Customs Lake pipes or not
Discussion in 'The Hokey Ass Message Board' started by wheeltramp brian, Aug 13, 2024.
  1. wheeltramp brian
    wheeltramp brian
    I was thinking of putting some lake pipes on my 55 Plymouth and happened to have a used one that is 70 inches and a little short, but I can buy an 80 inch one .not sure yet....thoughts?here is a 56 that looks pretty good 20240813_154804.jpg 20240813_154903.jpg 20240813_154854.jpg A MOPAR 56 PLYMOUTH RON DULIN (1).jpg A MOPAR 56 PLYMOUTH RON DULIN (2).jpg
    duecesteve, LCGarage, Stogy and 24 others like this.
  2. 40FORDPU
    40FORDPU
    Sure, appropriate for a mild custom (seems like the "look" you're going for).
    Stogy, Texas57 and Paul B like this.
  3. 57JoeFoMoPar
    57JoeFoMoPar
    "Yes" as to the lake pipes, but only if you get the proper length.
    ratster, Stogy and Paul B like this.
  4. wicarnut
    wicarnut
  5. wheeltramp brian
    wheeltramp brian
    Yes, these are the 70 inch ones and they make the 80 inch available, just trying to figure it
    out.
    Tow Truck Tom and Stogy like this.
  6. 57JoeFoMoPar
    57JoeFoMoPar
    The look is definitely right with them. I've often described lake pipes as traditional ground effects, since they give the impression of the car being lower without actually lowering the car. I think the longer 80" pipes will also give a lengthening effect visually, which is a perfect combo. The long and low look is what you're after. Cool car
    Stogy, John B, Okie Pete and 4 others like this.
  7. drdave
    drdave
    I vote yes....especially with the 80 inchers.
  8. Roothawg
    Roothawg
    I like them, but it's all in your personal tastes.
    Tow Truck Tom and Okie Pete like this.
  9. ROADSTER1927
    ROADSTER1927
    No it is an ad on that your great looking car does not need!
    05snopro440 and ekimneirbo like this.
  10. Side pipes are for Corvette's unless your car powered by one of those extremely elusive Corvette engines? :D
    ekimneirbo, Okie Pete and das858 like this.
  11. bchctybob
    bchctybob
    I’m not sure. They look era correct but they don’t really add anything to the look at this point, just “accessorize” it. Maybe look at it again after you’ve added wheels and tires and set the stance.
    Love the car (and the ‘56 in the pictures), definitely a great find.
  12. wheeltramp brian
    wheeltramp brian
    If and when the 241 Poly does give up the ghost, it
    will be getting a Corvette engine LOL.
  13. hotrodjack33
    hotrodjack33
    Yep. they work.
    Tow Truck Tom likes this.
  14. Mr48chev
    I'm not a huge fan as too many of them look stuck on as an afterthought. Maybe because the ones I see in this area are on pretty much stone stock cars and not on mild customs like the Plymouth like you posted where they are a working part of the look. With the white walls and hub caps I'd think that car can carry it off and they won't look like the "I got 300 left in the budget what can I stick on it/" type of thing that you now see too much of.
  15. winduptoy
    winduptoy
    only if they are functional.....
  16. ALLDONE
    ALLDONE
    yep, and only if you like them....
  17. ALLDONE
    ALLDONE
  18. Nailhead Jason
    Nailhead Jason
    I was always partial to the short ones, go from the door back. either way would look good on that car. Here are the ones i made for my 39. 8B7A96D9-2994-42BF-B69B-69EB92EB02A3.jpeg 5924917B-9F58-467D-BB0A-D61485BED69F.jpeg 19A8558E-A05B-4456-8FA2-B2400C39AB66.jpeg
  19. wheeltramp brian
    wheeltramp brian
    Well, I bit the bullet and ordered the 80 inch ones.We'll see how they look when I put them on and if I don't like them I can always take them off
  20. drdave
    drdave
    I think you will be happy. :)
  21. wheeltramp brian
    wheeltramp brian
    Kind of funny that the longer ones are cheaper than the shorter ones.
  22. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Back when ( 1961 ) my school buddy's older btother had a '56 Plymouth fitted with the short version of lakes pipes.
    Worked for me.
    I always felt that model and year deserved more attention than received.
    3AMideaz and drdave like this.
  23. dan c
    dan c
    i prefer what we used to call "sneaker pipes." they just stick out right behind the front wheels.
  24. 57JoeFoMoPar
    57JoeFoMoPar
    This is a crock of ****. Look at virtually every Barris built car, Larry Watson car, Alexander Bros. car from the era that had lake pipes. Virtually NONE of them had functional lake pipes, and they're all utilized for aesthetic purposes.
    When people say stuff like "lake pipes must be functional" or "why are you adding on **** that doesn't work", what is actually being said is, "I don't understand custom cars and automotive restyling of the relevant era".
    Here's a few ****boxes with untraditional, non-functional lake pipes.
    77ecd89a-3954-46dc-86d2-5c5fc4ad3a28.jpg Dave-jenkins-1957-chevrolet14.jpg ff1b250d6a410afadf7b29321b9b06e1.jpg KK.jpeg
    pigIRON63, Jrs50, 1Shot-Scot and 15 others like this.
  25. 302GMC
    302GMC
    from Idaho
    Not on that car. It looks stubby as is, & those pipes would make it stubbier ... just drop it about 5'' both ends & put tailpipes on it ....
  26. K13
    K13
    This seems to be the case with about 80% of the comments made on this board about customs.
  27. 57JoeFoMoPar
    57JoeFoMoPar
    I wouldn't cl***ify kickstands/cheater pipes as "lake pipes" in the typical sense. These are also more of a hot rod thing than a custom thing.
    54delray likes this.
  28. I like them on the late '50s/early '60s styled mild customs.. I have them on my Fleetline (made 'em function 'cos I like the sound uncorked!). I think your Plymouth is a perfect candidate!
    -Dave
  29. In_The_Pink
    In_The_Pink
    ^This. Less is more in this case.
  30. theHIGHLANDER
    theHIGHLANDER
    I have a set new in the box with the clamps included, but shipping might be a few sheckles to CA.
    alanp561 likes this.
