Hot Rods BChrismer's Survivor '40 Ford Convertible
Discussion in 'The Hokey Ass Message Board' started by bchrismer, Aug 9, 2024.
  1. Pretty much the same thing I said to @Weedburner 40 and @cvstl when I sent the picture to both of them.
  2. Spoken like a true blue hillbilly. I like.
    Ben
    Spent a little time rolling around on the garage floor this afternoon after church. Got the new Posies reversed eye spring and regular length shackles installed. I did make sure to swap the top two leaves to below the spring, to help it sit better once the spring settles.
    Currently sits a hair lower out back, but the change in driving characteristics is night and day with losing the long shackles!
  4. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Looks much better! Well, other than the exhaust hanger. :rolleyes:
    Grandadeo, Kelly Burns and bchrismer like this.
  5. One has to excuse @winduptoy for mistaking the "Hot Hamburger with Chicken Fried Steak. I'm sure all he remembers is the white gravy and how he hitched a ride back to the hotel with our server two years ago while we were at the Gathering at the Roc.
    This is the "normal" Hot Hamburger from Murphy's Steak House, in Bartlesville, OK. I've had it this way, but MUCH prefer the white gravy on it. However, when you order it with white gravy, the server usually looks at you like you farted in church, then tells you that you are the spawn of Satan himself as your buddies all around the table order it the same way.
    Baumi, brando1956, 40two and 8 others like this.
  6. Tim
    Tim
    from KCMO
    Thought of you and your shock situation yesterday as I stabbed the throttle to make turning around in a culdisack a little more fun.
    ya see I may have temporarily forgotten that the car still doesn’t have any rear shocks on it. Lol that’s a LOT of ass end body roll, but it got some giggles.
    Maybe we’ll both get our shocks sorted this month haha
  7. I've gotta take the coupe out to Mike Meeker's shop, so we can swap the clutch I killed in it. Hopefully while it's out there, I can drive the convertible up so we can stick it on the lift and I can at least drill a couple holes in the rear cross member to move the top of the shocks out towards the frame rails a couple inches. I just need to make sure to allow enough room between the shock and huge exhaust pipe so I don't break the hanger. I had to do that same "shock relocating" thing with my coupe several years ago, when I swapped out the parallel leaf springs to some that had reversed eyes and much less arch, causing a shallow shock angle. Much better to do on a lift than lying on your back!
  8. Grandadeo
    Grandadeo
    Is envy still a sin????
    40two, Nostrebor, Okie Pete and 3 others like this.
  9. That one definitely got a laugh out loud from me.
    One of these days when you are bored and have nothing better to do, perhaps you can come up to flyover country and play cars with me.
  10. Tim
    Tim
    from KCMO
    Man I tried drilling new shock mount holes for seemingly forever last year. I’m going to make some bolt on arraignment using existing holes this time. If there is a secret to putting holes in an old ford frame I sure don’t know it lol
  11. If I remember correctly, I drilled a pilot hole then used a step bit when I did it last time.
  12. Grandadeo
    Grandadeo
    It's definitely on top of my KQQL Things to do list! Got to get some face-to-face time with my MO and OK Buds.
  13. Okie Pete
    Okie Pete
    Would a hole saw work for drilling a hole for the shock mount bolt ?
    Murphys is a good place to eat
    bchrismer and guthriesmith like this.
  14. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    You just need to come up for the Gathering at the Roc Lee. That would be a good opportunity to hang out with a bunch of hoodlums. :D
  15. The 39 guy
    The 39 guy
    So Bret, are you considering the shock stoke length in this location change? Just asking as I leaned a lesson a long time ago about that. Seems that if the shock is to long you can bottom them out and break the shock or the mount. You probably have already considered that but I had to ask.
    Sam
    chryslerfan55 and bchrismer like this.
  16. Yeah, I am, Sam. I learned that with the panel truck. Due to the extra weight of the body on the "standard" Posies parallel leaf springs, I had installed the shocks on the lowest shock mount hole that I could. I busted a perfectly good pair of shocks that way.
    I wound up ordering some Monroe 555002 RV shocks. They had L1 top/bottom mounts, a 8.625 compressed, 12.750 extended, 4.125 travel. That seemed to fix my issue with it.
    I don't remember where I got the Monroe Shock Spec document, but I spent a LOT of time researching before I found those.
  17. I haven't measured yet, but I believe I should be OK with the existing shocks, mainly because as I move closer towards the frame rail, I think the rise of the cross member should be close to the same distance. I'll just need to check the travel to make sure they'll still be fine.
    chryslerfan55 and Tim like this.
  18. Tim
    Tim
    from KCMO
    Yup the reliability run at the roc let me know my rear springs have settled enough to bottom on the shocks first now :S
  19. Weedburner 40
    Weedburner 40
    Bret, you want me to send you the upper mounts or just bring them with me in September?
  20. Sent you a text because you were screening your calls.
    Weedburner 40 likes this.
  21. Tim
    Tim
    from KCMO
    I mean could ya blame him lmao
    guthriesmith and bchrismer like this.
  22. Dale sent me a text message back and said he was in a "Club Meeting". When he finally called me back, I LAUGHED!!! While I am part of the CrossMembersCC and took over The Roarin' 30's of Missouri, there are NO club meetings to attend.
    The good news is that Dale is sending me some of his upper shock mounts. I haven't seen them but from what he told me is that they will move the top of the shocks outward and slightly above the cross member. Once I have those installed, I can get a proper measurement, all while hoping that the existing shocks are miraculously perfect for the job. LOL
  23. Tim
    Tim
    from KCMO
    Seeing a man about a horse lol
    bchrismer likes this.
  24. RodStRace
    RodStRace
  25. RodStRace
    RodStRace
  26. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    We don't have meetings? I thought that is what we were doing at events in Springfield or Bartlesville/Dewey... :D
  27. SPEC
    SPEC
    Great Ride.
  28. 20240816_133405.jpg 20240816_133425.jpg 20240816_133443.jpg 20240816_133505.jpg 20240816_133336.jpg 20240816_164302.jpg
    Not quite what my plans were, but one of my buddies had these tires and wheels he took off of his '40 sedan before he sold it. Didn't know how I would feel about Wimbledon White on a blackish car, but I'm kinda digging the look. I feel like it is giving off '60's era hot rod vibes.
  29. Okie Pete
    Okie Pete
    That is a beautiful piece of history. I’m thankful that You were chosen to be its caretaker
  30. guthriesmith
    guthriesmith
    1. H.A.M.B. Chapel
    Guessing those were from Ben?
