Projects Kurt’s Puddle Jumper - 1930 Model A Extended-Cab Pickup Build
Discussion in 'Traditional Hot Rods' started by rgclouse, Aug 12, 2016.
Tags:
  1. rgclouse
    rgclouse
    Hard to believe but I actually got a Like from Ryan. Thank you!
    Still have to finish up headliner, but decided to give my neck and shoulders a break and work on something not requiring reaching over my head. Worked on closing up the hole around the shifter.
    Trim still has protected covering. Had to merge to boots to adapt to the round shift handle.
  2. rgclouse
    rgclouse
    Make that "two" boots. Wrong to.
  3. rgclouse
    rgclouse
    Got a lot done on Saturday. Headliner was almost done, but I ran out of 1 1/4 oval head screws. Got them and can now say it is done. Got the rearview mirror reinstalled.
    Got some indoor/outdoor gray carpet on sale at HD. Got the driver side fitted today.
    Installed carpet on top of the driveshaft tunnel.
    Have not decided what to do with the shifter mount. Stain and Varnish, paint gray, or try to over it with carpet.
  4. rgclouse
    rgclouse
    Got the p*** side carpet fitted and installed. Cut kick panels and covered with vinyl. Finished drive side carpet and installed Kick panels. Reinstalled seats.
  5. rgclouse
    rgclouse
    Not a lot done this week. After 17 years in this house, all the shrubs we put in 16-17 years ago have either gotten overgrown or died with the hard freezes the past couple of winters. Takes this 80 years old a long time to dig out and replace shrubs and trees. Got 7 more replaced this week. Still need to mulch and replace the landscape rock.
    Did get the shifter mount painted and the first piece of the carpet over the transmission hump installed.
  6. rgclouse
    rgclouse
    Well the good news is I'm basically done with the bushes project so hope to spend more time on Kurt this week. OT, but just to justify my not getting Model A work done.
    I'm to cheap to have the dirty rock carted away and replaced so I have to shovel and sift out all the dirt.
    Did get a second piece of carpet over the transmission hump fitted this morning.
    Outback, Jrs50 and brEad like this.
  7. rgclouse
    rgclouse
    Slow progress but forward progress. Finally decided on speedometer cable path and drilled (hole saw) a hole in front of transmission hump. Used a piece of 3/16 aluminum wire I have had for years to measure required length. Ordered exact fit from JEGS but they backordered it. Cancelled that and ordered one a few inches longer from Amazon.
    I had gotten a 90 degree speedometer cable adapter for Christmas and finally got it installed. I had to make a homemade wrench to tighten it to the trans.
    Wrench
    Too humid the AM. My gl***es fogged up on the first but making the wrench.
    Got the cable installed and grommet in the floor.
    Had fitted the 3rd and final carpet piece for the hump on Sat.
    Reinstalled it with the speedometer cable today. Not happy with the fit will cut another piece tomorrow.
    brEad and Jrs50 like this.
  8. rgclouse
    rgclouse
    Redid the last trans hump carpet. Got all the screws in to keep it in place. I declare the carpet project is done.
    Outback and brEad like this.
  9. I don't know what happened Roland, I lost track of you for about 4 months. Spent the last few minutes going over two pages to get caught up. Glad to see you making fine progress on your puddle jumper. I'm liking the interior, but for some reason the door panels really grab my eye. Good stuff. Keep at it!
    Outback likes this.
  10. rgclouse
    rgclouse
    Thanks JRS50. My only concern is they will show dirt and grime too easy. Wanted to keep them simple, no pleats or fancy stuff.
    Updated my To Do list. Checked off 13 things since the last time I updated it. To Do portion now fits on one page. Completed stuff is now on three pages.
    I had the top of the cowl off to run the speedometer cable and a few other cleanup items. Got it back installed today and put the dash back together. Added the vacuum gauge that was just riding on top of the engine on the right side. Not an exact match. I have had it for 40 years.
    Have to put the steering wheel back on and the eight nuts that hold the seats in and will be ready to shake it down.
    brEad, Jrs50 and hook00pad like this.
  11. rgclouse
    rgclouse
    Got everything ****oned up and took Kurt for a shakedown run. What a difference having gl*** and interior. Without wind noise the sound is totally different. Have a squeak but no idea where it is from.
    Speedometer works and odometer clocked 5 miles on the short drive. Speedometer calibration is way off. There is a traffic speed monitor 2 miles from me and I held it at 40 mph. It said 46-47. Two of our cars show the opposite reading 3-4 miles slow at 40.
  12. rgclouse
    rgclouse
    Not much to report. Got new door windows so I can back Kurt out of garage and know I'm not going to hit the garage door sides. Old drivers side mirror would move with wind at 20 mph.
    Been working on console / arm rest to also act as a glove compartment. Got a cup holder insert but too small to hold a 16 oz 7-UP bottle. Arm rest is about 1 inch too high.
  13. Parnell
    Parnell
    Making lots of progress!
