Hot Rods Cheap Turn Signal Switches
Discussion in 'The Hokey Ass Message Board' started by jaw22w, Aug 21, 2024.
  1. jaw22w
    jaw22w
    from Indiana
    I had the '26 out this morning. Got to the first corner and my turn signals aren't working. Great! No turn signal. no hazards. Fuse is good. But when I turn on the hazards and hit the brake, all the turn lights flash. Okay, so the turn signal switch has fallen apart inside. AGAIN. I have 30K miles on this car now, and I have replaced that switch twice now. The switch is the one from Speedway. Chrome plastic, looks cheap and apparently is! I have been searching, but that is the only switch I can find. Seems all the vendors are selling the same piece of ****. Can anyone point me towards a good quality turn signal switch?
    Tow Truck Tom likes this.
  2. Wanderlust
    Wanderlust
    If your in a rural area there are probably a bunch of those add on turn signal switches in old trucks just waiting to be put back to work :)
    Most likely will need a bit of cleaning on the contracts, but guaranteed to be built a whole lot better than the **** being sold now!
  3. In_The_Pink
    In_The_Pink
    Maybe try a vintage TSS from eBay or similar.
  4. RodStRace
    RodStRace
  5. It's obvious that you've lost the turn power from the flasher. The business of all turn lights coming on when you hit the brakes with the hazard switch turned on is normal. So before you throw another switch at it, I'd dis***emble the one you have and see if repair is possible. It's probably a design flaw, you may be able to address it.
  6. Goodspeed USA sells a decent cheap one. Actually made of metal
    Tow Truck Tom and alanp561 like this.
  7. Jack E/NJ
    Jack E/NJ
    from NJ
  8. RodStRace
    RodStRace
    I've heard that's as common knowledge as reading a dial clock nowadays.
  9. jaracer
    jaracer
    You have to be careful with old heavy truck turn signal switches. Most were setup for lamps and won't allow the brake switch to override the turn signal on one side.
    RodStRace likes this.
  10. In_The_Pink
    In_The_Pink
    Hopefully the installations instructions aren't written in cursive. :eek::D
    jaw22w and RodStRace like this.
  11. pprather
    pprather
    jazz1, Unkl Ian and olscrounger like this.
  12. olscrounger
    olscrounger
    ^^ I have used this one with good results
  13. 302GMC
    302GMC
    from Idaho
    There was a 3 ****on switch made for over the road trucks we used, came 4 or 7 wire. Push L. ****on or R. for turns, middle canceled, push L & R for 4 ways. Box was like 3''x3'' & mounted up under lip of dash panel if you wanted to hide it. Probably Signal-stat or Yankee.
  14. Bandit Billy
    Bandit Billy
    I used a United Pacific model on my dune buggy, metal case, light on the end lights up when blinking. No issues. Summit sells them
    alanp561 likes this.
  15. Crusty Chevy
    Crusty Chevy
  16. Bandit Billy
    Bandit Billy
    Acres likes this.
  17. Acres
    Acres
    from Sweden
  18. DDDenny
    Yes, yes I can!
    Johnny Gee likes this.
  19. Unkl Ian
    Unkl Ian
    Pretend you drive a BMW, throw the turn signal switch away.
  20. Unkl Ian
    Unkl Ian
    Was it the standard Cheapo turn signal switch ?
    https://www.speedwaymotors.com/Speedway-Standard-Turn-Signal-Switch,7012.html
    or the "Heavy Duty" cheapo turn signal switch, that is less money than the standard version ?
    https://www.speedwaymotors.com/Speedway-Heavy-Duty-Turn-Signal-Switch,30566.html
    Both appear to be held together by screws, open it up and see what is inside.
    If you are lucky, with the other broken ones, you have enough pieces to fix it.
    leon bee likes this.
  21. So, install dedicated signal lights.
    Ben
  22. jaracer
    jaracer
    Yes that would work.
  23. leon bee
    leon bee
    Man, this is no sh*t! Was doing just this a couple hours ago- I have the original of a certain switch, and TWO ******** reproductions dis***embled on my bench. Trying to end up with one switch that kinda works.
    Unkl Ian likes this.
  24. Unkl Ian
    Unkl Ian
    Why not use 1157 dual filament bulbs ?
  25. Unkl Ian
    Unkl Ian
    Is there a common weak link in the ******** reproductions ?
  26. deathrowdave
    deathrowdave
    from NKy
    I was with a Bud , on the Harley , a woman was giving hand signals . I guess my Buddy didn’t see her well almost bust her in da azz. I ask him “ didn’t you see her ? “ He answered only Damn thing that I knew for sure was she had the window down ! Never seen a signal one . I’m like WTH !!!
  27. jaracer
    jaracer
    Because many of the truck switches are setup for seperate lamps for turn signals and brakes. There is no provision inside the switch to deal with brake lights like there is on a p***enger car turn signal switch. On a car the brake and turn signal share one filament of an 1157 bulb.
    46international and jazz1 like this.
  28. yes the switch you want has 9 wires, the 7 wire switch does not turn the brake light off on the side you want flashing.
    The best switches are the old Signal Stat switches. I have one in my International for 45 years and still going strong. the switch in my Model A is a 40's switch from a Chevy, been working for 11 years in that car.
