Technical What did you do with your car today? * NEW*
Discussion in 'The Hokey Ass Message Board' started by j hansen, May 3, 2020.
  1. Chucky
    Chucky
    Swapped the stock wheel studs for some long Moser’s. I probably didn’t need them, but I probably don’t need a hot rod either. Also working on brake hose routing. The weather was just too nice today not to work on the old Studebaker.
    Tickety Boo, swade41, skooch and 6 others like this.
  2. Adriatic Machine
    Adriatic Machine
    64 mile round trip in the rain. Each time I’ll go a little further until I work out all the bugs.
    Last Tuesday I visited @gary terhaar RIP. This is the man who inspired me to pursue metal fabrication as a career 30 years ago. He mentored me, especially when we built the engine in my Rancho back in 2013. IMG_2250.jpeg IMG_2251.jpeg
    zggum, rod1, rusty1 and 16 others like this.
  3. choptop40
    choptop40
    Honoring the ones who inspired us...Kudos To you you sir....
    Adriatic Machine likes this.
  4. Adriatic Machine
    Adriatic Machine
    Thank you for that. I couldn’t visit him in my boring commuter car. I had to pay respects while appropriately dressed.
    rod1, HarryT and vtwhead like this.
  5. RICH B
    RICH B
    Made a hood prop for our '47 that tucks up out of the way when done. Decided I didn't want to use an in dash cable on the hood latch so I added a handle you can reach thru the grille.
    alanp561, Tickety Boo, Chucky and 6 others like this.
  6. warbird1
    warbird1
    After a lot of screwing around finally got the exhaust installed in the roadster... KIMG0287.JPG
    And thanks to @Hitchhiker I've got a good 32 grille and shell to work on!
    rod1, Chucky, charleyw and 11 others like this.
  7. kustomkat1950
    kustomkat1950
    from Coastal GA
    40two, Okie Pete, rod1 and 8 others like this.
  8. swade41
    swade41
    from Buffalo,NY
    I put the interior back in the 41
    Gave everything underneath a final look over then took it off the wheel cribs and set it back on concrete
    Tested brakes, forward/backwards gears, cooling fans, brake lights and the line lock, all works !
  9. choptop40
    choptop40
    ...nothing like hotrods in the morning with a cup of Joe... B6034670-160C-48C6-B2C6-77BB6243AEEA.jpeg
  10. More work on the 27, floors and tunnel, today will be brake master access door and shifter mounting.
    Chucky, X-cpe, swade41 and 3 others like this.
  11. j hansen
    j hansen
  12. swade41
    swade41
    from Buffalo,NY
  13. T. Turtle
    T. Turtle
    Well I'm continuing with the frustrating task of getting my car road legal too - this past week I was supposed to be with visitors from Israel but for obvious reasons their flight got cancelled, so I decided to have the week off and concentrate (a**** other things) on the car. On the positive side the machinist managed to adapt the water thermometer housing so it accepts the sensor (previously it was mounted on a br*** pipe which had a too large diameter thereby ruining the rubber hoses and having no swage to hold them) and the cooling system is now ***embled with water inside and what appears to be no leaks. On the negative side the car refused to pull gas into the carb (so no full working temperatures/pressures test) which can be either the fact the car was on the incline with an almost empty tank/kinked & loose steel pipe from pump to carb - or a dead fuel pump. The first is easily repaired, went to the local building supplier and got a copper pipe which I need to cut, flare and shape. The second will be PITA simply because it takes so long to get anything here from the US... I also managed to get other annoying things sorted like the windscreen washer working, the gas pedal fixed and some exposed floors cleaned and coated with paint. All during a heatwave meaning working at 90°f-100°f.
    But I am a masochist, so all is good.;)
  14. Paul
    Paul
    Editor
  15. Jkmar73
    Jkmar73
    from Tulare, CA
    Been working on rear quarter panel. Have gotten it closer. Still needs some more finishing work on the high spots. Should be able to take care of the low spots with filler.
  16. jeepster
    jeepster
    from wisconsin
  17. swade41
    swade41
    from Buffalo,NY
    Me and my son aligned the front end yesterday, which was the last of the mechanical things, so today I started working on the hood sides.
    I never finished the body work from where I made all the separate pieces into a one piece tilt front end.
    The plan is to smooth out the cloth and resin then cut the majority of the hood sides off but leaving enough to still tilt it by the hood.
  18. 31Apickup
    31Apickup
    alanp561 likes this.
  19. choptop40
    choptop40
    that tilt nose looks mean...are you painting the truck flat black ?
  20. swade41
    swade41
    from Buffalo,NY
    It's been that color for 30 years, all I'll do is paint the hood and touch up the fenders
    HOTRODPOWELL and skooch like this.
  21. Paul
    Paul
    Editor
    raced him twice
    beat him once
    alanp561, rod1 and 26 T Ford RPU like this.
  22. jimmy six
    jimmy six
    Added a larger overflow…..it’s shiny stainless so I’m not going to show it….. I semi gloss blacked the last one that was aluminum but this one is not that easy…
    RICH B and j hansen like this.
  23. jeepster
    jeepster
    from wisconsin
  24. Acres
    Acres
    from Sweden
    Repaired a flat, a damn screw in my new whitewalls......
    j hansen likes this.
  25. RICH B
    RICH B
    Put some trim on our '47. Really need to get the doors out and gone over.
    charleyw, skooch, 61Cruiser and 4 others like this.
  26. fastcar1953
    fastcar1953
  27. ALLDONE
    ALLDONE
    slap the **** out of it, that'll all come out...if it starts oil cann'n put some heat on the pop spot and give it some light slaps..quench it with a wet rag.. metal has a memory .... unless it's like the 100 year old doors on my 27 T... they have Alzheimer's ... and get some **** brick for a good guide.... not say you don't know how ... but just incase... here's a video that'll help you and outers not use so much filler..
  28. ALLDONE
    ALLDONE
    I don't know the secret hand shake, and I'm kicked out of all the reindeer games... so can I just ask what you raced him with??? with all due respect...
  29. Paul
    Paul
    Editor
    I don't have any pictures of my car at that event but here is one from GGPNW 24
    skooch, 26 T Ford RPU, X-cpe and 3 others like this.
  30. ALLDONE
    ALLDONE
    wow, ask and you shall receive... *****en car.. I didn't get my macs catalog yet, so gotta ask,..what year body..seems the pre 25's have more swoop on the rear of the cab, and rounded doors
