount/x-brace. 20220625_163323.jpg 20220627_211056.jpg 20220627_211157.jpg
    Now that its all fabbed and tacked I'll remove everything to finish weld.
    No time frame in mind, just working on it when I'm not working on my coupe or my house or any other number of projects I got myself into. And it got an engine crate out of my way and a T5 out of the foyer. The latter made my wife happy.
    Toms Dogs, Manostihl83, Tim and 13 others like this.
  2. 1940Willys
    1940Willys
  3. 19Fordy
    19Fordy
    That looks like either an 8BA or a 1CM with a mixture of both parts. Water pumps, intake and carb are 51 Merc.
  4. 1/2done
    1/2done
    from Ohio
    So are the heads
  5. 1/2done
    1/2done
    from Ohio
    No, I've been working on my coupe hoping it will move under it's own power soon. I need to post an update over there.
  6. 1/2done
    1/2done
    from Ohio
    Finally working on this again. Goal is run, stop and steer and take it to the Bellefontaine Hillclimb instead of my Camaro.
    Ch***is is a complete, plumbed roller
    Firewall is ready for finish welding, body is stripped and floor is Ospho coated top and bottom, it's getting sprayed with Raptor Liner
    20240810_145510.jpg 20240810_145441.jpg 20240810_145532.jpg 20240810_145522.jpg
    The hillclimb is in 2 weeks so it's a tall order. I'm on day 9 of 11 days off work, I probably should rest at least one of them. Once this is together the coupe is coming back over.
    captaintaytay, Tim, RMR&C and 5 others like this.
  7. 1/2done
    1/2done
    from Ohio
    Oh, and I also have this waiting in the wings. Because God knows I needed another project
  8. 51504bat
    51504bat
    Hopefully it has a 4" crank. Merc heads on a 3 3/4" crank 8ba lowers the compression. Best option for stock Ford heads would be EAB's with or without a 4" crank. JMO
  9. 1/2done
    1/2done
    from Ohio
    It has EAB heads on it now
  10. Needs a Hilborn injection. Hehe.
    warhorseracing likes this.
  11. 1/2done
    1/2done
    from Ohio
    I've been working on the Willys off and on between house and other projects. Getting close to wiring and fire up.
    hanging from the hoist so I could lay under it and spray epoxy primer and Raptor Liner
    I mixed up some red oxide and hot rod black primers to get something close to Kondar.
    Putting the body back on the frame alone was a real day at the beach
    More Progress. 20240929_161809.jpg 20240929_161939.jpg 20240929_162314.jpg 20240929_162435.jpg 20240929_165105.jpg
    Next project is cleaning up the hood and front fenders so they can be fitted and bolted on. Right now the goal is move under it's own power, bodywork will come later. Once this will move without me pushing it, the coupe will get the same treatment.
  12. elgringo71
    elgringo71
    I’m following your thread. I really like what you have done so far.
  13. 1/2done
    1/2done
    from Ohio
    Well it stops, steers and runs briefly due to no coolant. I'm waiting for a piece of tubing so I can modify the outlets on the radiator. The sheetmetal is all hung and bodywork will come at a later date.
    Everything is wired, fused and run to termination points.
    The glove box doors give access to the fuse/relay panel and master cylinders and are held in place with a single Dzus fastener.
    Engine compartment is relatively together, a little tidying up will come later.
    I hope to have the cooling system ****oned up this week and get the 40 in the garage to make it run, stop.and steer. I've got storage for my roadrace car again so nothing will have to sit out in the weather.
    Toms Dogs, rod1, Ricco39ford and 6 others like this.
  14. roseville carl
    roseville carl
    kool job so far.......
    1/2done likes this.
  15. Tim
    Tim
    from KCMO
    Rad!
    1/2done likes this.
  16. deathrowdave
    deathrowdave
    from NKy
    Love the handle / pin on shop crane
  17. 1/2done
    1/2done
    from Ohio
    Lol, that was the result of the replacement cylinder having a smaller hole than the original, and a short, useless SnapOn breaker bar.
  18. 1/2done
    1/2done
    from Ohio
    The wheels and tires I had on were from my 40 Ford coupe. I decided they needed to go back on it. I had 15" Torque Thrusts I had taken off my Camaro, I used the 15x8s off the rear and bought 15x6s and tires for the front. The rear tires are pretty thin and will get replaced with white letter in at some point in the future.
    I got the fuel and cooling systems ****oned up. The stock distributor needed a lot of work, so I opted for a Mallory Unilite. As soon as Ohio isn't a frozen hellscape, I'll get it tuned. It has moved in and out of the garage under it's own power, so it does run, stop and steer.
  19. 1/2done
    1/2done
    from Ohio
    I've been working on it solid for the last couple weeks to get it to the point of being drivable because I made a wise *** remark about taking it to the hillclimb. Now I'm being held to it. It's probably going to be slow and handle like a nun carrying a mattress, but I'm just going to have fun and hang out. I'll probably get lumped in with muscle cars or fast foreign **** anyway.
    I had to make lower sections for both rear fenders. It was like welding kleenex because the metal is do thin. It'll get leaded at some point in the future.
    I got the rear firewall made and everything in the trunk secured.
    And I got the front and rear gl*** installed. I've roped in windshields alone before, easy when it's from the outside in. But theses go in from the inside and fit really tight, so it was a 2 man 1 hour job.
    I still have some loose ends to take care of, but for the most part, its hillclimb ready.
    Algoma56, Chucky, CSPIDY and 9 others like this.
  20. rod1
    rod1
    Such a great project! I would love to see a Video of that runnin up the Hill.
    1/2done likes this.
  21. Fogger
    Fogger
    Terrific ac***ulation of great parts. Excellent project and vision. Good luck at the hill climb!
    1/2done likes this.
  22. Great project! Good times ahead.
    1/2done likes this.
  23. Handle like a nun carrying a mattress!! I like that!
    1/2done likes this.
  24. 1/2done
    1/2done
    from Ohio
    Well I made it to the hillclimb, nowhere near finished, but functional. We got 4 runs at it. After my second, I was done. I built a hot rod, not a road racer. It was sketchy as hell, especially with 12yr old tires on the rear, lol. It ran good and had decent power, but it kept trying to rotate the rear end around in the decreasing radius right hander before the finish. After my second run I decided the car and I were un****hed, quit while I'm ahead. The only other car in my cl*** was a Packard LaCarrera Panamericana race car from the Packard museum in Dayton. I figured he'd be way faster, but he wasn't. I won my cl***.
    The Packard.
    There's a designated hot rod cl*** now, so I'm thinking about taking my 40 Ford coupe next year. V8, 4sp, 3:50 gears on a spool and skinny bias plys. What could go wrong?
    CSPIDY, rod1 and warhorseracing like this.
