  1. down-the-road
    down-the-road
  2. down-the-road
    down-the-road
  3. down-the-road
    down-the-road
  4. down-the-road
    down-the-road
  5. down-the-road
    down-the-road
  6. down-the-road
    down-the-road
  7. down-the-road
    down-the-road
  8. down-the-road
    down-the-road
  9. down-the-road
    down-the-road
  10. down-the-road
    down-the-road
  11. down-the-road
    down-the-road
  12. down-the-road
    down-the-road
  13. down-the-road
    down-the-road
  14. davidvillajr
    davidvillajr
    In Heinzsight, you may be right.
  15. swi66
    swi66
  16. jnaki
    jnaki
    upload_2024-8-18_4-44-59.png wow!
    Hello,
    The old saying: “been there, done that…” to the extreme…
    One of the first things my brother did was to try and lower his newly purchased teenage Pale Yellow 1951 Oldsmobile sedan. Our neighborhood had a lot of cool looking cruising cars and they were all lowered or on a slight rake.
    We first tried small accessory clamps a lot of people were using when in doubt as to the “look” or not. The clamps squashed the coils and could bring the front end down an inch or two. We have all heard of the “two inch drop” is the coolest. Well, that wasn’t all it was made out to be..
    We used the clamps and the look was forming. So, we took off down the street and it was a little harsh in the ride. But, it certainly had the “look.” For a couple of weeks, caution was the mode of the day. But, once in a while, while driving, my brother forgot how low those clamps made the car and the normal dips made an awful sound. Sometimes, the little clamps fell off due to compression of the springs. Now, that was certainly an unusual oddball sight. Lowered on one side and stock on the other… YIKES.
    Jnaki
    So, my brother started his cruising teenage years with a lowered rake 51 Oldsmobile sedan. He had to slow down as soon as he left our Westside of Long Beach driveway as the next street over required a “slowest crawl” at an angle to get across the intersection. The drainage culverts caused a good run of water to leave the area, but it was a deep ditch that caused some bottoming out of various parts and ch***is of the Oldsmobile sedan. For the first several times, it was a snail’s pace going across the intersections.
    He could not even go into the teenage hangout drive in restaurant parking lot due to the steep angle of the sidewalk slope. So, he went around the block and came in through the rear alley, right into the back row slots. Or, if the back row was full, the next block over was another larger parking lot at a hamburger outlet + restaurant that had a ton of cruisers and local hot rod sedans.
    But, it was not enjoyable cruising. If one forgot to slow down while having a good time cruising, an awful noise was the result. When he got some lakes side pipes for under the doors, he used the for two weeks. The slight dips became a larger problem and now, he had to take those lowest pipes off. Another friend with a normal height cruiser bought them and now, it lowered the overall look of that different sedan by the diameter of the chromed lakes side pipe and tips.
    So, for the last several months of owning the 51 Oldsmobile sedan, he painted it a Lime Green, used the same Moon Discs and kept the new cut springs around 1 inch to 1.5 inches in front. It was a good choice and a lot more enjoyable to ride around. YRMV
  17. jeepsterhemi
    jeepsterhemi
  18. jeepsterhemi
    jeepsterhemi
  19. jeepsterhemi
    jeepsterhemi
  20. jeepsterhemi
    jeepsterhemi
  21. jeepsterhemi
    jeepsterhemi
  22. jeepsterhemi
    jeepsterhemi
  23. jeepsterhemi
    jeepsterhemi
  24. jeepsterhemi
    jeepsterhemi
  25. verde742
    verde742
  26. jeepsterhemi
    jeepsterhemi
  27. jeepsterhemi
    jeepsterhemi
  28. jeepsterhemi
    jeepsterhemi
  29. jeepsterhemi
    jeepsterhemi
  30. jeepsterhemi
    jeepsterhemi
