Projects 62 Falcon Gasser Build 'Night Terror'
Discussion in 'The Hokey Ass Message Board' started by Chadthesailor, Aug 14, 2024.
  1. Chadthesailor
    Chadthesailor
    Here is my newest project. It's a 62 falcon out of OKC. I've been working on it for several months now, so I thought it was time to share my progress. I'm building a g***er out of it. IMG_5252.jpeg IMG_5856.jpeg IMG_4631.jpeg IMG_4629.jpeg
  2. Chadthesailor
    Chadthesailor
    Few more pics
    mad mikey, 1971BB427, swade41 and 3 others like this.
  3. Let’s see, vehicle, check, build plan, check, engine, pending, color, it’ll buff out, upholstery, what upholstery?, rear axle, pending, suspension, it’s a g***er people, barricade on the shop door in case the boss ( your wife) gets mad, double check. Carry on.
  4. deathrowdave
    deathrowdave
    from NKy
    Grand slam ! Great Work and I’m a picky Sumana***** !
    mad mikey and Chadthesailor like this.
  5. Chadthesailor
    Chadthesailor
    Thank you!
    mad mikey likes this.
  6. bobss396
    bobss396
    What the hell... subscribed... :cool:
  7. Chadthesailor
    Chadthesailor
    Here is another photo dump, of the frame rail install, ladder bars, I kept the car leaf spring, but upgraded to HD mustang leafs, the original rear frame rails were rotten, so I modified some early mustang rails to replace them since you cant buy them. I am running a 48-52 F1 axle, using speedway g***er leaf springs, and spindles.
    mad mikey, 1971BB427 and bobss396 like this.
  8. Chadthesailor
    Chadthesailor
    I also recut the rear wheel radiuses a few times, until I got the stance I wanted. If you ever have seen the Falcon G***er 'Hound Dog' Thats the stance I was going for. Drivetrain is up in the air, I got a Virgin Fe 390 105 block, and a 460, Transmission is still undecided. Roll cage install will be coming up shortly, after I finish stripping the paint.
    mad mikey and 1971BB427 like this.
  9. RmK57
    RmK57
    There is a build on an early Falcon on here using a 460. It’s a very nice build he’s done, maybe get some ideas?
  10. Chadthesailor
    Chadthesailor
    Oh yes I believe I have seen that one. Nice build
  11. Chadthesailor
    Chadthesailor
    Engine mockup
    mad mikey, 1971BB427 and Chucky like this.
  12. 1971BB427
    1971BB427
    from Oregon
    A really top notch g***er build on your Falcon! Not many go this far to build an entire frame underneath. I built my '63 Falcon Futura g***er back about 9 years ago and used much of the Unibody by adding 1"x3" box tubing welded to the bottom of the front Unibody rails, then welded subframe connectors back to the rear, and tubing supports out to the rockers. Put a 468 BBC in mine, with Super T10 four speed, and a 8.8" Ford rear axle. Also added a 8 point cage to further stiffen up the body and ch***is. Mine was mostly for the street, but ran the nostalgia drags each summer also.
    Sold mine when I began building my '39 Chev g***er.
    mad mikey, bobss396 and loudbang like this.
  13. Chadthesailor
    Chadthesailor
    Awesome! I have seen this car on a Fb group before! killer
  14. Chadthesailor
    Chadthesailor
    Been pretty busy the last few weeks. Scored an all original 1971 460 out of a Lincoln, started tacking in the roll cage, got the engine and transmission hung from the motor plates.
  15. mad mikey
    mad mikey
    Love it! Great work, going to be a KILLER g***er, very nice. I will be watching your progress. ;):)
