Projects 34 Pickup New Project - So many missing parts!
Discussion in 'Traditional Hot Rods' started by NeedFiber, Mar 13, 2024.
  1. 51 mercules
    51 mercules
    Too much stuff going on. There's no motor or trans in it. I have a 1946 59AB motor for it that needs to gone through and a 39 trans for it.
    Outback and 51504bat like this.
  2. NeedFiber
    NeedFiber
  3. Jim Bouchard
    Jim Bouchard
    I’m pretty sure those mount on the frame in the center of the opening about where the handle is located to help hold the hood in position and from being pushed towards the engine.
  4. HOTRODRONNY
    HOTRODRONNY
    I have a 33/34 Ford Walker radiator for sale 200.00 replaced the one on my 34 Ford with a new one with the air con part installed let me know if you have interest
  5. NeedFiber
    NeedFiber
    What's the engine that Walker is made for?
  6. NeedFiber
    NeedFiber
    Gettin there on aligning the hood/grill shell... but I need some info on the lacing. On the cowl does it go in the "trough" or in front of the trough? I have many empty screw holes in front of the cowl trough but at the bottom, I don't see anything that would catch the J hooks if you were to run in in front of the trough.
    The shell looks pretty straight forward other than there is a ridge in the sheet metal that would run under the lace top to bottom on both sides. Seems like it would make it that much harder to keep the lace in that location. The J hook holes basically set the lace to run over that ridge. Anyone got pics??
    Thanks,
    Dave
  7. Jeff34
    Jeff34
  8. NeedFiber
    NeedFiber
    Jeff, you have any J hooks being used on the cowl lacing? My kit came with 4 but I dont have any slots. I'm thinking its used on other years etc. One size fits all kinda deal.
  9. Jeff34
    Jeff34
    Don't know. Haven't looked. What do they look like?
  10. Deuce Lover
    Deuce Lover
    I have the repro J hook kit that you can have but to far away .Go on www.fordbarn.com ,which is Ryans sister site for more help.Experts are there.
    Here is a pic of them. They are included in the lacing kits sold by all the vendors. I have a set of latches and window regulators to sell 20240828_094420.jpg if you need them
  11. NeedFiber
    NeedFiber
    Deuce, sent you a message
  12. NeedFiber
    NeedFiber
    Does anyone have a better seal they found to use on the grill shell vs. the lacing that comes in the Vintique grill shell lacing kit? Its much to thick and has no channel to ride the "hump" that runs down the center of the shell sealing flange. The lacing wants to either run in front or behind the hump and if you place it on the hump the hood sticks up about a fat 1/4" too high. See pics.
    Toms Dogs likes this.
  13. alchemy
    alchemy
    Original stuff is not supposed to ride on top of the ridge, it’s supposed to fit in the rearward groove. Might want to crush it a bit in the vise before installing.
    pprather likes this.
  14. NeedFiber
    NeedFiber
    The problem is the U clips aim it at the ridge, it will work its way rearward but I thought that looked dumb/ incorrect. I ran it through my bead roller... one of em popped lol.
  15. alchemy
    alchemy
    Maybe it’s different than 32 stuff that I’m familiar with. I do know 33-34 p***enger grille welting has a groove in the middle. But it’s held onto the flat p***enger surface with split rivets along the whole length. Not a clip at each end like the commercial does.
    Looking back in this thread you can see how the welting fits on Jeff34’s truck in his pics. Right in the rearward groove, running over the mounting screws.
  16. NeedFiber
    NeedFiber
    Ok I'm back at it! Holidays are over and its time to swing the hammer. Giving up on the hood/ rad shell for now. Lets talk about doors seals. Can anyone tell me where the bumpers go and how many there are? On the door or cab? These doors were stripped so I'm needing bumpers and seals (looks like there was one seal along the bottom inside edge?), gl*** channels and the bar that the gl*** rests on. I have latches and regulators. Thanks!
  17. NeedFiber
    NeedFiber
    Need some help on finding a post! I somehow ended up seeing a post on here for a 34 Ford pickup that was for sale. A gorgeous gold metallic finished hot rod. Flatty, wide whites, white with black interior, 37 Ford taillights with Zephyr lenses, listed for around 65K and sold for 55K. Can anyone point me to that post? I of course closed the page and damn if I can find it! Thanks, Dave
  18. RodStRace
    RodStRace
    Didn't see the for sale one, sorry.
    You keep having fitment issues with your front sheetmetal.
    It's been suggested that you start with the cab mounting, which is a good point. However, while the sheetmetal looks good but loose on the frame, it would be a good idea to check the frame for straightness first. You'd hate to get it all set up only to find something off and fix that only to redo the alignment.
    https://www.bing.com/images/search?...34+ford+pickup+measurements&form=IGRE&first=1
  19. NeedFiber
    NeedFiber
    Hoping you fine gents can point me towards that gold 34 pickup referenced above.
    @ RodStRace, body is on with proper wood kit and shimmed so the doors close/ align very nicely. The frame is pretty darn nice and in most of its original pain. I don't see any crash damage but your correct in that you never know. I'll inspect further when I remove the cab entirely.
  20. NeedFiber
    NeedFiber
    What years of tailgates didn't have the Ford name on them? Mine does not have it. Got a local guy selling one that he states is a 34 and it has the Ford name on it. I'd like the Ford name personally. Its good looking script.
  21. Taboo56Chevy
    Taboo56Chevy
    All wide bed 31 through 34 tailgates lack Ford script. They have the 3 long hinge brackets and two rectangle beads. 35 was the first year of the script on the tailgate.
    Jeff34 and Hotrodmyk like this.
  22. NeedFiber
    NeedFiber
    Any idea what years 35 and up will fit the 34 and older? I know I can measure and will but just curious.
    Thanks, Dave
  23. Hotrodmyk
    Hotrodmyk
    35 fits 34 for sure.
  24. Taboo56Chevy
    Taboo56Chevy
    35/36 gates will fit. They changed the hinge design in 37
  25. NeedFiber
    NeedFiber
    By George that's it!!! the 2nd one was the one I was looking for. That chocolate/gray one is a beautiful truck too. Thanks anothercarguy!
  26. NeedFiber
    NeedFiber
    Hey so looking at the two trucks in the link above, they dont have the exposed 3 bar hinges. What year are those tailgates?
  27. Taboo56Chevy
    Taboo56Chevy
    That hinge design is the 37-41 setup and those are 37 tailgates. One year only design.
    Hotrodmyk likes this.
  28. NeedFiber
    NeedFiber
    So I'm fitting all the sheet metal and have not a one seal to work with. On the front fenders, I know there is frame welting. I see rolls of the stuff. How thick should I be looking for? Also, on the front fenders I see little clips that held some kind of seal that would be on a vertical side of the fender, near the rear, that goes near that spot welded bracket on the fender. Looks like maybe 8" long. What should I be looking for for that seal? On the rear fenders I know I need fender welting. Any particular style? And is any seals used on the running boards to fender where they bolt together? How about the running board to the frame bottom? THANKS!!
  29. Taboo56Chevy
    Taboo56Chevy
    no real seals between the running board and fenders. Then welting is a mixed bag. I dont have any in my 33 pickup and its held up fine for decades and thousands of miles and many drag strip p***es.
