Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. gimpyshotrods
    gimpyshotrods
  2. Looks like you've got it, can you come to Kentucky and gap out my 55? :D
    Truckdoctor Andy and 427 sleeper like this.
  3. guthriesmith
    guthriesmith
    Reminds me of something I found last week inside an enclosed driveline. 12 bolts between both ends of the driveshaft and two loose with no Loc***e.
  4. gimpyshotrods
    gimpyshotrods
    Sure.
    Anything but another early Falcon!
  5. My door to fender to rocker is screwed on the driver's side. The fender has been patched on, but I'm just about to go wild with a cut off wheel and make my own gaps lmao
  6. gimpyshotrods
    gimpyshotrods
    That is how it is done. Cut and weld.
    I cut and cap where they are too narrow. I add TIG rods where they are too wide.
    My Falcon was built with a HALF-INCH gap between the trailing edge of the hood and the cowl. There are now two rows of 1/8" TIG rods there, and I even made a new drop filler panel to correct the whole leading edge.
    The p***enger door does not line up properly line-up with the dashboard, too. It is just made wrong. That entire feature will need to be rebuilt. It is blatantly wrong.
  7. Dick Stevens
    Dick Stevens
    You got to do what you got to do!
  8. saltflats
    saltflats
    from Missouri
    Not sure on the total of p***es. My buddy got this as a roller and he has made 17 p***es in the car.
  9. choptop40
    choptop40
    Made cardboard template for the door panels.. Not sure whats the best material. image.jpg
  10. fastcar1953
    fastcar1953
    Putting nova back together. 5 lug wheels. Waiting on new cragars. Those are just rollers. Good bye 13 inch 4 lug. 454818887_8430022333688645_8656538707070357330_n.jpg 455048852_8430021890355356_1564657428824480086_n.jpg 455112218_8430020510355494_5899595850291137653_n.jpg 455213378_8430021423688736_4279199464519475969_n.jpg
  11. chevy57dude
    chevy57dude
    @fastcar1953 - I always thought the proportions of the early Chevy II / Novas were just right. So many more wheel choices now with those 5 lugs. Really liking the car.
  12. fastcar1953
    fastcar1953
    Looking at cragars or astro supreme. Surprising not much in stock or have the right offset. I ordered 15x7 with 4 inch backspace. Cragar s/s. Going with 215/75/15 tires.
  13. Personally, I go to Lowe's and buy the utility board. It's not much over 1/8" thick, kinda similar to thin luan, about $10 for a 4X8 sheet.
  14. OK maybe it's been a bit since I bought a sheet. Don't you love this economy? Screenshot_20240811-213643_Samsung Internet.jpg Screenshot_20240811-213634_Samsung Internet.jpg
  15. Hey Brother, the car is looking great, that Benz is beautiful, and I really dig the color on the 39 Chevy.
  16. Thanks man, that's 69 Chevy garnet red.
  17. choptop40
    choptop40
    Thanks Lloyd....Digging the Delivery build...
  18. fastcar1953
    fastcar1953
  19. lumpy 63
    lumpy 63
    After years of enduring hand crank and battery powered ring grinders I finally bought myself a real one. Used it on the 383 build today. 20240813_192518.jpg
  20. lumpy 63
    lumpy 63
    20240817_165421.jpg 20240817_165526.jpg Got the bottom end of the 383 done. These take me way longer with all the block grinding and clearance checking+ file fitting the rings ...my fingers are also a little sore from the spirolockso_O
  21. fastcar1953
    fastcar1953
    Took the car for a short drive today. New rear end is in. 5 lug wheels. Oh yeah. 455663945_8460617043962507_1907064972987227302_n.jpg
  22. saltflats
    saltflats
    from Missouri
    I hear what your saying about the spirolocks, I try and remember to trim my fingernails after one of those jobs same with automatic transmission rebuilds.
    lumpy 63 likes this.
  23. lumpy 63
    lumpy 63
    20240820_165254.jpg A little more 383 progress, cam degreed and test fitting a few pieces. I'll order pushrods next and ****on it up.
  24. JD Miller
    JD Miller
    Playing with Ospho.... Found out it dissolves 50 year old acrylic enamel original chevy paint...... gotz to get some epoxy primer on there
  25. I've got an interference problem with the lower radiator hose and the fan belt, and no one to blame but myself. I decided to use a late '60s sbf righthand lower outlet water pump on my 351W because it might save a few bucks by getting a more common radiator set up for sbcs. I made a new alternator bracket that I thought would work. It just barely doesn't (maybe by a half inch) even after the third modification of the alternator bracket. I have tried several pre-shaped radiator hoses and none so far have solved the problem individually. Advice from the H.A.M.B. community says piece together two hoses with an aluminum coupler. Haven't gotten the coupler yet but would rather get a 1-3/4 inch aluminum C-tube that could bend around the fan belt. Those don't seem to exist and I have limited welding skills. Is it time I learned to weld aluminum? Find someone who is skilled in aluminum welding? Abandon this whole route and go back to the stock water pump with a lower left discharge and buy another cheap aluminum radiator to accommodate that? I know the joy of hotrodding isn't that it is just "plug and play," you gotta use your brains and solve problems in three dimensions. But I'm getting old, lazy and less patient by the day. Got any ideas not in play?
  26. lumpy 63
    lumpy 63
    Can you give us a few pictures of what you need? I can weld aluminum But need a better Idea of what your trying to accomplish.
  27. DDDenny
  28. choptop40
    choptop40
    Removed the 350 engine and M20 4 speed transmission ...Transmission going in a off topic Trans Am....Now the fun begins,,,clean up engine compartment . bolt up the 400 turbo to the 350 and set it back in 5 inches closer to the firewall... 0873610E-B076-4249-B3E2-0855192A879C.jpeg View attachment 6163030 60F91342-E0CF-49CB-941A-8D9DD51A448C.jpeg 177A03AB-54FB-40FA-AFD5-254D19DA87E6.jpeg A1358594-3F23-4008-82E5-42C12E47C9F7.jpeg
  29. IMG_2304.JPG I'm getting long-distance help from lumpy 63 on plumbing the lower hose between my radiator and water pump on my 351W. I had a fan belt that wanted to argue with the lower hose about a point of physics, something about two objects occupying the same space at the same time. Got the right part ordered now (thanks, Colin) and should see it soon, then onto plumbing the transmission cooler lines, wiring and start up. Someday I'll show a little more of this 50+ year '29AA project. For now, this is what today's challenge has been.
  30. lumpy 63
    lumpy 63
