Projects Grill help
Discussion in 'The Hokey Ass Message Board' started by Cory1940 buick, Aug 9, 2024.
Tags:
  1. Cory1940 buick
    Cory1940 buick
    What goes in these holes to attach the grill?
  2. JohnLewis
    JohnLewis
    IMG_0537.jpg IMG_0536.jpg I'd ***ume some type of clip similar to this.
  3. alanp561
    alanp561
    They are called Tinnerman nuts
    lothiandon1940 and JohnLewis like this.
  4. JohnLewis
    JohnLewis
    ^ Thank you, couldn't think of the name had to google clips until I found what I was thinking about lol.
  5. Lone Star Mopar
    Lone Star Mopar
    I've seen them listed as J Nuts & U Nuts as well. Around here they sell them in the help section at the parts store.
    NoSurf, lothiandon1940 and 49ratfink like this.
  6. 302GMC
    302GMC
    from Idaho
    Probably the grille casting has studs threaded into it, & nuts with washers hold it in. That's ***uming the grille is cast, of course. Buick grilles were usually cast in that period.
  7. ^^^^ what he said is correct. The grille is a cast unit with a right and left side. Uses threaded studs, washers and nuts to attach. Use either lock washers or Nylock nuts to keep them from coming loose. Mega bucks to get one chromed.
    Easier to install with two people. Lightly snug the one at the two o'clock position (driver's side) or ten o'clock (p***enger side) first to align the halves.
    Most likely you have some studs broken off flush with the hole in the grille back which will have to be removed. Do not use stainless steel studs.
    302GMC and alanp561 like this.
  8. Cory1940 buick
    Cory1940 buick
    all the studs in the 2 halves are gone I tapped the holes out just trying to figure out what held them in I guessing just use washers??
  9. Fender washers work best as the holes in the fenders are oversize to allow for adjustment. Nylok nuts give a cleaner look than lock washers. I will PM you.
  10. '29 Gizmo
    '29 Gizmo
    from UK
    Lots of different terms but I buy them as chimney nuts.
  11. jimmy six
    jimmy six
    Grille
    Bandit Billy likes this.