  14. rgclouse
    rgclouse
    Just checking in. Was away for 6 weeks visiting children and grandchildren. Now a week of work to get the yard back in shape.
    set me on fire, Outback and brEad like this.
  15. rgclouse
    rgclouse
    Still catching up. Main heatpump on house went out so no money to spend on Kurt for awhile. Also too hot to work in the garage. I did get it outside last weekend and washed it for the first time. The roof had been swept off a few times but never washed.
    Last Monday I put Kurt to work. He is a pickup! Used him to run errands and take the trash to the transfer station.
    Outback, Crusty Chevy, brEad and 3 others like this.
  16. rgclouse
    rgclouse
    Yesterday, I finally got back to working on Kurt. Why? Life of a 81 year old man. I have had 5 surgeries for skin cancer in the last 2 months. After each I'm supposed to take it easy for 2-3 weeks and when I could I just didn't have the gumption to go out and work.
    So yesterday I got to work to install the windlace on the top of the doors. They were glued up and the the cover plates painted last May.
    Should have been an easy job, other then working over my head which nether my neck or shoulder like, putting in 5 screws. I got the drivers side in and the door would not even start to close. Had to trim the intersection of the front and top windlace.
    Got it to partially close and the door hit the cover plate. When repairing the wood at the top of the body I put some carriage bolts above the door and the heads were keeping the cover plate from seating.
    Had to take apart the headliner to remove, grind the head, and reinstall one of the carriage bolts.
    Finally could close the door.
    Worked a bit on the console/glovebox after deciding to put off the p***enger side for another day. Decided cup holders will go up in front of the shifter instead of the top of the console/glovebox
  17. rgclouse
    rgclouse
    I don't know how it happened, but it's been 2 months since I posted. I know I wrote what I was going to post in my mind but I guess I forgot to actually post it.
    The glove box / arm rest is done.
    Carpet is really gray, don't know why the pics look so blue.
    Hinged and latched.
    and installed.
    Decided not to put a cup holder in top of glove box, but to extend the console in front of the shifter and put 2 larger cup holders there. Got it rough shaped and a coin holder routed in the top. Then ran out of time before a trip up North for Christmas and New Years.
    A lot of finish sanding, hole filling, and paint to go. I spend too much last year on propane to make the garage comfortable to work so will not being getting much done until it warms up to the middle 40's.
  18. Outback
    Outback
    from NE Vic, Oz
    Good to see you pushing forward.
  19. What's going on with the Puddle Jumper?
    Hope everything is okay in your world, RG.
  20. rgclouse
    rgclouse
    Have not touched Kurt since my last post in Jan. Last fall I fell in the yard and injured my shoulder. I finally saw an Orthopedic Doctor in Jan and he said it was the rotator cuff and prescribed physical therapy and rest. I just finished 3 months of PT and now have to catchup on spring chores.
    Hope to at least get the console finished and get Kurt some exercise in Early May.
  21. Parnell
    Parnell
    You keep having a rough time with the weather down in Tenn. My friend in Paris keeps me informed> Hope the shoulder is getting better! Good wishes from California!
    Outback likes this.
  22. rgclouse
    rgclouse
    Would not say a rough time, but plenty hot and humid. Still have not touched Kurt since Jan. Shoulder still hurting, but more due to keeping up the homestead at my advanced age. Just can't do as much as I could a few years ago, let alone 82 years ago. Turned 82 at the end of July.
    Went north to MN in June/July to visit kids/grandkids/and great grand kids. Generator in MH developed an exhaust leak on the way up. Only way to fix it was to pull the generator when we got back home. So hot in the garage I could only work a couple of hours each morning so it took 4 days till I had it out and torn down to find this:
    Considered trying to repair it but ended up replacing it for $362. You have to turn the gen over and remove a bottom cover to get to the 4 nuts that hold it on.
    Back in and running well but that task burned up over 2 weeks.
    Finished my first p*** of weeding and t******* around the house. Was gone 6 weeks and we had weeds, weeds, weeds. One behind the garage was 1.5 inch in diameter and over 6 feet tall. I say first p*** since when mowing this morning I noticed more weeds have grown in the 3 weeks since I started weeding.
    I hope it cools down in Sept and it will be possible to get back to Kurt.
  23. Grumpy ole A
    Grumpy ole A
    I understand the heat and humidity living in Galveston county, Tx. I have several projects/jobs to do on my aviator. With the heat it’s hard to get things done.
    osage orange likes this.
  24. jamesgs4
    jamesgs4
    from denver
    Inspirational build thread! The truck is looking good! I hope to have half the drive you do if i’m still kicking at 82:)
  25. rgclouse
    rgclouse
    Thanks for the likes and kind words.
    Funny, the heat didn't bother me in my youth. During my time in the early sixties as a mechanic for the auto thrill show, I slept in my truck and worked in the hot sun all day. Bought my first airconditioned car in 1967 and have not had an unairconditioned vehicle till the Model A ( does not include my 1994 GMC pickup which has A/C but I'm to cheap to get the AC working again). Bought our first house in 1972 without AC. We had AC within the first year.
