Projects Removing the street rod from an A RPU
Discussion in 'Traditional Hot Rods' started by GTHOtrod, Apr 14, 2024.
  1. foot room be damned I would have kept the Cleveland. :D
    I like your choice of mill, so do not misunderstand what I am going to say. For me a hot rod outruns the other guy. You were more likely to do that with the Cleveland. Never the less I like your choice of engine. :cool:
  2. GTHOtrod
    GTHOtrod
    Took my Cleveland powered shop ute, to pick up the new to me front end.
    Purchased from a local rodder who decided to go ifs.
    Cleaned up the casting a little. Without getting to carried away. 20240520_141453.jpg
    Added a coat of ch***is coater black paint, to keep the rust away while I'm setting it all up. 20240520_173734.jpg
    Spooky, Cooon, Stogy and 10 others like this.
  3. GTHOtrod
    GTHOtrod
    Little more progress today,
    Turned up a driving punch, to fit the bushes in the stub axles
    Dug out a block, some old heads and water pumps and put them together for a mock up engine. 20240521_174856.jpg
    Removed the booger welded 'tank' , then mocked the cowl together with the new tank and firewall. 20240520_173645.jpg 20240520_173658.jpg 20240521_183217.jpg
    28rp, Stogy, LCGarage and 15 others like this.
  4. Okie Pete
    Okie Pete
    You are getting rid of the ugly and making it Your own . Very cool build . Thank You for sharing Your project with us.
    Stogy, Motorwrxs and GTHOtrod like this.
  5. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Bringing the real deal together.
    The former treatment was a mistake.
    You got it on track. Thanks for sharing your efforts
    Stogy, Outback and GTHOtrod like this.
  6. straykatkustoms
    straykatkustoms
    What a kool project! Thank you for taking the time to share your progress. Going to be very helpful for others to see your process.
  7. sko_ford
    sko_ford
  8. Motorwrxs
    Motorwrxs
    Keep it going…enjoying watching your progress
    Stogy, Tow Truck Tom and GTHOtrod like this.
  9. GTHOtrod
    GTHOtrod
    Today's progress.
    Cut the ifs mounts of the ch***is, then cleaned up one side. Still need to tidy up the other side
    Did some work to get the cowl gaps looking a lot better. Slotted a few holes, and reworked a couple curves on the repop panels.
    Slid the now shiny black, 9" back under the rear. Will be looking at options for a shorter coil over, or changing the mounting points, need to get it sitting a few inches lower in the rear 20240525_182559.jpg
  10. TomT
    TomT
    That isn’t no street rod anymore! Lookin’ goood!
    Stogy, Outback, Tow Truck Tom and 3 others like this.
  11. GTHOtrod
    GTHOtrod
    Picked up my trans adaptor from 'Old Time Speed' here in Australia. Very happy with the service.
    Will allow me the option to run either a ford t5, or muscle car era top loader, behind the flathead. 20240603_191356.jpg 20240603_191333.jpg
    41 GMC K-18, Okie Pete, Stogy and 8 others like this.
  12. GTHOtrod
    GTHOtrod
    Have been busy on OT cars in the fleet lately. But have started making a bit more progress on the A.
    ***embled The front axle, stubs, brakes. Got it sitting in the right spot, then tacked the shock mounts and hairpin mounts in place.
    Mounted my t5 to the flattie block and started to mock up for fabricating mounts.
    Sitting on the trans cross member from the clevo/ c4 combo, I was around 20mm forward. Redrilled an old trans mount by 20mm, and the engine location now looks pretty good. 20240822_181446.jpg
  13. GTHOtrod
    GTHOtrod
    Trans is a T5 from a 90's Australian 6cyl falcon. They share the front end dimensions, like input shaft length etc. with the muscle era top loader. Shifter location is a little far rearward, but that's not too painful to remedy. 20240822_181512.jpg
    Okie Pete, Stogy, LCGarage and 8 others like this.
  14. Automotive Stud
    Automotive Stud
  15. Grumpy ole A
    Grumpy ole A
    I like your build. It’s going to be a good looking hot rod.
    Stogy and GTHOtrod like this.
  16. pprather
    pprather
    Great progress reviving an old rod.
  17. 29Sleeper
    29Sleeper
    from SoCal
    Aussie Clevelands are pretty pedestrian. Ford sent the patterns down there and they were used mainly for making destroked 302s. The heads were oddball too. 2V ports and valves with 4V chamber.
  18. Stan Back
    Stan Back
    I can't figure out why the first builder put the engine so far back, especially on a roadster pickup. Perhaps he bought the driveshaft first and built forward.
  19. GTHOtrod
    GTHOtrod
    I have 351 Cleveland's in both my aussie xy falcons. Both using those oddball 2v closed chamber heads. They make for a good combo, with 11:1 comp and the old F246 cam.
    Spooky, deadbeat, Cooon and 1 other person like this.
  20. GTHOtrod
    GTHOtrod
    I can only ***ume the ch***is was originally built for a 289/302 c4 combo. But it's still a long way back.
    It seems this little A has had many ambitious owners since the project was started, seemingly about 30 years ago, from what i can put together of its history. But no one had successfully achieved much with the build.
    28rp, Outback and Stogy like this.
  21. HOTRODPRIMER
    HOTRODPRIMER
    The steel wheels are a big improvement to the overall look, gonna be a cool ride. HRP
    Outback, GTHOtrod and Stogy like this.
  22. dmar836
    dmar836
    Be careful. Disk brakes, fat radials, 9", coil overs, T5. Still firmly on the bubble IMO.
    1biggun likes this.
  23. GTHOtrod
    GTHOtrod
    Being an Australian build, the disc brakes are so much easier for registration, so they'll be staying. The 9"and t5 are neither here nor there for me, being under the car.
    So they're staying. Looking at getting rid of the coil overs. And wheels and tyres are a long way off, it needs something to roll on while I build it
    Okie Pete, 28rp and nunattax like this.
  24. 29Sleeper
    29Sleeper
    from SoCal
    Plan on those as your last big buy. A friend was building a car right when Boyd's billet wheels became the street rod thing. He spent a lot of money and by the time the car was done that wheel fad had p***ed him by. He got about 1/3 of what he paid for them.
    osage orange, Outback and GTHOtrod like this.
  25. GTHOtrod
    GTHOtrod
    Was happy to come across these market place today.
    Set of 16x4 dodge wheels, should fit the build nicely being a decent early wheel with 5x4.5" pattern Screenshot_20240901_115843_Facebook.jpg
  26. Outback
    Outback
    from NE Vic, Oz
    Nice work, they are a good looking wheel
    GTHOtrod likes this.
  27. GTHOtrod
    GTHOtrod
    Will likely dress them with an early ford cap
    Outback likes this.
  28. Outback
    Outback
    from NE Vic, Oz
    I had some with some ribbed dress rings that looked pretty good
  29. GTHOtrod
    GTHOtrod
    Needed to add a clutch pedal, now I've changed to a manual trans. I got lucky and picked up this pedal box for not much money. It was well worth the price just for the pedal rubbers alone. If I can use the pedals or pedal box also, then even better.
    BigJoeArt and 41 GMC K-18 like this.
  30. GTHOtrod
    GTHOtrod
    Tacked in my motor mounts.
    Then mounted up my gl*** fenders and sat the cowl on for a look at the progress.
    I have found some front and rear fenders local to me, that need some work, so will be replacing the gl*** ones.
    20240912_113802.jpg 20240915_121705.jpg 20240915_172038.jpg 20240915_172102.jpg 20240915_171804.jpg
