Projects Putting together my second 64 tempest sedan
Discussion in 'The Hokey Ass Message Board' started by Fourdoor64, Jun 11, 2024.
  1. Fourdoor64
    Fourdoor64
    I believe they are similar, which will work out because I have a ford 8.8 in my daily driver grand marquis that's howling at the moon lol. I also have an extra 8.8 so I'll probably practice on one of those and then go after the 10 bolt.
  2. wheeldog57
    wheeldog57
    Great progress on the Pontiac @Fourdoor64. I recently delved into the Pontiac 4dr world with a 61 Catalina.
  3. Fourdoor64
    Fourdoor64
    That things killer! Definately going to stand out at cruise nights and shows, never see those!
    wheeldog57 and Squablow like this.
  4. Fourdoor64
    Fourdoor64
    Last night I took a break from the V8 car, and brought the six banger tempest in the garage to practice a bit of bodywork. The rust has been coming back in full force since my highschool bondo gl*** repairs back in 2018. I'm trying to spiff the car up for the Adirondack Nationals in Lake George a few weeks from now, so I figured it's as good a time as any to try something new. It's my first time ever making patches and using a welder for bodywork. It may not be perfect, or the right way to do it, but i feel better about doing this than filling it back up with mud. This car is banged up, rusty, been hit, and overall a driver - not a show car, so I don't mind practicing on it. Still a little work left to do on that patch, but overall I'm happy with it for my first one. Hopefully I have good luck with the other 6,345 patches it needs, I'll be saying my prayers.
  5. Squablow
    Squablow
    I've been doing welding/rust repairs for decades and I'd say your work there looks very good, and especially good for a first-time repair.
    The blistered area just above your new patches might end up being pinholes by the time you grind that out. Usually if you're making a repair panel, you can make it extra large and include pinholes and some surrounding area, because the back side of that is probably pitted and ready to break through fairly soon. But if you're trying to blend in the original paint in as small of areas as possible, the way you're doing it is probably as good as it gets.
    61Cruiser and chryslerfan55 like this.
  6. Fourdoor64
    Fourdoor64
    Hey thanks! It definately ended up coming out better than I had anticipated (thanks to my trusty grinder lol). I did want to include the upper part with the bubbling, but i was a bit intimidated by the body line in that spot. I may give it a go now that I'm feeling a bit more comfortable with it.
  7. Fourdoor64
    Fourdoor64
    Just got back from a camping trip to see the Adirondack Nationals show in Lake George NY. Had a blast with some friends and saw an unbelievable amount of really cool stuff. First time going but we all agreed it'll be a yearly trip from now on. The 6 banger tempest did great as always. No real issues other than a headlight going out. The thing is an absolute dog with the tired 215 mated to 2.56 gears, but it always gets me to and from wherever I'm going without any complaints. Next year I'd like to have a little more fun on the drive though, so back to the V8 one. I'll be working on it this week and hopefully I'll have it done enough to enjoy some fall cruises around new england.
    61Cruiser, Duellym, xcaddict and 5 others like this.
  8. 67drake
    67drake
    from Muscoda WI
    Cool! Using an old car the way it should be used! Not sitting in a garage under a cover
    Fourdoor64 likes this.
  9. Fordgasser1
    Fordgasser1
    from Jersey
    I love 64's Tempest/Lemans/GTO's! Here mine! Was a 6cyl,now a 68 400/th400. 456818861_429611653442905_8284099551431659471_n.jpg
    Squablow, Toms Dogs, treb11 and 5 others like this.
