1954 IH R100 Build
Discussion in 'Off Topic Hot Rods & Customs' started by Daniel Jaquith, Aug 19, 2024.
  1. Daniel Jaquith
    Daniel Jaquith
    Hey Guys,
    I wanted to start a build thread to do***ent my progress and gain from the collective knowledge of people who have gone before. (wise old farts)
    I've always been into Internationals because they are rare(ish), generally cool looking and I never wanted to be able to buy anything off the shelf to fit them. I must either hate myself or love a challenge.
    I've had numerous scouts, all offroad builds, and been an on and off again part of our local IH Club. Back in 2013 I was heading up our annual car show and RatPin from the board here showed up with this thing.
    https://imgur.com/a/gMExdNR
    Link to his build thread: https://www.jalopyjournal.com/forum/threads/1954-international-r-100-build-thread.614359/
    I had never seen a lowered truck I liked the look of better. So I promised myself one day I'd build one just like it. So here we are a few years later.
  2. Daniel Jaquith
    Daniel Jaquith
    Since every International has to have a parts rig, I found the green one first then bought the white one a few months later.
  3. Daniel Jaquith
    Daniel Jaquith
    Here are a few teardown and build design pics
  4. chicken
    chicken
    from Kansas
    Daniel, that looks great! You should probably move your thread to the "off topic" forum though, since it involves more modern suspension. Just select "forums" and "off topic" and you'll find it. Show us more!
  5. Daniel Jaquith
    Daniel Jaquith
    First order of business was the rear axle and frame.
    I found an 8.8 from a 98 Mustang that will be the correct width after swapping in two drivers side ford ranger shafts. (narrows it 1.5" overall)
    Being on bags the frame was in the way. I've never been a fan of notches and since everything behind the axle was going to be custom anyways I designed up some frame plates and went all new from the axle back. This allowed me to mount my bags directly under the frame and well and place my lower links basically anywhere I want. This got me really good numbers for the rear 4 link.
  6. Daniel Jaquith
    Daniel Jaquith
    On the same trip to the Pick-N-Pull that I got the axle, I found a 5.3l from an 04 Tahoe. It was their 50% off Black Friday sale so I got the axle and the fully dressed LS for under $300.
  7. Daniel Jaquith
    Daniel Jaquith
    Front end is a 58.5" wide Mustang2 from Paul Horton's https://welderseries.company.site/New-Products-c24567209
    Using Ridetech upper and lower control arms with 4" travel Shockwaves. I got everything tacked into place yesterday.
    This is where I need some ***istance/checking.
    Few Specs that should align with other build threads I've read on here.
    4* caster
    0* camber
    4* anti dive on the upper control arm mounting plates
    Lower arms level at ride height
    Upper arms aim down from the ball joint towards the center of the frame at 10* for bump steer
    Link to a video of the travel: https://imgur.com/a/9gsf0Uv
    How does this look?
  8. 6sally6
    6sally6
    Gonna be cool !!
    6sally6
  9. chicken
    chicken
    from Kansas
    The suspension arc looks good to me. Ought to handle well. The numbers at the rear are nice...you may be able to get that power to the ground! Nice work.
  10. Daniel Jaquith
    Daniel Jaquith
    Last night I got the tires and fenders mounted to check for steering clearance. Full turn lock to lock with about 1/2" to spare at ride height. Like a glove.
  11. Daniel Jaquith
    Daniel Jaquith
    To get a rolling ch***is and since I'm pretty happy with the front end, I shifted my focus back on the rear axle.
    Rear upper link mounts are in according to my dimensions in the 4-Link calculator. I cycled everything and found that my links were binding pretty bad. I had this su****ion going into this but everyone on the internet and every build I saw used these same poly bushings. Coming from the off-road industry where we have huge articulation built into our suspensions, bind really isn't an option. Bind+Torque=Broken.
    My bind is exaggerated because of the triangulated links but even in a dual parallel with a Panhard bar setup, like this one,
    https://welderseries.company.site/Parallel-Rear-Four-Link-Package-for-Air-Springs-p51448832
    the axle shifts left or right a little bit putting the bushings in a bind.
    Is this just normal and accepted?
    I think I'm going to swap those threaded bushings out for a set of these, https://ballisticfabrication.com/forged-chromoly-2-0-in-ballistic-joint/
    They have articulation and are rebuildable.
    One more question about air bag mounts. When the axle move from ride height, to slammed. (4"higher) the axle travel in an arc because of the link setup so my lower bag mount isn't parallel with the frame anymore. Should I angle my top bag mount so that the top and bottom of the bag are parallel at full stuff? These Slam bags have internal bump stops and I don't want to damage that by hitting it at an angle.
  12. Daniel Jaquith
    Daniel Jaquith
    The Ballistic joints came in and they fit perfectly. The rubber joints in the housing still bind at full stuff but the rubber should allow for that and keep things smoother on the road than the poly joints. I'll just swap out the bushing once they wear out.
    The specs on the SS7 bag says 2.7" minimum height so I spaced the plates 3" and at the correct angle when compressed. This should allow the internal bump stop to work properly and the frame bump stop will stop the bag from ridding fully on the bag bump, hopefully extending its life.
