Technical 39 Chevy coupe help
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Aug 13, 2024.
  1. Lloyd's paint & glass
    Don't you love putting **** together that you didn't take apart?? The front fenders on a 39 Chevy, do they bolt directly to the radiator support? Am I missing something? Signed, **** this **** in Kentucky
    20240813_161356.jpg 20240813_161411.jpg 20240813_161622.jpg 20240813_161626.jpg
    Truckdoctor Andy and Kelly Burns like this.
  2. It has been a long time since I worked on a friend's '39, but I believe they do. I hope my vagueness helps!
  3. 57 Fargo
    57 Fargo
    Clearly they bolt to whatever has the holes for the fender bolts. Duh…:)
    Truckdoctor Andy likes this.
  4. alanp561
    alanp561
    Where are the inner fender panels?
  5. Lloyd's paint & glass
    Still in the storage building. Gotta be modified.
  6. 05snopro440
    05snopro440
    It sure looks like that bolts right to the rad support and the grille wraps around.
    On my 46 Pickup there's another piece between the fender and rad support, but you can definitely tell something is missing. That said, on mine there are about 8000 pieces that make up all the parts around the rad support to the fenders, so I wouldn't be surprised if there were some kind of bracket or something that goes in there.
    Not helpful, I know.
    Lloyd's paint & glass likes this.
  7. lumpy 63
    lumpy 63
    My neighbor kid Danny has one in his backyard, He said he would take pictures when he gets home.
  8. JohnLewis
    JohnLewis
    I agree with the above I believe the grille and possibly inner fender skirt helps fill the gap. IMG_0547.jpg IMG_0545.jpg
  9. lumpy 63
    lumpy 63
    30025.jpeg It's an old g***er if you want another one Lloyd:p
  10. 24riverview
    24riverview
    The inner fenders and grille tie the whole clip together but this piece is what actually bolts fender to support.
    Bet you wondered what the other holes under headlight were for...:D
  11. Lloyd's paint & glass
    Well I'll be a son of a *****! There's what I needed to see! Thank you my kind sir
  12. lumpy 63
    lumpy 63
    I'll let Danny know you got it sorted:cool:
  13. Lloyd's paint & glass
    Thanks man. Now I've gotta dig through boxes and coffee cans looking for those damn brackets :rolleyes:
  14. patsurf
    patsurf
    faster to make a couple
  15. Lloyd's paint & glass
    That's very true!
  16. Yeah, maybe for you guys! I’m a mechanic, not a fabricator! :D:eek:
  17. Lloyd's paint & glass
    Got a vice and a hammer?? You're in :D
  18. 1971BB427
    1971BB427
    from Oregon
    I had to make mine, and used some 2" square thinwall box tubing. Just split it down the middle lengthwise, and then cut a V at the bend point on each side, and bent them 90 degrees. Then welded up the joint at the 90. Be sure to drill the larger hole that goes to the radiator support before bending too! Then the two holes that attach to headlamp housing bolts can be marked and drilled once it's all aligned.
    And these aren't a straight 90 degree bend! There's a slight angle to make them align to the headlamp bolts.
  19. Lloyd's paint & glass
    Thanks man. I'm gonna look in my boxes of parts first, because the owner still has the grille, so I don't know the spacing i need.
  20. M C Empson
    M C Empson
    I'm glad I read this as I'm also missing these brackets. Thanks Guys
  21. deathrowdave
    deathrowdave
    from NKy
    If I only lived closer , I spend most of my days buildin stuff for Buddies in need . Today it was a barrel tuner for bench rest .22 rifle
  22. Lloyd's paint & glass
    Easy bracket to make, but not knowing the space needed for the grille to fit makes it impossible. The chin piece under the grille is ****ed up, so I need the spacing to be correct so I can use it to straighten the chin piece. Aggravating man lol
  23. choptop40
    choptop40
    Looks like your in the wrong racket........er...I meant bracket....lol....Hamb to the rescue once again....Lumpy63 that 39 Chevy is driving me nuts....
    lothiandon1940 likes this.
  24. Lloyd's paint & glass
    My buddy Gerald took this picture of his, and lumpy sent me a couple of his neighbors. 20240814_175501.jpg IMG_5212.jpg IMG_5213(1).jpg
    JohnLewis and lothiandon1940 like this.
  25. 1971BB427
    1971BB427
    from Oregon
    The grille wont do much to help figure out spacing. Those grilles have enough flex to them width wise that they are designed to fit a little variance in the opening. So you need to setup the core support, fenders, and check the hood to see how everything aligns first. Then you can add those two braces once it's all aligned. Those braces have a slot in them for a reason, so they can also fit varying fitment. So they wont really set dimensions for anything
    When I put my frontend together I had zero parts, so I fit my fenders to the body just snug. Then I bolted the little piece that goes under the grille in to get the front of the fenders together. I then put a pad on my floor jack and set it to support the fenders under the nose piece. Set the hood on and loosened the fender to body bolts to allow me to raise/lower the front fenders. I sat hood on and began adjusting the floor jack to raise the ***embly until the hood aligned perfectly. I removed the hood and finally bolted the grille into the opening. I have a one piece hood, so I don't have hood sides.
    After that I tightened the fender to body bolts, and then the fender to radiator support bolts, and the various brackets.
    It sometimes takes loosening bolts again to get minor adjustments, but it was very close doing it the way I did it
  26. 39ChevyBob
    39ChevyBob
    BB427 has what I think is the best way to go about this. For what it's worth, a couple more pics of the brace that mounts under the headlight pad.
    I bought my car complete 14 years ago, and when going thru spare parts a couple years ago, I had these braces in there, all pretty and painted. Asked on a 1939 forum what they were, and finally installed them! Had driven the 39 about 20,000 miles by then, with no slumping or problems, but glad I now have them where they should go. 20210213_155316.jpg IMG_2700.jpg