  10. Fourdoor64
    Fourdoor64
    Well she's roadworthy! At least kind of. The car runs great, stays cool, and stops. Did all new hard and soft lines, new wheel cylinders, front shocks, and made a few misc adjustments. The biggest issue is the stock rear gearing. This trans uses a 2.54 first gear ratio. That mixed with the 2.56 rear ratio that's in the car makes an overall first ratio of about 6.5 - not ideal. She takes a whole lot of clutch to get out of the hole. I have a 3.08 Chevy 10 bolt I'm swapping in for the time being (super clean $75 marketplace score). It still won't be great off the line, but it should be a hell of alot easier to get going then it is now. (Overall ratio of 7.8 rather than the 6.5) Ultimately id like to swap to somewhere in the 3.20-3.30s, but after all this work, I'm determined to put some miles on this car. Once I get some 3.20 something's in the car it should be A-OK. Even with that issue, once I'm going the car is a blast. Still scoots pretty good on a 3-2 downshift. It's really cool for me to drive one with a little power and a stick, after just about daily driving my straight 6 auto since 2018. Can't wait to take a few road trips next summer in this thing.
    61Cruiser, Duellym, Squablow and 7 others like this.
  11. bobss396
    bobss396
    A good feeling when it turns into a real driver. My Belair is pretty solid now. I need to do the springs soon and borrow an alignment rack.
    61Cruiser and Fourdoor64 like this.
  12. Fourdoor64
    Fourdoor64
    Made some more progress over the weekend and got the Chevy 3.08 rear end in the car, along with new seals, and rear lines. I won't be sticking with the Chevy 10 bolt forever, but for now it'll get me to the point where I can start off a bit easier than the 2.56s. planning on rebuilding the original BOP 10 bolt since those are a little bit stronger. Other than that I did a few little things like digging into the headlight harness and finding the source of my non functional right blinker. Also got the interior all the way back in the car. I am waiting on my 3r to 1310 combination U-joint and with that I should be able to actually put miles on the car. Hopefully the next post is some pictures of the car in the scenic new England fall.
    61Cruiser, 67drake, bobss396 and 2 others like this.
  13. Fourdoor64
    Fourdoor64
    This things a blast
    61Cruiser, Duellym, 67drake and 2 others like this.
  14. Fourdoor64
    Fourdoor64
    Warmer weather loading......
    Duellym, Squablow and 67drake like this.
  15. Duellym
    Duellym
    We need a chop comparison this vs my 41 now smh
  16. Fourdoor64
    Fourdoor64
    We're getting there hombre. We'll take em out Easter egg hunting
  17. Fourdoor64
    Fourdoor64
    Well it's still on jackstands, but I've done a good amount of work in the past few months. All the steering components are new, I "rebuilt" the brake master, re-sealed the intake, couple of new hoses, new edelbroken AVS2, and many oil leaks fixed. The car is ready to be put back on all 4s, but (mini rant) I've been fighting with the bullsh1t post 2019 EPA paint stripper in my efforts to strip and paint the rims. I swear I'd have gotten further stripping them with dawn dish soap. Why the EPA had to make paint stripper "safe" is beyond me...it's supposed to burn that's how you know it works. Anyways my father found an old can of the pre 2019 stuff in the ba*****t, and it worked like a charm. She'll be back on her wheels in no time. If anybody out there has a time machine, feel free to go back to the 80s and send me a few cases of paint stripper and R12. Just be sure you definately don't throw in a few quaaludes. - I'd really appriciate it.
    Squablow, bobss396 and Tickety Boo like this.
  18. Fourdoor64
    Fourdoor64
    Recently noticed I hadn't updated this in a while. The car did make the whole trip, from eastern M***achusetts, out to Michigan, and back, all in one piece. We had some issues - but once ironed out - the car did great. We even cannonballed home the last day from Ohio to M***, 12 hours, only stopping for gas. Good machine.
    treb11, Squablow, bobss396 and 2 others like this.
  19. GuyW
    GuyW
    Good show!
    I miss my '64 Goat. warmed up 326 (replacement motor), 4 spd muncie, 12 bolt posi...
  20. Squablow
    Squablow
    Hadn't noticed the update, love the pics with the S-Cargo on the roof! Who needs a wagon when you've got that?