    Uncle Ronn, 41 GMC K-18 and Okie Pete like this.
  13. Daniel Jaquith
    Daniel Jaquith
    Got a rolling ch***is.
  14. Daniel Jaquith
    Daniel Jaquith
    Got most of the body back on and rolled it out of the shop.
  15. Okie Pete
    Okie Pete
    Looking good
    Sharpone and Daniel Jaquith like this.
  16. Daniel Jaquith
    Daniel Jaquith
    Got the motor mounts and transmission crossmember in this weekend.
    Also working on layout for behind the cab under the bed floor. The round s****s are representing two 3 gallon tanks on either side of the driveshaft. Dual battery box on the p***enger side and compressors and air management will go on the drivers side. Unless I go with an engine driven compressor, then layout get much simpler.
  17. Uncle Ronn
    Uncle Ronn
    from Modesto CA
    Neat Project!
    Updates??
    Sharpone, pprather and 41 GMC K-18 like this.
  18. Daniel Jaquith
    Daniel Jaquith
    Thank Ronn, Its been slow the last month or so. I've been busy researching and planning though. I dove into the world of air suspension solenoids and air line plumbing. I've settled on a solution that will still flow well and wont be crazy expensive. See attached pic. I'm going to put the standard SMC 3/8" valves in a sealed aluminum enclosure mounted on the frame. I've also decided to get 2-4 gallon air tanks and mount them on either side of the driveshaft unlike the layout I tried out in the above post of having them perpendicular to the driveshaft. Air and Fuel lines will all be 3/8" NiCopp Hard Tube from here: https://4lifetimelines.com/collections/tubing
    I've also decided to go with an engine mounted compressor instead of electric ones. https://www.littleshopmfg.com/gm-4-8-5-3-6-0-6-2-ls-belt-driven-compressor-kit/
    I just ordered the tanks and a bunch of fittings for plumbing on Black Friday so I should have some progress soon.
  19. Uncle Ronn
    Uncle Ronn
    from Modesto CA
    Looking forward more content....you're doing Great Job!
  20. Daniel Jaquith
    Daniel Jaquith
    New Tig welder came is so I was able to weld the mounting tabs back on the fuel tank. It will mount 3" under the frame on some support brackets (screenshot below) with rubber strips between the aluminum and the steel and rubber washers on the bolts to help with vibration.
    Got the air tanks where I like them, (Imagine the same on the other side) and have some brackets drawn up to cut out on the plasma table.
  21. Daniel Jaquith
    Daniel Jaquith
    Not a huge update but I was able to get some parts cut on the plasma table to help the driveshaft loop and tank mounts along.
    41 GMC K-18, Okie Pete and Sharpone like this.
  22. Daniel Jaquith
    Daniel Jaquith
    Fuel tank mounts tig'd and installed.
    Working on headers now. Equal length fender-well exit is going to be a trick to get to work.
  23. Okie Pete
    Okie Pete
    Late mentor had a short bed 1947 IH pickup with an early 60’s Oldsmobile V8 and auto trans . He was a closet hot rodder at heart .
    41 GMC K-18 and Daniel Jaquith like this.
  24. Daniel Jaquith
    Daniel Jaquith
    Small progress. I got the driveshaft loop finished and tacked into place. I also replaced the fuel filler on the tank so that it can go through the frame and flush fill when the tailgate is down.
    Few more fittings along with the water traps and manifold valves are coming in this week then I can start running lines.
    Uncle Ronn, SS327 and 41 GMC K-18 like this.
  25. Daniel Jaquith
    Daniel Jaquith
    Rolled it outside, even if only to sweep under it.
    Started working on the 3/8" air lines. I obviously started off with the easiest one. Line over the driveshaft loop to tie the tanks together. Also pulled the seat and brackets from the parts truck. Need to figure out where the brake pedal goes to say which side of the frame the brake MC and pedal are going so I can plan exhaust.
    I know some of you can smell that last picture of what I found in the back of the seat.
    Uncle Ronn and 41 GMC K-18 like this.
  26. RodStRace
    RodStRace
    I admire the artistry of the air line bends. When in operation, do you get water in there like shop lines? I see a couple traps if it does...
  27. Daniel Jaquith
    Daniel Jaquith
    Thank you! I like the look of the NiCopp against the black fittings, plus hard lines are just ***y.
    I will absolutely get water in the system. Probably more than a compressor in a shop because an air system on a vehicle has even more temp/humidity changes.
    The compressor will be an engine mounted York setup. https://www.littleshopmfg.com/gm-4-8-5-3-6-0-6-2-ls-belt-driven-compressor-kit/
    The feed line to the tanks will travel down the inner drivers side frame and go through a large SMC water trap before hitting the first tank. Each tank will have a drain on the bottom as well as smaller water traps before each manifold valve. Should keep everything nice and dry.
    Uncle Ronn likes this.
  28. 05snopro440
    05snopro440
    Very cool build. Gotta love a Binder. My dad has a 41 KB-1 half ton that he built about 1999.
    Uncle Ronn and Daniel Jaquith like this.
