Just a Thought.. EFI on a Flathead???
Discussion in 'Off Topic Hot Rods & Customs' started by lostn51, May 7, 2024.
  1. PotvinV8
    PotvinV8
    I would say that's a logical concern, BUT if you take the ECU out of the equation, you've got a throttle body and a bunch of sensors, that, if you're hand was forced, should be able to be made to work with just about any other ECU. Now, it won't be plug and play, but it would allow one to upgrade an older system. The ECU just sees voltage from the various sensors, compiles that information, and translates it into a fuel map based on those inputs. So theoretically, you could take a throttle body and sensors from Company A and wire it to Company B's ECU and make it work just fine.
    RodStRace likes this.
  2. CSPIDY
    CSPIDY
    FFI technology is so much better than carb technology
    Why hide it
    the way I see it, this is hotrodding at it best
  3. Vic Walter
    Vic Walter
    Moon Eyes EFI 3x2 and a Mega Squirt ECM should get it done...
    RMcCulley and lostn51 like this.
  4. Vic Walter
    Vic Walter
    Carb technology really is not that bad. What makes it bad is that modern fuels are not designed to function at atmospheric pressure like you find in carb float bowls.
    lostn51 and 19Eddy30 like this.
